查看: 1915|回复: 9
我跟大家 一样 配不上ks的 ipv6
发表于 2021-11-26 16:22:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
于是我 看了一下ks的  debian11 官方安装的配置文件,配个ipv6 至于吗。。。。
auto lo
iface lo inet loopback
auto eno1
iface eno1 inet dhcp
    accept_ra 0
# control-alias eno1
iface eno1 inet6 static
    address xxxxxxxxxxxxxxxx:8da1::1/56
    dns-nameservers xxxxx:xxx:3:163::1
    gateway xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8d00::/57 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8d00::/57 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8d80::/59 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8d80::/59 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dc0::/59 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dc0::/59 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8db0::/60 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8db0::/60 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8de0::/60 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8de0::/60 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da8::/61 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da8::/61 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8df0::/61 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8df0::/61 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da4::/62 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da4::/62 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8df8::/62 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8df8::/62 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da2::/63 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da2::/63 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dfc::/63 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dfc::/63 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da0::/64 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da0::/64 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dfe::/64 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dfe::/64 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da1:8000::/65 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da1:8000::/65 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dff:8000::/65 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dff:8000::/65 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da1:4000::/66 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da1:4000::/66 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dff:4000::/66 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dff:4000::/66 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8da1:2000::/67 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8da1:2000::/67 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    post-up route add -A inet6 xxxxxxxxxxxxxxxx:8dff:2000::/67 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
    pre-down route del -A inet6 xxxxxxxxxxxxxxxx:8dff:2000::/67 gw xxxxxxxxxxxxxxxx:8dff:ff:ff:ff:ff || true
........ 还有很长
发表于 2021-11-26 16:52:59 | 只看该作者
配这么多有用吗?
发表于 2021-11-26 16:24:43 | 只看该作者
我晕。。。是这么配吗
发表于 2021-11-26 16:27:17 来自手机 | 只看该作者
怎么会这么长
发表于 2021-11-26 16:33:35 来自手机 | 只看该作者
一二个足够了,都是一根网线
发表于 2021-11-26 16:35:38 | 只看该作者
我记得有大佬 会写教程 不知道写完没有
 楼主| 发表于 2021-11-26 17:26:19 | 只看该作者
foboy 发表于 2021-11-26 16:59
没这么复杂。我已经在我博客写了教程
  pm 下 大佬博客
签名貌似都不是?
发表于 2021-11-26 17:30:43 | 只看该作者
iface eth0 inet6 static
    address xxxx:xxxx:xxxx:xx:/56
    dns-nameservers 2001:4860:4860::8888 2606:4700:4700::1111
    up ip -6 route add [ipv6 gateway] dev eth0
    up ip -6 route add default via [ipv6 gateway]
/56是你可用的地址池,其实没啥意义,你要几个地址就几条address就行。如果把/56改成和网关相同prefix的话(一般是48或64),两条route都可以省了,直接一条gateway [ipv6网关就行]
发表于 2021-11-26 19:55:17 | 只看该作者
我DD了win2019,发现没有ipv6,没DD钱也没看ipv6,现在还有办法吗?另外现在在后台也不能重装了,报错。
发表于 2021-11-28 00:00:07 | 只看该作者
GMT+8, 2026-4-14 19:16 , Processed in 0.062572 second(s), 11 queries , Gzip On, MemCache On.
