查看: 2782|回复: 8
[不限流量] WikiHost 5元月抛(大概)BGP韩国小鸡评测
发表于 2021-12-13 00:38:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置:
Korea - Ceph BGP KVM VPS - Standard - Standard.A1
vCPU 1x (Xeon 26xx v4 - 均衡分配)
内存 1G
系统盘 50G | 云存储
存储冗余技术 Ceph 云存储技术
存储盘 无 (可附加)
上行月流量 350G
不计算下行流量
公网网络速率 200Mbps
内网网络速率 1Gbps
IPv4 地址 1x
DDoS防御 无 (被攻击黑洞2小时)
200Mbps @ 限定流量 耗尽后自动降级到 3Mbps @ 无限流量
次月流量重置恢复 200Mbps
优惠码: 1YK3GM26KK 90%一次性折扣 , 限制 200 名客户 . 限制月付
测试ip:161.129.34.x
CPU Model             : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
CPU Cores             : 1
CPU Frequency         : 2399.996 MHz
CPU Cache             : 16384 KB
Total Disk            : 50.1 GB (0.9 GB Used)
Total Mem             : 978 MB (63 MB Used)
Total Swap            : 0 MB (0 MB Used)
System uptime         : 0 days, 0 hour 3 min
Load average          : 0.81, 0.56, 0.23
OS                    : Debian GNU/Linux 11
Arch                  : x86_64 (64 Bit)
Kernel                : 5.10.0-8-cloud-amd64
TCP CC                : bbr
Virtualization        : KVM
Organization          : AS138195 MOACK.Co.LTD
Region                : Seoul
I/O Speed(1st run)    : 201 MB/s
I/O Speed(2nd run)    : 148 MB/s
I/O Speed(3rd run)    : 130 MB/s
Average I/O speed     : 159.7 MB/s
Speedtest.net    192.76 Mbps       202.61 Mbps         160.53 ms
Shanghai   CT    210.17 Mbps       3.07 Mbps           58.72 ms
Shanghai   CU    209.06 Mbps       201.93 Mbps         24.38 ms
Guangzhou  CT    101.77 Mbps       2.46 Mbps           60.64 ms
Hongkong   CN    210.76 Mbps       205.94 Mbps         40.06 ms
Tokyo      JP    209.89 Mbps       200.53 Mbps         31.45 ms
yabs.sh
#              Yet-Another-Bench-Script              #
#                     v2021-12-03                    #
# https://github.com/masonr/yet-another-bench-script #
Sun Dec 12 16:10:12 UTC 2021
Basic System Information:
Processor  : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
CPU cores  : 1 @ 2399.996 MHz
AES-NI     : ✔️ Enabled
VM-x/AMD-V : ✔️ Enabled
RAM        : 978.8 MiB
Swap       : 0.0 KiB
Disk       : 49.2 GiB
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 2.74 MB/s      (685) | 18.08 MB/s     (282)
Write      | 2.75 MB/s      (688) | 18.52 MB/s     (289)
Total      | 5.49 MB/s     (1.3k) | 36.60 MB/s     (571)
Read       | 59.21 MB/s     (115) | 108.16 MB/s    (105)
Write      | 62.36 MB/s     (121) | 115.37 MB/s    (112)
Total      | 121.58 MB/s    (236) | 223.54 MB/s    (217)
Provider        | Location (Link)           | Send Speed      | Recv Speed
Clouvider       | London, UK (10G)          | 158 Mbits/sec   | 178 Mbits/sec
Online.net      | Paris, FR (10G)           | 164 Mbits/sec   | 318 Kbits/sec
WorldStream     | The Netherlands (10G)     | 164 Mbits/sec   | 143 Kbits/sec
WebHorizon      | Singapore (1G)            | 199 Mbits/sec   | busy
Clouvider       | NYC, NY, US (10G)         | 171 Mbits/sec   | 175 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 173 Mbits/sec   | 185 Mbits/sec
Clouvider       | Los Angeles, CA, US (10G) | 186 Mbits/sec   | 189 Mbits/sec
Iveloz Telecom  | Sao Paulo, BR (2G)        | 158 Mbits/sec   | 166 Mbits/sec
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 748
Multi Core      | 739
Full Test       | https://browser.geekbench.com/v5/cpu/11568178
traceroute to 202.141.162.123 (202.141.162.123), 30 hops max, 32 byte packets
1  161.129.34.1  1.77 ms  AS138195  Republic of Korea, Seoul, rixcloud.com
2  10.24.80.1  0.56 ms  *  LAN Address
3  10.10.10.17  0.61 ms  *  LAN Address
4  203.195.115.25  2.53 ms  AS4809  Republic of Korea, Seoul, ChinaTelecom
5  59.43.187.209  24.01 ms  *  China, Shanghai, ChinaTelecom
6  *
7  59.43.130.205  38.30 ms  *  China, Shanghai, ChinaTelecom
8  *
9  202.97.13.10  30.90 ms  AS4134  China, Anhui, Hefei, ChinaTelecom
10  202.102.217.22  32.19 ms  AS4134  China, Anhui, Hefei, ChinaTelecom
11  61.191.108.201  39.88 ms  AS4134  China, Anhui, Hefei, ChinaTelecom
12  61.190.194.54  32.35 ms  AS4134  China, Anhui, Hefei, ChinaTelecom
13  *
14  218.22.20.10  32.34 ms  AS4134  China, Anhui, Hefei, ChinaTelecom
15  lug.ustc.edu.cn (202.141.162.123)  32.28 ms  AS4134  China, Anhui, Hefei, ustc.edu.cn, ChinaTelecom
电信为双向CN2线路,移动联通BGP直连
发表于 2021-12-13 08:57:24 | 只看该作者
来个tg,或者联系签名tg
发表于 2021-12-13 00:39:56 来自手机 | 只看该作者
还不错,看起来,解锁情况有吗
发表于 2021-12-13 00:41:21 | 只看该作者
买了一个,吃灰中,有人要吗?
 楼主| 发表于 2021-12-13 00:44:02 | 只看该作者
ycdxsb 发表于 2021-12-13 00:39
还不错,看起来,解锁情况有吗
来了
** 正在测试IPv4解锁情况
** 您的网络为: MOACK.Co.LTD
Dazn:                                  No
HotStar:                               No
Disney+:                               Yes (Region: US)
有图比 Premium:                       No  (Region: CN)
Amazon Prime Video:                    Unsupported
Tiktok Region:                         US
iQyi Oversea Region:                   KR
Viu.com:                               No
有图比 CDN:                           Tokyo
Netflix Preferred CDN:                 Associated with [Sejong Telecom] in [Seoul]
当前主机不支持IPv6,跳过...
环球旅游体质
发表于 2021-12-13 00:45:06 来自手机 | 只看该作者
优惠码只能用一次么
发表于 2021-12-13 00:48:00 | 只看该作者
亏了,看了下买不到了
发表于 2021-12-13 00:52:36 | 只看该作者
ansheng 发表于 2021-12-13 00:41
买了一个,吃灰中,有人要吗?
发表于 2021-12-13 08:58:02 | 只看该作者
不错的机子
GMT+8, 2026-4-21 05:37 , Processed in 0.070245 second(s), 11 queries , Gzip On, MemCache On.
