查看: 3872|回复: 25
绿云新加坡大盘鸡BFStorageSG-1 95刀3年款测试(补充三网回程)
发表于 2021-11-27 09:46:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
套餐配置:
  1. BFStorageSG-1:
  2. Singapore DC1 Datacenter
  3. 2048MB RAM
  4. 2048MB SWAP
  5. 500GB SATA RAID-10 HDD
  6. 1 core CPU
  7. 1 IPv4 IP
  8. 3TB Bandwidth
  9. 1Gbps Port
  10. Linux OS
  11. KVM SolusVM Control Panel
  12. No refund/money back on this plan. Double RAM + Storage for Triennial payments.
三网测速:
流媒体:
bench.sh:
yabs.sh
  1. Basic System Information:
  3. Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  4. CPU cores  : 1 @ 2599.996 MHz
  5. AES-NI     : ✔ Enabled
  6. VM-x/AMD-V : ❌ Disabled
  7. RAM        : 3.9 GiB
  8. Swap       : 0.0 KiB
  9. Disk       : 985.1 GiB
  10. fio Disk Speed Tests (Mixed R/W 50/50):
  11. ---------------------------------
  12. Block Size | 4k            (IOPS) | 64k           (IOPS)
  13.   ------   | ---            ----  | ----           ----
  14. Read       | 14.43 MB/s    (3.6k) | 135.38 MB/s   (2.1k)
  15. Write      | 14.44 MB/s    (3.6k) | 136.09 MB/s   (2.1k)
  16. Total      | 28.88 MB/s    (7.2k) | 271.47 MB/s   (4.2k)
  17.            |                      |
  18. Block Size | 512k          (IOPS) | 1m            (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 457.42 MB/s    (893) | 492.73 MB/s    (481)
  21. Write      | 481.73 MB/s    (940) | 525.54 MB/s    (513)
  22. Total      | 939.16 MB/s   (1.8k) | 1.01 GB/s      (994)
  23. iperf3 Network Speed Tests (IPv4):
  25. Provider        | Location (Link)           | Send Speed      | Recv Speed
  26.                 |                           |                 |
  27. Clouvider       | London, UK (10G)          | 334 Mbits/sec   | 150 Mbits/sec
  28. Online.net      | Paris, FR (10G)           | 265 Mbits/sec   | 110 Mbits/sec
  29. WorldStream     | The Netherlands (10G)     | busy            | busy
  30. WebHorizon      | Singapore (1G)            | 714 Mbits/sec   | 459 Mbits/sec
  31. Clouvider       | NYC, NY, US (10G)         | 308 Mbits/sec   | 134 Mbits/sec
  32. Velocity Online | Tallahassee, FL, US (10G) | 234 Mbits/sec   | 71.4 Mbits/sec
  33. Clouvider       | Los Angeles, CA, US (10G) | 324 Mbits/sec   | 107 Mbits/sec
  34. Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 73.4 Mbits/sec
  35. Geekbench 5 Benchmark Test:
  36. ---------------------------------
  37. Test            | Value
  38.                 |
  39. Single Core     | 666
  40. Multi Core      | 693
  41. Full Test       | https://browser.geekbench.com/v5/cpu/11241011
2021-11-27 16:11:03 补一下三网回程
电信:
联通:
移动:
发表于 2021-11-27 10:26:19 | 只看该作者
正如论坛大神所说DC2比DC1的还垃圾点。。
 楼主| 发表于 2021-11-27 10:34:32 | 只看该作者
之前忘了说了,大盘鸡都是DC1机房的,昨天那一批(包括这只)好像都是只能看美区的奈飞。电信ping爆表,想出国必须套中转;联通不套中转勉强能用。
发表于 2021-11-27 10:47:14 | 只看该作者
moue 发表于 2021-11-27 10:34
之前忘了说了,大盘鸡都是DC1机房的,昨天那一批(包括这只)好像都是只能看美区的奈飞。电信ping爆表, ...
是啊。。。DC2的也不咋地。
发表于 2021-11-27 11:40:36 来自手机 | 只看该作者
我也有一个,想出掉……不知道会不会有人要
 楼主| 发表于 2021-11-27 11:43:33 | 只看该作者
关键是只能看美区奈飞,这一点就让我的心凉半截;DC2奈飞正常但没看到大盘鸡
发表于 2021-11-27 11:45:16 | 只看该作者
联通和移动好像还挺友好的,电信基本不用看,
发表于 2021-11-27 11:46:46 | 只看该作者
我的新加坡大盘鸡怎么跟你们不一样?DC1机房,95刀三年,磁盘容量1T的,内存4G,但不能解锁奈飞
IP是96开头的,看起来像广播IP
这种可以付费换IP么
发表于 2021-11-27 11:46:51 | 只看该作者
买个套路云不香吗?
GMT+8, 2026-5-1 21:16 , Processed in 0.064801 second(s), 10 queries , Gzip On, MemCache On.
