查看: 1604|回复: 6
[Windows VPS] Oracle SG的ARM因维护需要迁移?
发表于 2021-12-12 17:34:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Oracle Cloud Infrastructure Customer,
The Oracle Cloud Infrastructure team detected one or more of your instances as unstable due to an error in the underlying infrastructure. At the time listed below, Oracle Cloud Infrastructure will attempt to move your instance(s) to a different infrastructure. It is recommended that you move your instance(s) before the time listed below.
Details related to affected instance(s), timing, and instructions on how to move your affected instance(s) can be found below.
To request a 7 or 14-day extension, please contact support at least 24 hours before the current start/action required by time, and ensure you provide the CN reference number and instance ID(s).
How do I move my instance(s)?
Many instances can be moved with a simple reboot. For more details, please check our online documentation here: https://docs.cloud.oracle.com/iaas/Content/Compute/Tasks/movinganinstance.htm
这是干啥?说迁移用重启就行了,但主机连不上啊,控制台选择重启,说被修改了,不能重启。。。我擦
instance ocid1.instance.oc1.ap-singapore-1.xxxx is currently being modified, try again later
发表于 2021-12-12 17:36:10 | 只看该作者
即使是世界首富。也经不住mjj大军入驻。迟早要集体下车
发表于 2021-12-12 17:36:23 | 只看该作者
实例哪里重新引导
发表于 2021-12-12 17:37:28 | 只看该作者
等就行了
发表于 2021-12-12 17:38:18 | 只看该作者
你的实例状态是正在停止吗
发表于 2021-12-12 17:45:05 | 只看该作者
放着不动吧,我的昨天也维护了,提示维护好了,可惜SSH连不上,我就重新引导,一直提示引导中,然后我就把它终止掉,从昨天晚上终止到现在也没成功,今天不管了我就重新建了一个
 楼主| 发表于 2021-12-12 17:55:26 来自手机 | 只看该作者
感觉是被撸狠了,借维护接口直接封了
GMT+8, 2026-5-1 01:21 , Processed in 0.058949 second(s), 10 queries , Gzip On, MemCache On.
