查看: 1830|回复: 9
[不限流量] 关于let里readydedis这家的促销机器
发表于 2021-11-30 02:08:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个是官网在售的配置:
这个是目前在促销的配置:
Specifications
FLASH-10G
2 cores
10GB RAM
100GB SSD
Unmetered @ 1Gbps
1 IPv4
Free Windows / Linux
Location: Seattle, WA / Atlanta, GA / Jacksonville, FL / Las Vegas, NV
Promo code: FLASH10GBOU47HUYAO0
$10/m
可见,虽然便宜,但是跟他所标注的原价100刀有那么一点先加价再给个折扣的感觉。
实际上,我是先选了亚特兰大,然后迁移到了西雅图,ip都是跟大家看到的一样,是colocrossing,也就是现在在促销的vir家的。
以下是亚特兰大的测试数据:
  3. #                     v2021-10-09                    #
  6. Mon Nov 29 12:24:11 EST 2021
  7. Basic System Information:
  9. Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
  10. CPU cores  : 2 @ 2799.998 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ❌ Disabled
  13. RAM        : 9.6 GiB
  14. Swap       : 0.0 KiB
  15. Disk       : 98.4 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 81.76 MB/s   (20.4k) | 419.75 MB/s   (6.5k)
  21. Write      | 81.97 MB/s   (20.4k) | 421.96 MB/s   (6.5k)
  22. Total      | 163.74 MB/s  (40.9k) | 841.72 MB/s  (13.1k)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 708.59 MB/s   (1.3k) | 718.94 MB/s    (702)
  27. Write      | 746.24 MB/s   (1.4k) | 766.82 MB/s    (748)
  28. Total      | 1.45 GB/s     (2.8k) | 1.48 GB/s     (1.4k)
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 676 Mbits/sec   | 153 Mbits/sec
  34. Online.net      | Paris, FR (10G)           | 637 Mbits/sec   | 144 Mbits/sec
  35. WorldStream     | The Netherlands (10G)     | 648 Mbits/sec   | 129 Mbits/sec
  36. WebHorizon      | Singapore (1G)            | 161 Mbits/sec   | 124 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 725 Mbits/sec   | 574 Mbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 695 Mbits/sec   | 518 Mbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 673 Mbits/sec   | 242 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 598 Mbits/sec   | 136 Mbits/sec
以下则是西雅图的情况:
  3. #                     v2021-10-09                    #
  6. Mon Nov 29 12:43:46 EST 2021
  13. RAM        : 9.6 GiB
  14. Swap       : 0.0 KiB
  15. Disk       : 98.4 GiB
  20. Read       | 18.27 MB/s    (4.5k) | 121.72 MB/s   (1.9k)
  21. Write      | 18.28 MB/s    (4.5k) | 122.36 MB/s   (1.9k)
  22. Total      | 36.55 MB/s    (9.1k) | 244.08 MB/s   (3.8k)
  23.            |                      |
  26. Read       | 284.96 MB/s    (556) | 298.81 MB/s    (291)
  27. Write      | 300.10 MB/s    (586) | 318.71 MB/s    (311)
  28. Total      | 585.06 MB/s   (1.1k) | 617.53 MB/s    (602)
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 392 Mbits/sec   | 113 Mbits/sec
  34. Online.net      | Paris, FR (10G)           | 798 Mbits/sec   | 87.3 Mbits/sec
  35. WorldStream     | The Netherlands (10G)     | 506 Mbits/sec   | 172 Mbits/sec
  36. WebHorizon      | Singapore (1G)            | 218 Mbits/sec   | 4.16 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 852 Mbits/sec   | 258 Mbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 855 Mbits/sec   | 5.48 Mbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 902 Mbits/sec   | 12.1 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 542 Mbits/sec   | 2.36 Mbits/sec
结论:
看看西雅图这读写速度,再看看这网络,美西基本上是没法用了。美东就看各位老板有没有特别的场景。
发表于 2021-11-30 02:11:08 | 只看该作者
总结:你亏了
发表于 2021-11-30 02:12:46 来自手机 | 只看该作者
cc机房 就是vir用的那个机房吧
 楼主| 发表于 2021-11-30 02:13:06 | 只看该作者
无所谓亏不亏,玩玩就好。
发表于 2021-11-30 02:13:28 | 只看该作者
你为甚能觉得它值10刀?无限流量?
发表于 2021-11-30 02:15:41 来自手机 | 只看该作者
其实他家还有个洛杉矶的amd,用起来还可以
 楼主| 发表于 2021-11-30 02:19:14 | 只看该作者
haoxiujie 发表于 2021-11-30 02:12
cc机房 就是vir用的那个机房吧
大佬说得对。就是vir所用的机房。
发表于 2021-11-30 02:22:02 来自手机 | 只看该作者
给个链接,感觉可以收来刷刷pt?
 楼主| 发表于 2021-11-30 02:25:14 | 只看该作者
深沐 发表于 2021-11-30 02:22
给个链接,感觉可以收来刷刷pt?
建议还是别上车了,价格其实没有啥优势,当然他们家有免费的windows,然而对于dd来说就意义不大了。
发表于 2021-11-30 02:38:12 来自手机 | 只看该作者
零维 发表于 2021-11-30 02:25
建议还是别上车了,价格其实没有啥优势,当然他们家有免费的windows,然而对于dd来说就意义不大了。 ...
这个感觉吃灰有点划不来
GMT+8, 2026-4-24 11:12 , Processed in 0.076698 second(s), 10 queries , Gzip On, MemCache On.
