查看: 12405|回复: 104
virmach AMD Ryzen 8.88 开通了 测试(更新3 有CPU分数了)
发表于 2021-12-4 18:47:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想收的看这个帖子:https://loc.qiche.eu.org/thread-932955-1-1.html
yabs 脚本
  1. Basic System Information:
  3. Processor  : AMD Ryzen 9 3900X 12-Core Processor
  4. CPU cores  : 8 [url=home.php?mod=space&uid=*]@[/url] 3799.998 MHz
  5. AES-NI     : ✔ Enabled
  6. VM-x/AMD-V : ❌ Disabled
  7. RAM        : 8.3 GiB
  8. Swap       : 256.0 MiB
  9. Disk       : 86.4 GiB
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 349.47 MB/s  (87.3k) | 572.58 MB/s   (8.9k)
  15. Write      | 350.39 MB/s  (87.5k) | 575.59 MB/s   (8.9k)
  16. Total      | 699.86 MB/s (174.9k) | 1.14 GB/s    (17.9k)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 646.48 MB/s   (1.2k) | 678.33 MB/s    (662)
  21. Write      | 680.83 MB/s   (1.3k) | 723.50 MB/s    (706)
  22. Total      | 1.32 GB/s     (2.5k) | 1.40 GB/s     (1.3k)
  23. iperf3 Network Speed Tests (IPv4):
  25. Provider        | Location (Link)           | Send Speed      | Recv Speed
  26.                 |                           |                 |
  27. Clouvider       | London, UK (10G)          | busy            | busy
  28. Online.net      | Paris, FR (10G)           | 803 Mbits/sec   | 143 Mbits/sec
  29. WorldStream     | The Netherlands (10G)     | busy            | busy
  30. WebHorizon      | Singapore (1G)            | 103 Mbits/sec   | busy
  31. Clouvider       | NYC, NY, US (10G)         | 884 Mbits/sec   | 589 Mbits/sec
  32. Velocity Online | Tallahassee, FL, US (10G) | 563 Mbits/sec   | 8.21 Mbits/sec
  33. Clouvider       | Los Angeles, CA, US (10G) | 939 Mbits/sec   | 940 Mbits/sec
  34. Iveloz Telecom  | Sao Paulo, BR (2G)        | 662 Mbits/sec   | 173 Mbits/sec
用vir自带的默认Centos 8系统跑不了yabs脚本测CPU的部分
gb5 CPU单独手动测试已经发在下面了
更新 1:
换了LemonBench脚本测CPU
  1. CPU Model:             AMD Ryzen 9 3900X 12-Core Processor  3.80 GHz
  2. CPU Cache Size:        512 KB
  3. CPU Number:            8 vCPU
  4. Virt Type:             KVM
  5. Memory Usage:          216.35 MB / 8.30 GB
  6. Swap Usage:            0 KB / 256.00 MB
  7. Boot Device:           /dev/vda1
  8. Disk Usage:            1.75 GB / 90.60 GB
  9. CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
  10. Load (1/5/15min):      0.48 0.10 0.03
  11. Uptime:                0 Days, 0 Hours, 12 Minutes, 12 Seconds
  12. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  13. 1 Thread Test:                 2151 Scores
  14. 8 Threads Test:                16740 Scores
  15. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  16. 1 Thread - Read Test :         57704.72 MB/s
  17. 1 Thread - Write Test:         25761.48 MB/s
更新 2:
UnixBench脚本测CPU
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3. ------------------------------------------------------------------------
  4. Benchmark Run: Sat Dec 04 2021 07:15:43 - 07:43:28
  5. 8 CPUs in system; running 1 parallel copy of tests
  6. Dhrystone 2 using register variables       55592558.3 lps   (10.0 s, 7 samples)
  7. Double-Precision Whetstone                    10129.4 MWIPS (8.9 s, 7 samples)
  8. Execl Throughput                               6652.1 lps   (30.0 s, 2 samples)
  9. File Copy 1024 bufsize 2000 maxblocks       1545178.1 KBps  (30.0 s, 2 samples)
  10. File Copy 256 bufsize 500 maxblocks          407268.8 KBps  (30.0 s, 2 samples)
  11. File Copy 4096 bufsize 8000 maxblocks       4455474.9 KBps  (30.0 s, 2 samples)
  12. Pipe Throughput                             2470505.1 lps   (10.0 s, 7 samples)
  13. Pipe-based Context Switching                 331961.8 lps   (10.0 s, 7 samples)
  14. Process Creation                              13459.2 lps   (30.0 s, 2 samples)
  15. Shell Scripts (1 concurrent)                  10428.1 lpm   (60.0 s, 2 samples)
  16. Shell Scripts (8 concurrent)                   4392.8 lpm   (60.0 s, 2 samples)
  17. System Call Overhead                        2418653.7 lps   (10.0 s, 7 samples)
  18. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  19. Dhrystone 2 using register variables         116700.0   55592558.3   4763.7
  20. Double-Precision Whetstone                       55.0      10129.4   1841.7
  21. Execl Throughput                                 43.0       6652.1   1547.0
  22. File Copy 1024 bufsize 2000 maxblocks          3960.0    1545178.1   3902.0
  23. File Copy 256 bufsize 500 maxblocks            1655.0     407268.8   2460.8
  24. File Copy 4096 bufsize 8000 maxblocks          5800.0    4455474.9   7681.9
  25. Pipe Throughput                               12440.0    2470505.1   1985.9
  26. Pipe-based Context Switching                   4000.0     331961.8    829.9
  27. Process Creation                                126.0      13459.2   1068.2
  28. Shell Scripts (1 concurrent)                     42.4      10428.1   2459.5
  29. Shell Scripts (8 concurrent)                      6.0       4392.8   7321.3
  30. System Call Overhead                          15000.0    2418653.7   1612.4
  31.        ========
  32. System Benchmarks Index Score                                        2468.4
  33. ------------------------------------------------------------------------
  34. Benchmark Run: Sat Dec 04 2021 07:43:28 - 08:11:15
  35. 8 CPUs in system; running 8 parallel copies of tests
  36. Dhrystone 2 using register variables      414498665.7 lps   (10.0 s, 7 samples)
  37. Double-Precision Whetstone                    77565.0 MWIPS (8.9 s, 7 samples)
  38. Execl Throughput                              27875.8 lps   (29.9 s, 2 samples)
  39. File Copy 1024 bufsize 2000 maxblocks        933643.5 KBps  (30.0 s, 2 samples)
  40. File Copy 256 bufsize 500 maxblocks          240418.5 KBps  (30.0 s, 2 samples)
  41. File Copy 4096 bufsize 8000 maxblocks       2827648.8 KBps  (30.0 s, 2 samples)
  42. Pipe Throughput                            18621001.2 lps   (10.0 s, 7 samples)
  43. Pipe-based Context Switching                1846203.4 lps   (10.0 s, 7 samples)
  44. Process Creation                              49492.3 lps   (30.0 s, 2 samples)
  45. Shell Scripts (1 concurrent)                  40872.9 lpm   (60.0 s, 2 samples)
  46. Shell Scripts (8 concurrent)                   6457.0 lpm   (60.0 s, 2 samples)
  47. System Call Overhead                        9583271.0 lps   (10.0 s, 7 samples)
  48. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  49. Dhrystone 2 using register variables         116700.0  414498665.7  35518.3
  50. Double-Precision Whetstone                       55.0      77565.0  14102.7
  51. Execl Throughput                                 43.0      27875.8   6482.7
  52. File Copy 1024 bufsize 2000 maxblocks          3960.0     933643.5   2357.7
  53. File Copy 256 bufsize 500 maxblocks            1655.0     240418.5   1452.7
  54. File Copy 4096 bufsize 8000 maxblocks          5800.0    2827648.8   4875.3
  55. Pipe Throughput                               12440.0   18621001.2  14968.7
  56. Pipe-based Context Switching                   4000.0    1846203.4   4615.5
  57. Process Creation                                126.0      49492.3   3928.0
  58. Shell Scripts (1 concurrent)                     42.4      40872.9   9639.8
  59. Shell Scripts (8 concurrent)                      6.0       6457.0  10761.6
  60. System Call Overhead                          15000.0    9583271.0   6388.8
  61.        ========
  62. System Benchmarks Index Score                                        6798.7
  63. ======= Script description and score comparison completed! =======
更新 3:
Geekbench 5 脚本测CPU
用vir自带默认Centos系统跑的 没有dd纯净系统
https://browser.geekbench.com/v5/cpu/11415624
  1. Geekbench 5 Score
  2. Single-Core Score 1214
  3. Multi-Core Score 7711
测得差不多了吧,今天再测下去不知道会不会因为高占用被关机呢
发表于 2021-12-4 18:50:14 | 只看该作者
看了半天最重要的cpu没有出来
已更新CPU测试  发表于 2021-12-4 21:29
发表于 2021-12-4 18:50:03 来自手机 | 只看该作者
gb5直接挂? vir可以,超售天王名副其实
yabs脚本问题,手动测gb5已经更新了  发表于 2021-12-4 21:30
发表于 2021-12-4 19:01:24 来自手机 | 只看该作者
CPU测不了,我就想笑。不过又一想,8.88不管啥CPU,都着实羡慕。
yabs脚本问题,手动测gb5已经更新了  发表于 2021-12-4 21:31
发表于 2021-12-4 20:52:52 | 只看该作者
  1. wget --no-check-certificate https://cdn.geekbench.com/Geekbench-5.4.3-Linux.tar.gz && tar xf Geekbench-5.4.3-Linux.tar.gz && cd Geekbench-5.4.3-Linux; \
  2. ./geekbench_x86_64
跑下gb5,跑完了会出得分页面链接
大佬这个就可以测gb5了,yabs脚本就测不了  发表于 2021-12-4 21:33
发表于 2021-12-4 21:06:54 | 只看该作者
hlav 发表于 2021-12-4 21:05
等一下再测这个 在跑unixbench 它测的项目太多了 跑了好久
可以的话其实最好dd下系统再测。原装的系统有点限制
发表于 2021-12-4 18:55:26 | 只看该作者
1号节点啊,我之前那个2号节点的连接不了raw.gitrubuerscontent.com,被我卖了
发表于 2021-12-4 18:50:30 | 只看该作者
curl -sL yabs.sh | bash
发表于 2021-12-4 18:48:03 | 只看该作者
实名羡慕中
发表于 2021-12-4 18:48:07 | 只看该作者
IO可以,现在邻居少
发表于 2021-12-4 18:48:18 | 只看该作者
实名羡慕+1
cherbim 该用户已被删除
发表于 2021-12-4 18:48:41 | 只看该作者
发表于 2021-12-4 18:49:02 | 只看该作者
我就是个柠檬精,我承认了
发表于 2021-12-4 18:49:03 | 只看该作者
前排 . 请问这个鸡能传家宝到倒闭吗?
GMT+8, 2026-5-2 10:42 , Processed in 0.080879 second(s), 19 queries , Gzip On, MemCache On.
