查看: 4299|回复: 21
今天的Vir 闪购 - 水牛城-纽约 22:00测速
发表于 2021-11-29 22:16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
闪购套餐:
$8.01/yr - BUFFALO, NY / 1 vCPU / 1408M RAM / 25G SSD / 2500G BW / 1 IPs
原版BBR,v2-ws 裸奔
测速时间: 22:00
基本上都拉3次左右,以观察是否偶然现象(错觉
某广东移动100Mbps:
  1. root@VM-888:~# iperf3 -c 23.94.*.*
  2. Connecting to host 23.94.*.*, port 5201
  3. [  4] local 192.168.*.* port 50440 connected to 23.94.*.* port 5201
  4. [ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
  5. [  4]   0.00-1.00   sec   864 KBytes  7.08 Mbits/sec    0    124 KBytes
  6. [  4]   1.00-2.00   sec  4.41 MBytes  37.0 Mbits/sec    0   1.94 MBytes
  7. [  4]   2.00-3.00   sec  9.71 MBytes  81.4 Mbits/sec    0   8.55 MBytes
  8. [  4]   3.00-4.00   sec  11.0 MBytes  92.4 Mbits/sec    0   8.71 MBytes
  9. [  4]   4.00-5.00   sec  11.0 MBytes  92.5 Mbits/sec    0   8.74 MBytes
  10. [  4]   5.00-6.00   sec  11.0 MBytes  92.2 Mbits/sec    0   8.74 MBytes
  11. [  4]   6.00-7.00   sec  10.9 MBytes  91.7 Mbits/sec    0   8.74 MBytes
  12. [  4]   7.00-8.00   sec  11.0 MBytes  92.4 Mbits/sec    0   8.74 MBytes
  13. [  4]   8.00-9.00   sec  11.0 MBytes  92.4 Mbits/sec    0   8.76 MBytes
  14. [  4]   9.00-10.00  sec  11.0 MBytes  92.5 Mbits/sec    0   8.76 MBytes
  15. - - - - - - - - - - - - - - - - - - - - - - - - -
  16. [ ID] Interval           Transfer     Bandwidth       Retr
  17. [  4]   0.00-10.00  sec  92.0 MBytes  77.2 Mbits/sec    0             sender
  18. [  4]   0.00-10.00  sec  91.2 MBytes  76.5 Mbits/sec                  receiver
  19. iperf Done.
  20. root@VM-888:~#
某浙江联通100Mbps:
  3. [  4] local 192.168.*.* port 49098 connected to 23.94.*.* port 5201
  5. [  4]   0.00-1.00   sec   451 KBytes  3.69 Mbits/sec    2   58.0 KBytes
  6. [  4]   1.00-2.00   sec  2.63 MBytes  22.0 Mbits/sec    0    332 KBytes
  7. [  4]   2.00-3.00   sec  2.75 MBytes  23.1 Mbits/sec    0   2.60 MBytes
  8. [  4]   3.00-4.00   sec  8.01 MBytes  67.1 Mbits/sec  106   2.95 MBytes
  9. [  4]   4.00-5.00   sec  6.02 MBytes  50.5 Mbits/sec  555   8.15 MBytes
  10. [  4]   5.00-6.00   sec  10.9 MBytes  91.3 Mbits/sec    0   8.15 MBytes
  11. [  4]   6.00-7.00   sec  5.43 MBytes  45.6 Mbits/sec  600   4.32 MBytes
  12. [  4]   7.00-8.00   sec  5.38 MBytes  45.1 Mbits/sec  563   4.07 MBytes
  13. [  4]   8.00-9.00   sec  5.54 MBytes  46.5 Mbits/sec  575   2.86 MBytes
  14. [  4]   9.00-10.00  sec  4.98 MBytes  41.8 Mbits/sec  703   3.87 MBytes
  17. [  4]   0.00-10.00  sec  52.1 MBytes  43.7 Mbits/sec  3104             sender
  18. [  4]   0.00-10.00  sec  50.9 MBytes  42.7 Mbits/sec                  receiver
  19. iperf Done.
  20. root@VM-888:~#
某江苏联通100Mbps:
  3. [  4] local 192.168.*.* port 48826 connected to 23.94.*.* port 5201
  5. [  4]   0.00-1.00   sec   163 KBytes  1.33 Mbits/sec    0   62.2 KBytes
  6. [  4]   1.00-2.00   sec  2.54 MBytes  21.3 Mbits/sec    0    498 KBytes
  7. [  4]   2.00-3.00   sec  4.53 MBytes  37.9 Mbits/sec    2   3.87 MBytes
  8. [  4]   3.00-4.00   sec  10.9 MBytes  91.2 Mbits/sec    0   7.90 MBytes
  9. [  4]   4.00-5.00   sec  8.17 MBytes  68.6 Mbits/sec   17   7.90 MBytes
  10. [  4]   5.00-6.00   sec  7.16 MBytes  60.1 Mbits/sec    0   7.90 MBytes
  11. [  4]   6.00-7.00   sec  8.41 MBytes  70.5 Mbits/sec    0   7.90 MBytes
  12. [  4]   7.00-8.00   sec  8.46 MBytes  71.0 Mbits/sec    0   7.90 MBytes
  13. [  4]   8.00-9.00   sec  8.40 MBytes  70.5 Mbits/sec    0   7.90 MBytes
  14. [  4]   9.00-10.00  sec  8.64 MBytes  72.5 Mbits/sec    1   7.94 MBytes
  17. [  4]   0.00-10.00  sec  67.3 MBytes  56.5 Mbits/sec   20             sender
  18. [  4]   0.00-10.00  sec  66.1 MBytes  55.4 Mbits/sec                  receiver
  19. iperf Done.
  20. root@VM-888:~#
同-某江苏联通300Mbps:
  3. [  4] local 192.168.*.* port 46456 connected to 23.94.*.* port 5201
  5. [  4]   0.00-1.00   sec   358 KBytes  2.93 Mbits/sec    0   41.0 KBytes
  6. [  4]   1.00-2.00   sec  2.11 MBytes  17.7 Mbits/sec    0    264 KBytes
  7. [  4]   2.00-3.00   sec  2.98 MBytes  25.0 Mbits/sec    0   1.89 MBytes
  8. [  4]   3.00-4.00   sec  8.16 MBytes  68.5 Mbits/sec    0   8.16 MBytes
  9. [  4]   4.00-5.00   sec  9.48 MBytes  79.5 Mbits/sec    0   8.24 MBytes
  10. [  4]   5.00-6.00   sec  8.86 MBytes  74.3 Mbits/sec    1   8.24 MBytes
  11. [  4]   6.00-7.00   sec  9.54 MBytes  80.0 Mbits/sec    0   8.24 MBytes
  12. [  4]   7.00-8.00   sec  9.29 MBytes  78.0 Mbits/sec    1   8.24 MBytes
  13. [  4]   8.00-9.00   sec  8.73 MBytes  73.2 Mbits/sec    1   2.65 MBytes
  14. [  4]   9.00-10.00  sec  6.09 MBytes  51.1 Mbits/sec    1   8.24 MBytes
  17. [  4]   0.00-10.00  sec  65.6 MBytes  55.0 Mbits/sec    4             sender
  18. [  4]   0.00-10.00  sec  63.6 MBytes  53.3 Mbits/sec                  receiver
  19. iperf Done.
  20. root@VM-888:~#
发表于 2021-11-29 22:17:59 | 只看该作者
骗我买大水牛,你打错主意了
发表于 2021-11-29 22:21:53 | 只看该作者
Virtual server not found
发表于 2021-11-29 22:18:44 | 只看该作者
水牛能拿来当梯子?
发表于 2021-11-29 22:19:51 | 只看该作者
这个闪购可真是闪,一直是水牛城就没停下过
发表于 2021-11-29 22:20:08 | 只看该作者
 楼主| 发表于 2021-11-29 22:20:28 | 只看该作者
探针的价格   奔着便宜买的,也就这样了
发表于 2021-11-29 22:20:39 | 只看该作者
大水牛不适合当梯子,只适合挂程序
 楼主| 发表于 2021-11-29 22:25:18 | 只看该作者
直接进控制管理面板  - vps control panel
https://solusvm.virmach.com/home.php
GMT+8, 2026-4-14 18:40 , Processed in 0.065095 second(s), 11 queries , Gzip On, MemCache On.
