查看: 5574|回复: 24
绿云 越南6刀机评测
发表于 2021-11-20 21:05:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
流媒体:
  1. -- Japan --
  2. Abema.TV:                              No
  3. Niconico:                              Yes
  4. Paravi:                                No
  5. U-NEXT:                                No
  6. Hulu Japan:                            No
  7. Fuji TV:                               No
  8. Radiko:                                No
  9. DMM:                                   Yes
  10. Princess Connect Re:Dive Japan:        Yes
  11. Pretty Derby Japan:                    No
  12. Kancolle Japan:                        No
  13. ErogameScape:                          Yes
  14. -- Korea --
  15. Tving:                                 No
  16. KakaoTV:                               Yes
  17. -- United States --
  18. Hulu United States:                    ->/dev/fd/63: line 701: warning: command substitution: ignored null byte in input
  19. parse error: Invalid numeric literal at line 1, column 48
  20. Hulu United States:                    Yes
  21. HBO Now:                               No
  22. HBO Max:                               No
  23. Paramount+:                            No
  24. Peacock TV:                            No
  25. Sling TV:                              No
  26. Pluto TV:                              No
  27. encoreTVB:                             No
  28. ABC:                                   No
  29. -- Europe --
  30. BritBox:                               No
  31. ITV Hub:                               No
  32. Channel 4:                             No
  33. BBC iPLAYER:                           No
  34. Molotov:                               No
  35. -- ** --
  36. Biguz:                                 Yes
  37. Blacked:                               Yes
  38. -- Global --
  39. DAZN:                                  No
  40. Netflix:                               Only Homemade
  41. DisneyPlus:                            No
  42. 有图比:                               No Premium(Region: VN)
  43. Amazon Prime Video:                    Yes(Region: VN)
  44. Tiktok:                                Failed
  45. iQiyi Global:                          Yes(Region: VN)
  46. Viu.com:                               No
  47. Steam:                                 Yes(Currency: VND)
io&网速
  1. CPU Model             : Intel(R) Xeon(R) CPU E5-2690 0 [url=home.php?mod=space&uid=175]@[/url] 2.90GHz
  2. CPU Cores             : 1
  3. CPU Frequency         : 2899.998 MHz
  4. CPU Cache             : 16384 KB
  5. Total Disk            : 14.0 GB (1.6 GB Used)
  6. Total Mem             : 976 MB (72 MB Used)
  7. Total Swap            : 1023 MB (1 MB Used)
  8. System uptime         : 0 days, 0 hour 8 min
  9. Load average          : 0.04, 0.23, 0.15
  10. OS                    : Debian GNU/Linux 11
  11. Arch                  : x86_64 (64 Bit)
  12. Kernel                : 5.10.0-8-amd64
  13. TCP CC                : bbr
  14. Virtualization        : KVM
  15. Organization          : AS63734 365 Online technology joint stock company
  16. Location              : Ho Chi Minh City / VN
  17. Region                : Ho Chi Minh
  18. ----------------------------------------------------------------------
  19. I/O Speed(1st run)    : 327 MB/s
  20. I/O Speed(2nd run)    : 600 MB/s
  21. I/O Speed(3rd run)    : 521 MB/s
  22. Average I/O speed     : 482.7 MB/s
  23. ----------------------------------------------------------------------
  24. Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    8.59 Mbps         634.59 Mbps         68.61 ms
  26. Shanghai   CT    9.11 Mbps         511.15 Mbps         221.79 ms
  27. Shanghai   CU    5.20 Mbps         6.92 Mbps           310.82 ms
  28. Guangzhou  CT    2.86 Mbps         83.81 Mbps          206.52 ms
  29. Guangzhou  CU    10.78 Mbps        585.69 Mbps         58.98 ms
  30. Hongkong   CN    11.91 Mbps        602.24 Mbps         97.87 ms
  31. Tokyo      JP    9.29 Mbps         659.09 Mbps         83.00 ms
  32. ----------------------------------------------------------------------
  33. root@GreenCloud:~#
  1. [Info] 测试路由 到 上海电信(天翼云) 中 ...
  2. traceroute to 101.227.255.45 (101.227.255.45), 30 hops max, 60 byte packets
  3. 1  103.199.16.1  3.50 ms  AS63734  http: 403
  4. 2  171.244.2.57  0.74 ms  AS38731  http: 403
  5. 3  171.244.2.201  0.72 ms  AS38731  http: 403
  6. 4  171.244.131.185  1.88 ms  AS38731  http: 403
  7. 5  203.113.156.199  2.03 ms  AS7552  http: 403
  8. 6  localhost (27.68.229.101)  24.41 ms  AS7552  http: 403
  9. 7  localhost (27.68.228.118)  26.01 ms  AS7552  http: 403
  10. 8  localhost (27.68.240.10)  25.47 ms  AS7552  http: 403
  11. 9  te0-0-0-23.clbr01.hkg04.pccwbtn.net (63.216.84.65)  48.39 ms  AS3491,AS31713  http: 403
  12. 10  HundredGE0-6-0-0.br04.sjo01.pccwbtn.net (63.223.60.58)  200.00 ms  AS3491,AS31713  http: 403
  13. 11  HundredGE0-6-0-0.br04.sjo01.pccwbtn.net (63.223.60.58)  198.64 ms  AS3491,AS31713  http: 403
  14. 12  218.30.53.84  195.21 ms  AS4134  http: error
  15. 13  202.97.89.134  336.31 ms  AS4134  http: 403
  16. 14  202.97.12.185  376.66 ms  AS4134  http: 403
  17. 15  202.97.24.141  369.06 ms  AS4134  http: 403
  18. 16  *
  19. 17  *
  20. 18  *
  21. 19  *
  22. 20  *
  23. 21  *
  24. 22  *
  25. 23  *
  26. 24  *
  27. 25  *
  28. 26  *
  29. 27  *
  30. 28  *
  31. 29  *
  32. 30  *
  33. [Info] 测试路由 到 上海电信(天翼云) 完成 !
  34. [Info] 测试路由 到 厦门电信CN2 中 ...
  35. traceroute to 117.28.254.129 (117.28.254.129), 30 hops max, 60 byte packets
  36. 1  103.199.16.1  1.83 ms  AS63734  http: 403
  37. 2  171.244.2.57  0.57 ms  AS38731  http: 403
  38. 3  171.244.2.205  0.62 ms  AS38731  http: 403
  39. 4  171.244.2.237  1.79 ms  AS38731  http: 403
  40. 5  203.113.156.197  1.10 ms  AS7552  http: 403
  41. 6  *
  42. 7  *
  43. 8  ae-8.r26.tkokhk01.hk.bb.gin.ntt.net (129.250.6.99)  25.18 ms  AS2914  http: 403
  44. 9  ae-2.a00.chwahk02.hk.bb.gin.ntt.net (129.250.6.121)  25.23 ms  http: error  http: 403
  45. 10  xe-0-0-21-2.a00.chwahk02.hk.ce.gin.ntt.net (203.131.241.66)  21.37 ms  AS2914  http: 403
  46. 11  59.43.248.249  56.10 ms  *  http: 403
  47. 12  *
  48. 13  59.43.130.153  30.81 ms  *  http: 403
  49. 14  59.43.46.214  51.73 ms  *  http: 403
  50. 15  *
  51. 16  *
  52. 17  117.25.141.106  233.78 ms  AS133775  http: 403
  53. 18  117.28.254.129  46.90 ms  AS4809  http: 403
  54. [Info] 测试路由 到 厦门电信CN2 完成 !
  55. [Info] 测试路由 到 浙江杭州联通 中 ...
  56. traceroute to 101.71.241.238 (101.71.241.238), 30 hops max, 60 byte packets
  57. 1  103.199.16.1  3.14 ms  AS63734  http: 403
  58. 2  171.244.2.57  0.65 ms  AS38731  http: 403
  59. 3  171.244.2.205  0.61 ms  AS38731  http: 403
  60. 4  171.244.2.233  1.48 ms  AS38731  http: 403
  61. 5  203.113.156.199  1.76 ms  AS7552  http: error
  62. 6  *
  63. 7  localhost (27.68.229.242)  1.15 ms  AS7552  http: 403
  64. 8  ae-8.r26.tkokhk01.hk.bb.gin.ntt.net (129.250.6.99)  35.22 ms  AS2914  http: error
  65. 9  ae-0.r27.tkokhk01.hk.bb.gin.ntt.net (129.250.5.29)  24.08 ms  AS2914  http: 403
  66. 10  ae-4.r26.osakjp02.jp.bb.gin.ntt.net (129.250.2.42)  101.40 ms  AS2914  http: 403
  67. 11  ae-5.r30.tokyjp05.jp.bb.gin.ntt.net (129.250.7.78)  121.62 ms  AS2914  http: 403
  68. 12  ae-2.r03.tokyjp05.jp.bb.gin.ntt.net (129.250.3.33)  110.77 ms  AS2914  http: 403
  69. 13  219.158.40.177  337.42 ms  AS4837  http: 403
  70. 14  219.158.8.185  333.48 ms  AS4837  http: 403
  71. 15  219.158.7.133  341.14 ms  AS4837  http: 403
  72. 16  219.158.115.146  343.04 ms  AS4837  http: 403
  73. 17  101.69.245.206  339.67 ms  AS4837  http: error
  74. 18  *
  75. 19  *
  76. 20  *
  77. 21  *
  78. 22  *
  79. 23  *
  80. 24  *
  81. 25  *
  82. 26  *
  83. 27  *
  84. 28  *
  85. 29  *
  86. 30  *
  87. [Info] 测试路由 到 浙江杭州联通 完成 !
  88. [Info] 测试路由 到 浙江杭州移动 中 ...
  89. traceroute to 112.17.0.106 (112.17.0.106), 30 hops max, 60 byte packets
  90. 1  103.199.16.1  1.28 ms  AS63734  http: 403
  91. 2  171.244.2.57  0.53 ms  AS38731  http: 403
  92. 3  171.244.2.201  0.73 ms  AS38731  http: 403
  93. 4  171.244.2.225  0.79 ms  AS38731  http: error
  94. 5  localhost (27.68.225.17)  1.37 ms  AS7552  http: 403
  95. 6  localhost (27.68.229.145)  22.41 ms  AS7552  http: 403
  96. 7  localhost (27.68.228.118)  24.86 ms  AS7552  http: 403
  97. 8  localhost (27.68.240.98)  22.03 ms  AS7552  http: 403
  98. 9  localhost (27.68.240.198)  22.41 ms  AS7552  http: 403
  99. 10  xe-2-2-3-xcr1.hke.cw.net (195.89.113.21)  22.33 ms  AS1273  http: 403
  100. 11  ae4-xcr1.hkg.cw.net (195.2.10.97)  25.61 ms  AS1273  http: 403
  101. 12  ae0-xcr1.sng.cw.net (195.2.30.65)  53.55 ms  AS1273  http: 403
  102. 13  223.121.2.61  62.56 ms  AS58453  http: 403
  103. 14  223.120.2.17  84.28 ms  AS58453  http: 403
  104. 15  223.120.2.14  317.10 ms  AS58453  http: 403
  105. 16  223.120.22.5  342.51 ms  AS58453  http: 403
  106. 17  221.183.55.34  342.20 ms  AS9808  http: 403
  107. 18  221.183.25.193  343.88 ms  AS9808  http: error
  108. 19  221.176.22.13  344.00 ms  AS9808  http: 403
  109. 20  111.24.17.61  343.34 ms  AS9808  http: 403
  110. 21  221.183.10.6  121.12 ms  AS9808  http: 403
  111. 22  *
  112. 23  211.140.4.74  122.58 ms  AS56041  http: 403
  113. 24  218.205.87.13  122.54 ms  AS56041  http: 403
  114. 25  *
  115. 26  *
  116. 27  *
  117. 28  *
  118. 29  *
  119. 30  *
  120. [Info] 测试路由 到 浙江杭州移动 完成 !
  121. [Info] 测试路由 到 北京教育网 中 ...
  122. traceroute to 202.205.6.30 (202.205.6.30), 30 hops max, 60 byte packets
  123. 1  103.199.16.1  1.65 ms  AS63734  http: 403
  124. 2  171.244.2.57  0.42 ms  AS38731  http: 403
  125. 3  171.244.2.205  0.58 ms  AS38731  http: 403
  126. 4  171.244.2.233  1.57 ms  AS38731  http: 403
  127. 5  localhost (27.68.225.21)  1.95 ms  AS7552  http: 403
  128. 6  localhost (27.68.229.105)  22.69 ms  AS7552  http: 403
  129. 7  localhost (27.68.240.166)  21.35 ms  AS7552  http: error
  130. 8  101.4.114.181  217.71 ms  AS4538  http: 403
  131. 9  101.4.114.221  198.23 ms  AS4538  http: 520
  132. 10  101.4.115.113  195.35 ms  AS4538  http: 403
  133. 11  101.4.118.213  198.97 ms  AS4538  http: 403
  134. 12  101.4.113.110  197.11 ms  AS4538  http: 520
  135. 13  219.224.102.230  197.41 ms  AS4538  http: 403
  136. 14  *
  137. 15  *
  138. 16  *
  139. 17  *
  140. 18  *
  141. 19  *
  142. 20  101.4.130.54  199.56 ms  AS133111  http: 403
  143. 21  *
  144. 22  *
  145. 23  101.4.130.53  197.66 ms  AS133111  http: 403
  146. 24  *
  147. 25  *
  148. 26  *
  149. 27  *
  150. 28  *
  151. 29  *
  152. 30  *
  153. [Info] 测试路由 到 北京教育网 完成 !
  154. [Info] 四网路由快速测试 已完成 !
  155. root@GreenCloud:~# ^C
  156. root@GreenCloud:~#
发表于 2021-11-20 21:06:31 | 只看该作者
上越南了啊
发表于 2021-11-20 21:07:18 | 只看该作者
绕路了?回程怎么样
发表于 2021-11-20 21:07:23 | 只看该作者
这是要深度挖掘绿云
 楼主| 发表于 2021-11-20 21:08:05 | 只看该作者
朋友业务需要 买了个顺便测试一下
发表于 2021-11-20 21:08:26 | 只看该作者
富强靠越南,泪目了
 楼主| 发表于 2021-11-20 21:09:56 | 只看该作者
irony 发表于 2021-11-20 21:08
富强靠越南,泪目了
不是啊 朋友在国外要用越南的
 楼主| 发表于 2021-11-20 21:14:54 | 只看该作者
my2468 发表于 2021-11-20 21:07
绕路了?回程怎么样
有脚本吗 我去跑一下看看
发表于 2021-11-20 23:19:10 | 只看该作者
wget https://raw.githubusercontent.com/nanqinlang-script/testrace/master/testrace.sh
bash testrace.sh
 楼主| 发表于 2021-11-20 23:27:37 | 只看该作者
bash testrace.s ...
  18. 16  *
  19. 17  *
  20. 18  *
  21. 19  *
  22. 20  *
  23. 21  *
  24. 22  *
  25. 23  *
  26. 24  *
  27. 25  *
  28. 26  *
  29. 27  *
  30. 28  *
  31. 29  *
  32. 30  *
  41. 6  *
  42. 7  *
  47. 12  *
  50. 15  *
  51. 16  *
  62. 6  *
  74. 18  *
  75. 19  *
  76. 20  *
  77. 21  *
  78. 22  *
  79. 23  *
  80. 24  *
  81. 25  *
  82. 26  *
  83. 27  *
  84. 28  *
  85. 29  *
  86. 30  *
  111. 22  *
  114. 25  *
  115. 26  *
  116. 27  *
  117. 28  *
  118. 29  *
  119. 30  *
  136. 14  *
  137. 15  *
  138. 16  *
  139. 17  *
  140. 18  *
  141. 19  *
  143. 21  *
  144. 22  *
  146. 24  *
  147. 25  *
  148. 26  *
  149. 27  *
  150. 28  *
  151. 29  *
  152. 30  *
GMT+8, 2026-4-24 21:27 , Processed in 0.073651 second(s), 10 queries , Gzip On, MemCache On.
