查看: 3604|回复: 14
有越南的商家推荐吗
发表于 2021-11-20 20:04:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VNPT 真不错还能解锁奈飞
流媒体解锁:
  1. -- Japan --
  2. Abema.TV:                              Only overseas
  3. Niconico:                              Yes
  4. Paravi:                                No
  5. U-NEXT:                                No
  6. Hulu Japan:                            No
  7. Fuji TV:                               No
  8. Radiko:                                No
  9. DMM:                                   Yes
  10. Princess Connect Re:Dive Japan:        Yes
  11. Pretty Derby Japan:                    Yes
  12. Kancolle Japan:                        No
  13. ErogameScape:                          Yes
  14. -- Korea --
  15. Tving:                                 No
  16. KakaoTV:                               Yes
  17. -- United States --
  18. Hulu United States:                    ->/dev/fd/63: line 701: warning: command substitution: ignored null byte in input
  19. parse error: Invalid numeric literal at line 1, column 48
  20. Hulu United States:                    Yes
  21. HBO Now:                               No
  22. HBO Max:                               No
  23. Paramount+:                            No
  24. Peacock TV:                            No
  25. Sling TV:                              No
  26. Pluto TV:                              No
  27. encoreTVB:                             No
  28. ABC:                                   No
  29. -- Europe --
  30. BritBox:                               No
  31. ITV Hub:                               No
  32. Channel 4:                             No
  33. BBC iPLAYER:                           No
  34. Molotov:                               No
  35. -- ** --
  36. Biguz:                                 Yes
  37. Blacked:                               Yes
  38. -- Global --
  39. DAZN:                                  Yes(Region: VN)
  40. Netflix:                               Yes(Region: VN)
  41. DisneyPlus:                            No
  42. 有图比:                               No Premium(Region: VN)
  43. Amazon Prime Video:                    Yes(Region: VN)
  44. Tiktok:                                Yes(Region: VN)
  45. iQiyi Global:                          Yes(Region: VN)
  46. Viu.com:                               No
  47. Steam:                                 Yes(Currency: VND)
  1. CPU Model             : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
  2. CPU Cores             : 1
  3. CPU Frequency         : 2999.986 MHz
  4. CPU Cache             : 16384 KB
  5. Total Disk            : 20.0 GB (1.1 GB Used)
  6. Total Mem             : 989 MB (53 MB Used)
  7. Total Swap            : 0 MB (0 MB Used)
  8. System uptime         : 0 days, 0 hour 11 min
  9. Load average          : 0.00, 0.08, 0.05
  10. OS                    : Debian GNU/Linux 10
  11. Arch                  : x86_64 (64 Bit)
  12. Kernel                : 4.19.0-17-cloud-amd64
  13. TCP CC                : bbr
  14. Virtualization        : KVM
  15. Organization          : AS135905 VIETNAM POSTS AND TELECOMMUNICATIONS GROUP
  16. Location              : Hanoi / VN
  17. Region                : Hanoi
  18. ----------------------------------------------------------------------
  19. I/O Speed(1st run)    : 255 MB/s
  20. I/O Speed(2nd run)    : 247 MB/s
  21. I/O Speed(3rd run)    : 145 MB/s
  22. Average I/O speed     : 215.7 MB/s
  23. ----------------------------------------------------------------------
  24. Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    99.86 Mbps        95.85 Mbps          0.28 ms
  26. Shanghai   CT    31.46 Mbps        11.82 Mbps          423.92 ms
  27. Shanghai   CU    11.96 Mbps        32.33 Mbps          224.90 ms
  28. Guangzhou  CT    4.41 Mbps         13.09 Mbps          261.82 ms
  29. Guangzhou  CU    23.97 Mbps        15.71 Mbps          456.15 ms
  30. Hongkong   CN    43.64 Mbps        19.27 Mbps          29.01 ms
  31. Tokyo      JP    42.40 Mbps        37.38 Mbps          80.14 ms
发表于 2021-11-20 21:28:44 | 只看该作者
越南 那不就是VNPT了
https://portal.vietnix.vn/clientarea.php
他们家呀,便宜不限量 (没有AFF 哼
谢谢! 这个好! 还能解锁奈飞 比绿云的便宜  发表于 2021-11-20 22:26
发表于 2021-11-20 20:08:39 | 只看该作者
快车道有越南的   4V4G 20Gssd    250M 不限流量  170刀  ,不知道贵不贵
 楼主| 发表于 2021-11-20 20:10:30 | 只看该作者
好贵哦 170刀一个月
发表于 2021-11-20 20:11:27 | 只看该作者
 楼主| 发表于 2021-11-20 20:12:57 | 只看该作者
不清楚 朋友让帮忙操作的 也不好意思问
发表于 2021-11-20 20:21:49 | 只看该作者
不该问的不要问,选这种小地方有啥业务还不清楚吗
发表于 2021-11-20 20:25:14 | 只看该作者
买个新加坡的吧
绿云好像有6刀月付的越南机子
 楼主| 发表于 2021-11-20 20:47:39 | 只看该作者
DogeLee2 发表于 2021-11-20 20:25
买个新加坡的吧
绿云好像有6刀月付的越南机子
朋友只需要越南的哈哈 刚刚买了台6刀的 看看他流量够不够 不够再接着买几台用了
 楼主| 发表于 2021-11-20 21:59:32 | 只看该作者
liyugui8 发表于 2021-11-20 21:28
越南 那不就是VNPT了
他们家呀,便宜不限量 (没有AFF 哼 ...
好兄弟 这个速度咋样 绿云的速度太慢了
GMT+8, 2026-4-16 20:22 , Processed in 0.066056 second(s), 12 queries , Gzip On, MemCache On.
