查看: 2639|回复: 8
请教下contabo带宽限制问题
发表于 2021-12-4 23:03:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在loc里搜了一下,contabo好像要求9天还是10天内平均带宽占用不超过100m。不过我又在一个帖子看到说是这个限制的是上传。
想问下有没有了解的mjj,如果下载长时间跑满会不会有限制,这几天plex在刮削片子生成视频预览略缩图,估摸着还得跑几天
来自 8#
 楼主| 发表于 2021-12-8 17:56:42 | 只看该作者
atomkk 发表于 2021-12-6 17:16
我也想知道这个问题,客服有答复麻烦楼主也回来说一下,先谢了哈
收到回复了
Thank you for your inquiry. With respect to the bandwidth please allow us to inform you in detail:
The Internet access to our data centers is 100 percent redundant and multi-homed via 780 Gbit/s in total (e.g. Telia Carrier, Lumen, DE-CIX, AMS-IX, Cogent, Hurricane Electric, M-Net, Versatel, Colt). We have implemented several mechanisms and monitoring systems in order to guarantee the best networking possible for our customers. A team of highly skilled technicians is permanently working on solutions to enforce network improvements while we also strive toward the increase of bandwidth capacities and development of business relations to reliable Internet carriers. The traffic is unlimited, so you do not need to care about how much traffic you use every month. We do not oversubscribe our bandwidth capacities unlike many other providers. Thus, generally the full port speed is provided to you at any time.
Depending on the particular model, our VPS and Virtual Dedicated Servers come with different ports ranging from 100 Mbit/s up to 1 Gbit/s. Most of our Dedicated Servers have a 100 Mbit/s port, while some exceptional, high-end servers even provide a 1 Gbit/s port by default. All of our Dedicated Servers can be upgraded to a Gbit/s connection which provides the opportunity to transfer data quickly with up to 1,000 Mbit/s. As a high-end solution, only our Dedicated Servers Dual 10-Core and AMD EPYC can be equipped with a 10 Gbit/s port. This allows for a temporary maximum of transfer rates.
Only for our Virtual Dedicated Servers and Dedicated Servers we can offer you Unrestricted Data Transfer with higher bandwidth values at extremely affordable prices. Unrestricted Data Transfer guarantees a fixed value of bandwidth which is available at all times, of course, with unlimited traffic. If you require constantly high bandwidth values which exceed 100 Mbit/s, we recommend our Unrestricted Data Transfer Add-Ons to you.
However, there can be some isolated and temporary limits at different points in the Internet routing - outside of our sphere of influence - owing to the continuously changing and developing structure of the Internet. Your local Internet access provider might be the initiator for bandwidth problems in your area, too.
It might be possible to achieve a significant improvement by adjusting various settings. In order to do so, we require some information, and we therefore would appreciate it very much if you could respond to the following questions:
* What kind of traffic is your server handling at the moment?
* Did you change the settings of the network card?
* Can you send us an overview of the services employed on your server and the corresponding network ports?
* Finally, can you send us a traceroute protocol to your server?
This information will enable us to analyze the issue thoroughly.
Looking forward to reading your feedback!
If you have any questions or need help, please do not hesitate to contact us.
谢谢你的询问。关于带宽问题,请允许我们向您详细介绍一下。
我们的数据中心的互联网接入是100%冗余的,并且通过780Gbit/s的多中心接入(如Telia Carrier、Lumen、DE-CIX、AMS-IX、Cogent、Hurricane Electric、M-Net、Versatel、Colt)。我们已经实施了一些机制和监测系统,以保证为我们的客户提供最好的网络。一支由高技能技术人员组成的团队长期致力于解决网络改进问题,同时我们还努力提高带宽能力,并与可靠的互联网运营商发展业务关系。流量是无限的,所以你不需要关心你每个月使用多少流量。我们不会像许多其他供应商那样超额订购我们的带宽容量。因此,一般来说,在任何时候都会向您提供完整的端口速度。
根据特定的模型,我们的VPS和虚拟专用服务器有不同的端口,从100 Mbit/s到1 Gbit/s。我们大多数的专用服务器都有一个100 Mbit/s的端口,而一些特殊的高端服务器甚至默认提供1 Gbit/s的端口。我们所有的专用服务器都可以升级到Gbit/s连接,这为快速传输数据提供了机会,速度高达1,000 Mbit/s。作为一个高端解决方案,只有我们的专用服务器双10核和AMD EPYC可以配备一个10 Gbit/s端口。这允许传输速率暂时达到最高。
只有我们的虚拟专用服务器和专用服务器,我们可以以极其实惠的价格为您提供具有更高带宽值的无限制数据传输。无限制数据传输保证了一个固定的带宽值,当然是在任何时候都可以使用的,而且是无限流量。如果你需要持续的高带宽值,超过100 Mbit/s,我们向你推荐我们的无限制数据传输附加功能。
然而,由于互联网结构的不断变化和发展,在互联网路由的不同点上可能存在一些孤立和临时的限制--在我们的影响范围之外。你当地的互联网接入商也可能是你所在地区带宽问题的始作俑者。
通过调整各种设置,可能会有明显的改善。为了做到这一点,我们需要一些信息,因此,如果你能回答以下问题,我们将非常感激。
* 你的服务器目前正在处理什么样的流量?
* 你是否改变了网卡的设置?
* 你能给我们发一份你的服务器上使用的服务和相应的网络端口的概述吗?
*最后,你能给我们发送一个到你服务器的traceroute协议吗?
这些信息将使我们能够彻底分析这个问题。
期待阅读您的反馈!
如果你有任何问题或需要帮助,请不要犹豫,与我们联系。
没正面回答行不行,但是看上去应该是下行也不能长期占用超过100M
 楼主| 发表于 2021-12-4 23:14:22 | 只看该作者
In Contabo we will never charge you extra for your traffic. The traffic package is already included in your server. Generally the full port speed is provided to you anytime. In case your server has an uplink faster than 100 Mbit/s and the average traffic consumption continuously exceeds 100 Mbit/s over a timespan of at least 10 days the connection is switched to 100 Mbit/s to make sure you will stay within your traffic package and will not incur any fees.
在 Contabo,我们绝不会为您的流量收取额外费用。流量包已包含在您的服务器中。通常,全端口速度随时提供给您。如果您的服务器的上行链路速度超过 100 Mbit/s 并且平均流量消耗在至少 10 天的时间跨度内持续超过 100 Mbit/s,则连接切换到 100 Mbit/s 以确保您保持在流量范围内包,不会产生任何费用。
去官网查了一下,下载应该是没啥问题的
发表于 2021-12-4 23:19:56 | 只看该作者
限制200M,连续跑满限到100M
 楼主| 发表于 2021-12-4 23:25:29 | 只看该作者
好鸭 发表于 2021-12-4 23:19
限制200M,连续跑满限到100M
我刚发了个邮件去问他们客服了,看看他们客服怎么说
发表于 2021-12-6 10:00:27 | 只看该作者
请教楼主,客服有回复吗?
 楼主| 发表于 2021-12-6 16:17:43 | 只看该作者
atomkk 发表于 2021-12-6 10:00
请教楼主,客服有回复吗?
还没,应该是周末不上班,这会德国才周一早上
发表于 2021-12-6 17:16:08 | 只看该作者
发表于 2021-12-9 10:11:47 | 只看该作者
空灵心梦 发表于 2021-12-8 17:56
收到回复了
If you require constantly high bandwidth values which exceed 100 Mbit/s, we recommend  ...
懂了,感谢!
GMT+8, 2026-4-17 05:49 , Processed in 0.065034 second(s), 11 queries , Gzip On, MemCache On.
