查看: 6611|回复: 38
[不限流量] naranja的48欧 4H8G160G 还凑合吧
发表于 2021-11-27 00:06:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  3. #                     v2021-10-09                    #
  6. Fri 26 Nov 2021 10:53:37 AM EST
  7. Basic System Information:
  9. Processor  : AMD EPYC 7351 16-Core Processor
  10. CPU cores  : 4 [url=home.php?mod=space&uid=175]@[/url] 2399.996 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ❌ Disabled
  13. RAM        : 7.8 GiB
  14. Swap       : 1023.0 MiB
  15. Disk       : 156.5 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 106.64 MB/s  (26.6k) | 794.39 MB/s  (12.4k)
  21. Write      | 106.92 MB/s  (26.7k) | 798.57 MB/s  (12.4k)
  22. Total      | 213.56 MB/s  (53.3k) | 1.59 GB/s    (24.8k)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 1.19 GB/s     (2.3k) | 1.19 GB/s     (1.1k)
  27. Write      | 1.25 GB/s     (2.4k) | 1.27 GB/s     (1.2k)
  28. Total      | 2.44 GB/s     (4.7k) | 2.47 GB/s     (2.4k)
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 907 Mbits/sec   | 931 Mbits/sec
  34. Online.net      | Paris, FR (10G)           | busy            | busy
  35. WorldStream     | The Netherlands (10G)     | 906 Mbits/sec   | 935 Mbits/sec
  36. WebHorizon      | Singapore (1G)            | 455 Mbits/sec   | 562 Mbits/sec
  37. Clouvider       | NYC, NY, US (10G)         | 887 Mbits/sec   | 573 Mbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 837 Mbits/sec   | 618 Mbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 833 Mbits/sec   | 599 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 482 Mbits/sec   | 570 Mbits/sec
  41. iperf3 Network Speed Tests (IPv6):
  43. Provider        | Location (Link)           | Send Speed      | Recv Speed
  44.                 |                           |                 |
  45. Clouvider       | London, UK (10G)          | 898 Mbits/sec   | 881 Mbits/sec
  46. Online.net      | Paris, FR (10G)           | 902 Mbits/sec   | 877 Mbits/sec
  47. WorldStream     | The Netherlands (10G)     | 887 Mbits/sec   | 891 Mbits/sec
  48. WebHorizon      | Singapore (1G)            | 349 Mbits/sec   | 466 Mbits/sec
  49. Clouvider       | NYC, NY, US (10G)         | 870 Mbits/sec   | 716 Mbits/sec
  50. Clouvider       | Los Angeles, CA, US (10G) | 820 Mbits/sec   | 742 Mbits/sec
  51. Geekbench 5 Benchmark Test:
  52. ---------------------------------
  53. Test            | Value
  54.                 |
  55. Single Core     | 549
  56. Multi Core      | 1781
  57. Full Test       | https://browser.geekbench.com/v5/cpu/11238398
  1. -> System Information
  2. OS Release:                Debian GNU/Linux "Buster" 10.0 (x86_64)
  3. CPU Model:                AMD EPYC 7351 16-Core Processor  2.40 GHz
  4. CPU Cache Size:        512 KB
  5. CPU Number:                4 vCPU
  6. Virt Type:                KVM
  7. Memory Usage:                111.69 MB / 7.79 GB
  8. Swap Usage:                0 KB / 1023.00 MB
  9. Boot Device:                /dev/vda1
  10. Disk Usage:                1.04 GB / 164.10 GB
  11. CPU Usage:                0.0% used, 0.0% iowait, 0.0% steal
  12. Load (1/5/15min):        0.20 0.30 0.31
  13. Uptime:                0 Days, 0 Hours, 28 Minutes, 37 Seconds
  14. Kernel Version:        4.19.0-5-amd64
  15. Network CC Method:        cubic + pfifo_fast
  16. -> Network Infomation
  17. IPV4 - IP Address:        [NL] 185.213.x.x
  18. IPV4 - ASN Info:        AS41608 (NextGenWebs-NL - NextGenWebs, S.L., ES)
  19. IPV4 - Region:                Netherlands Flevoland Dronten
  20. -> Media Unlock Test
  21. HBO Now:                                No
  22. Bahamut Anime:                                No
  23. Abema.TV:                                Yes
  24. Princess Connect Re:Dive Japan:        Yes
  25. BBC:                                        No
  26. BiliBili China Mainland Only:                No
  27. BiliBili Hongkong/Macau/Taiwan:        No
  28. Bilibili Taiwan Only:                        No
  29. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  30. 1 Thread Test:                 1256 Scores
  31. 4 Threads Test:                 4521 Scores
  32. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  33. 1 Thread - Read Test :                32306.85 MB/s
  34. 1 Thread - Write Test:                13409.35 MB/s
  35. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  36. Test Name                Write Speed                                Read Speed
  37. 100MB-4K Block                9.4 MB/s (2287 IOPS, 11.19s)                7.1 MB/s (1741 IOPS, 14.70s)
  38. 1GB-1M Block                425 MB/s (404 IOPS, 2.47s)                534 MB/s (509 IOPS, 1.96s)
  39. -> Speedtest.net Network Speed Test
  40. Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
  41. Speedtest Default                109.08 MB/s        105.98 MB/s        0.60 ms                Weserve B.V. (Netherlands Dronten)
  42. China, Beijing CU                  Fail: Timeout Exceeded after 60 seconds
  43. China, Shanghai CT                 0.16 MB/s        95.21 MB/s        238.70 ms        China Telecom (China Shanghai)
  44. China, Hangzhou CM                 27.85 MB/s        101.92 MB/s        264.68 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
  45. -> Traceroute Test (IPV4)
  46. Traceroute to China, Beijing CU (TCP Mode, Max 30 Hop)
  47. ============================================================
  48. traceroute to 123.125.99.1 (123.125.99.1), 30 hops max, 32 byte packets
  49. 1  5.2.71.2  0.79 ms  AS60404  Netherlands, Flevoland, Dronten, liteserver.nl
  50. 2  45.83.173.3  1.73 ms  AS42156  Netherlands, North Holland, Amsterdam, netnova.nl
  51. 3  195.22.213.198  1.73 ms  AS6762  Netherlands, North Holland, Amsterdam, tisparkle.com
  52. 4  89.221.35.144  166.18 ms  AS6762  United States, California, Los Angeles, tisparkle.com
  53. 5  219.158.40.49  226.04 ms  AS4837  United States, California, Los Angeles, ChinaUnicom
  54. 6  219.158.16.97  221.83 ms  AS4837  China, Beijing, ChinaUnicom
  55. 7  219.158.9.218  236.47 ms  AS4837  China, Beijing, ChinaUnicom
  56. 8  *
  57. 9  *
  58. 10  221.219.202.246  211.91 ms  AS4808  China, Beijing, ChinaUnicom
  59. 11  124.65.194.134  234.57 ms  AS4808  China, Beijing, ChinaUnicom
  60. 12  61.135.113.158  234.39 ms  AS4808  China, Beijing, ChinaUnicom
  61. 13  *
  62. 14  123.125.99.1  227.76 ms  AS4808  China, Beijing, ChinaUnicom
  63. Traceroute to China, Beijing CT (TCP Mode, Max 30 Hop)
  64. ============================================================
  65. traceroute to 180.149.128.9 (180.149.128.9), 30 hops max, 32 byte packets
  66. 1  5.2.71.2  1.65 ms  AS60404  Netherlands, Flevoland, Dronten, liteserver.nl
  67. 2  45.83.173.3  1.67 ms  AS42156  Netherlands, North Holland, Amsterdam, netnova.nl
  68. 3  195.22.213.198  1.64 ms  AS6762  Netherlands, North Holland, Amsterdam, tisparkle.com
  69. 4  89.221.40.141  159.32 ms  AS6762  United States, California, Los Angeles, tisparkle.com
  70. 5  218.30.54.176  150.73 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
  71. 6  202.97.93.137  216.61 ms  AS4134  China, ChinaTelecom
  72. 7  202.97.12.73  233.49 ms  AS4134  China, Beijing, ChinaTelecom
  73. 8  202.97.53.21  295.93 ms  AS4134  China, Beijing, ChinaTelecom
  74. 9  *
  75. 10  36.110.246.198  289.30 ms  AS23724  China, Beijing, ChinaTelecom
  76. 11  *
  77. 12  180.149.128.9  269.93 ms  AS23724  China, Beijing, ChinaTelecom
  78. Traceroute to China, Beijing CM (TCP Mode, Max 30 Hop)
  79. ============================================================
  80. traceroute to 211.136.25.153 (211.136.25.153), 30 hops max, 32 byte packets
  81. 1  5.2.71.2  0.55 ms  AS60404  Netherlands, Flevoland, Dronten, liteserver.nl
  82. 2  45.83.173.3  3.49 ms  AS42156  Netherlands, North Holland, Amsterdam, netnova.nl
  83. 3  213.207.9.115  2.89 ms  AS24785  Netherlands, openpeering.nl
  84. 4  217.170.0.250  12.49 ms  AS24785  United Kingdom, London, openpeering.nl
  85. 5  195.66.226.5  12.25 ms  AS8553  United Kingdom, London, linx.net
  86. 6  223.120.10.81  13.75 ms  AS58453  United Kingdom, London, ChinaMobile
  87. 7  223.120.10.1  12.53 ms  AS58453  United Kingdom, London, ChinaMobile
  88. 8  *
  89. 9  *
  90. 10  *
  91. 11  *
  92. 12  111.24.17.105  409.04 ms  AS9808  China, Beijing, ChinaMobile
  93. 13  111.24.14.54  411.95 ms  AS9808  China, Beijing, ChinaMobile
  94. 14  211.136.67.106  404.27 ms  AS56048  China, Beijing, ChinaMobile
  95. 15  211.136.63.66  445.38 ms  AS56048  China, Beijing, ChinaMobile
  96. 16  211.136.95.226  469.93 ms  AS56048  China, Beijing, ChinaMobile
  97. 17  211.136.95.226  467.05 ms  AS56048  China, Beijing, ChinaMobile
  98. 18  *
  99. 19  211.136.25.153  459.82 ms  AS56048  China, Beijing, ChinaMobile
发表于 2021-11-27 00:09:47 | 只看该作者
在荷兰鸡的水平里算一般
发表于 2021-11-27 00:08:25 | 只看该作者
页面打开空白,人麻了
发表于 2021-11-27 00:09:42 | 只看该作者
价格多少的
 楼主| 发表于 2021-11-27 00:10:34 | 只看该作者
48欧 刚才打漏了
 楼主| 发表于 2021-11-27 00:11:40 | 只看该作者
Anoneko 发表于 2021-11-27 00:09
在荷兰鸡的水平里算一般
之前想买过,今天有幸捡到一个
 楼主| 发表于 2021-11-27 00:12:47 | 只看该作者
不知道还有没有,有兴趣的话可以找找。
发表于 2021-11-27 00:15:15 | 只看该作者
发表于 2021-11-27 00:16:16 | 只看该作者
Mr.Qin 发表于 2021-11-26 08:15
#              Yet-Another-Bench-Script       ...
这是9欧的吧
GMT+8, 2026-4-28 04:52 , Processed in 0.073849 second(s), 11 queries , Gzip On, MemCache On.
