查看: 3156|回复: 18
kimsufi发布新机器了
发表于 2021-12-1 00:06:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hello !
Some of you are already aware, thanks to the huge leak of the new kimsufi servers..
So we decided to release it a bit in advance
https://www.kimsufi.com/us/en/servers.xml
https://www.kimsufi.com/en/servers.xml
你好
由于新kimsufi服务器的信息泄漏,你们中的一些人已经意识到了。。
所以我们决定提前发布:)
KS-4        Intel  Core i5-750        4c/4t        2.67GHz        16GB DDR3 1333MHz          2TB         100 Mbps        /128        $17.99
KS-15        Intel  Xeon E3-1225v2        4c/4t        3.2GHz        16GB DDR3 1333MHz        SoftRaid  3x2TB         100 Mbps        /128        $20.99
KS-16        Intel  Xeon E3-1245v2        4c/4t        3.4GHz        32GB DDR3 1333MHz        SoftRaid  3x2TB         100 Mbps        /128        $22.99
KS-17        Intel  Xeon E3-1245v2        4c/4t        3.4GHz        32GB DDR3 1333MHz        SoftRaid  2x480Go         100 Mbps        /128        $22.99
KS-GAME-1        Intel  Core i7-4790K        4c/8t        4GHz        16GB DDR3 1600MHz          240Go         100 Mbps        /128        $26.99
KS-GAME-2        Intel  Core i7-4790K        4c/8t        4GHz        32GB DDR3 1600MHz          240Go         100 Mbps        /128        $31.99
KS-5        Intel  Xeon E5-1620v2        4c/8t        3.7GHz        32GB DDR3 1333MHz        SoftRaid  2x2TB         100 Mbps        /128        $34.99
KS-9        Intel  Xeon E3-1231v3        4c/8t        3.4GHz        32GB DDR4 1333MHz        SoftRaid  4x2TB         100 Mbps        /128        $34.99
KS-6        Intel  Xeon E5-1620v2        4c/8t        3.7GHz        32GB DDR3 1333MHz        SoftRaid  2x480Go         100 Mbps        /128        $34.99
KS-10        Intel  Xeon E3-1231v3        4c/8t        3.4GHz        32GB DDR4 1333MHz        SoftRaid  2x480Go         100 Mbps        /128        $34.99
KS-12        Intel  Xeon E5-1630v3        4c/8t        3.7GHz        64GB DDR4 ECC 2133MHz        SoftRaid  2x480Go         100 Mbps        /128        $37.99
KS-11        Intel  Xeon E5-1630v3        4c/8t        3.7GHz        64GB DDR4 ECC 2133MHz        SoftRaid  4x2TB         100 Mbps        /128        $37.99
KS-7        Intel  Xeon E5-1620v2        4c/8t        3.7GHz        64GB DDR3 1333MHz        SoftRaid  2x2TB         100 Mbps        /128        $39.99
KS-14        Intel  Xeon E5-1650v3        6c/12t        3.5GHz        64GB DDR4 ECC 2133MHz        SoftRaid  2x480Go         100 Mbps        /128        $39.99
KS-13        Intel  Xeon E5-1650v3        6c/12t        3.5GHz        64GB DDR4 ECC 2133MHz        SoftRaid  4x2TB         100 Mbps        /128        $39.99
贴一个KS-GAME-1的测试
#              Yet-Another-Bench-Script              #
#                     v2021-10-09                    #
# https://github.com/masonr/yet-another-bench-script #
Tue 30 Nov 2021 04:33:41 PM UTC
Basic System Information:
Processor  : Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
CPU cores  : 8 @ 2898.132 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 15.5 GiB
Swap       : 512.0 MiB
Disk       : 234.1 GiB
fio Disk Speed Tests (Mixed R/W 50/50):
Read       | 141.36 MB/s  (35.3k) | 181.14 MB/s   (2.8k)
Write      | 141.74 MB/s  (35.4k) | 182.09 MB/s   (2.8k)
Total      | 283.11 MB/s  (70.7k) | 363.23 MB/s   (5.6k)
Read       | 227.44 MB/s    (444) | 241.09 MB/s    (235)
Write      | 239.52 MB/s    (467) | 257.15 MB/s    (251)
Total      | 466.96 MB/s    (911) | 498.25 MB/s    (486)
Provider        | Location (Link)           | Send Speed      | Recv Speed
Clouvider       | London, UK (10G)          | 95.1 Mbits/sec  | 941 Mbits/sec
Online.net      | Paris, FR (10G)           | 95.1 Mbits/sec  | 941 Mbits/sec
WorldStream     | The Netherlands (10G)     | busy            | 940 Mbits/sec
WebHorizon      | Singapore (1G)            | 8.11 Mbits/sec  | 331 Mbits/sec
Clouvider       | NYC, NY, US (10G)         | 29.9 Mbits/sec  | 656 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 19.7 Mbits/sec  | 564 Mbits/sec
Clouvider       | Los Angeles, CA, US (10G) | 16.9 Mbits/sec  | 542 Mbits/sec
Iveloz Telecom  | Sao Paulo, BR (2G)        | 13.2 Mbits/sec  | 416 Mbits/sec
Geekbench 5 Benchmark Test:
Test            | Value
Single Core     | 1184
Multi Core      | 4412
Full Test       | https://browser.geekbench.com/v5/cpu/11338790
发表于 2021-12-1 00:07:50 | 只看该作者
提前发了
 楼主| 发表于 2021-12-1 00:11:13 | 只看该作者
你先去看看,有很多新机型
发表于 2021-12-1 00:12:02 来自手机 | 只看该作者
意思我现在开机,可以分配个新机型?
发表于 2021-12-1 00:12:05 来自手机 | 只看该作者
mjj们只看价格
发表于 2021-12-1 00:13:13 | 只看该作者
只看性价比
发表于 2021-12-1 00:15:56 来自手机 | 只看该作者
ksle才是性价比
发表于 2021-12-1 00:16:04 来自手机 | 只看该作者
set up fee劝退
GMT+8, 2026-4-24 00:26 , Processed in 0.060405 second(s), 10 queries , Gzip On, MemCache On.
