查看: 1469|回复: 8
248 跑分
发表于 2021-11-5 19:21:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实在是忍不住,入手了一个248,
来个跑分,感觉CPU有点猛呀,所以能干什么?
[Info] Bench Start Time: 2021-11-05 19:18:51
[Info] Test Mode: Fast Mode
-> System Information
OS Release:            Debian GNU/Linux "Buster" 10.2 (x86_64)
CPU Model:             AMD EPYC 7K62 48-Core Processor  2.60 GHz
CPU Cache Size:        512 KB
CPU Number:            2 vCPU
Virt Type:             KVM
Memory Usage:          145.48 MB / 3.73 GB
Swap Usage:            [ No Swapfile/Swap Partition ]
Boot Device:           /dev/vda1
Disk Usage:            1.45 GB / 82.50 GB
CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
Load (1/5/15min):      0.21 0.05 0.02
Uptime:                0 Days, 0 Hours, 6 Minutes, 3 Seconds
Kernel Version:        4.19.0-11-amd64
Network CC Method:     cubic + pfifo_fast
-> Network Infomation
IPV4 - IP Address:     [CN] 142.192.147.99
IPV4 - ASN Info:       AS45090 (TENCENT-NET-AP - Shenzhen Tencent Computer Systems Company Limited, CN)
IPV4 - Region:         China HeBei Langfang
-> Media Unlock Test
HBO Now:                               No
Bahamut Anime:                         No
Abema.TV:                              No
Princess Connect Reive Japan:        No
BBC:                                   No
BiliBili China Mainland Only:          Yes
BiliBili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                  No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                 1625 Scores
2 Threads Test:                1715 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :         43768.04 MB/s
1 Thread - Write Test:         19266.35 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name              Write Speed                             Read Speed
100MB-4K Block         6.8 MB/s (1664 IOPS, 15.38s)            12.3 MB/s (2993 IOPS, 8.55s)
1GB-1M Block           148 MB/s (140 IOPS, 7.10s)              149 MB/s (142 IOPS, 7.03s)
发表于 2021-11-5 19:28:16 来自手机 | 只看该作者
恭喜吃灰机喜加一
 楼主| 发表于 2021-11-5 19:24:34 | 只看该作者
等等党永不为奴
发表于 2021-11-5 19:26:40 | 只看该作者
哈哈
发表于 2021-11-5 19:28:11 | 只看该作者
我之前发过,这个脚本似乎有问题,双核那么点分
发表于 2021-11-5 19:28:40 | 只看该作者
6133 上海 表示  太惨了!!
发表于 2021-11-5 19:30:02 | 只看该作者
前两天试了下,单核1800,双核2800~~
  1. ------------------------------------------------------------------------
  2. Benchmark Run: Wed Nov 03 2021 06:01:16 - 06:29:14
  3. 2 CPUs in system; running 1 parallel copy of tests
  4. Dhrystone 2 using register variables       40515220.1 lps   (10.0 s, 7 samples)
  5. Double-Precision Whetstone                     7250.5 MWIPS (9.9 s, 7 samples)
  6. Execl Throughput                               5830.1 lps   (30.0 s, 2 samples)
  7. File Copy 1024 bufsize 2000 maxblocks       1342418.4 KBps  (30.0 s, 2 samples)
  8. File Copy 256 bufsize 500 maxblocks          370959.5 KBps  (30.0 s, 2 samples)
  9. File Copy 4096 bufsize 8000 maxblocks       3311476.6 KBps  (30.0 s, 2 samples)
  10. Pipe Throughput                             2338525.0 lps   (10.0 s, 7 samples)
  11. Pipe-based Context Switching                  55031.8 lps   (10.0 s, 7 samples)
  12. Process Creation                              13092.2 lps   (30.0 s, 2 samples)
  13. Shell Scripts (1 concurrent)                  11781.5 lpm   (60.0 s, 2 samples)
  14. Shell Scripts (8 concurrent)                   1836.3 lpm   (60.0 s, 2 samples)
  15. System Call Overhead                        3257386.7 lps   (10.0 s, 7 samples)
  16. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  17. Dhrystone 2 using register variables         116700.0   40515220.1   3471.7
  18. Double-Precision Whetstone                       55.0       7250.5   1318.3
  19. Execl Throughput                                 43.0       5830.1   1355.8
  20. File Copy 1024 bufsize 2000 maxblocks          3960.0    1342418.4   3389.9
  21. File Copy 256 bufsize 500 maxblocks            1655.0     370959.5   2241.4
  22. File Copy 4096 bufsize 8000 maxblocks          5800.0    3311476.6   5709.4
  23. Pipe Throughput                               12440.0    2338525.0   1879.8
  24. Pipe-based Context Switching                   4000.0      55031.8    137.6
  25. Process Creation                                126.0      13092.2   1039.1
  26. Shell Scripts (1 concurrent)                     42.4      11781.5   2778.7
  27. Shell Scripts (8 concurrent)                      6.0       1836.3   3060.5
  28. System Call Overhead                          15000.0    3257386.7   2171.6
  29.        ========
  30. System Benchmarks Index Score                                        1821.7
  31. ------------------------------------------------------------------------
  32. Benchmark Run: Wed Nov 03 2021 06:29:14 - 06:57:14
  33. 2 CPUs in system; running 2 parallel copies of tests
  34. Dhrystone 2 using register variables       58208689.3 lps   (10.0 s, 7 samples)
  35. Double-Precision Whetstone                    12815.8 MWIPS (9.9 s, 7 samples)
  36. Execl Throughput                               7727.8 lps   (30.0 s, 2 samples)
  37. File Copy 1024 bufsize 2000 maxblocks       1646016.4 KBps  (30.0 s, 2 samples)
  38. File Copy 256 bufsize 500 maxblocks          448432.0 KBps  (30.0 s, 2 samples)
  39. File Copy 4096 bufsize 8000 maxblocks       4506776.8 KBps  (30.0 s, 2 samples)
  40. Pipe Throughput                             2783104.0 lps   (10.0 s, 7 samples)
  41. Pipe-based Context Switching                 331650.6 lps   (10.0 s, 7 samples)
  42. Process Creation                              20700.5 lps   (30.0 s, 2 samples)
  43. Shell Scripts (1 concurrent)                  13826.3 lpm   (60.0 s, 2 samples)
  44. Shell Scripts (8 concurrent)                   2009.5 lpm   (60.0 s, 2 samples)
  45. System Call Overhead                        4393008.7 lps   (10.0 s, 7 samples)
  46. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  47. Dhrystone 2 using register variables         116700.0   58208689.3   4987.9
  48. Double-Precision Whetstone                       55.0      12815.8   2330.1
  49. Execl Throughput                                 43.0       7727.8   1797.2
  50. File Copy 1024 bufsize 2000 maxblocks          3960.0    1646016.4   4156.6
  51. File Copy 256 bufsize 500 maxblocks            1655.0     448432.0   2709.6
  52. File Copy 4096 bufsize 8000 maxblocks          5800.0    4506776.8   7770.3
  53. Pipe Throughput                               12440.0    2783104.0   2237.2
  54. Pipe-based Context Switching                   4000.0     331650.6    829.1
  55. Process Creation                                126.0      20700.5   1642.9
  56. Shell Scripts (1 concurrent)                     42.4      13826.3   3260.9
  57. Shell Scripts (8 concurrent)                      6.0       2009.5   3349.2
  58. System Call Overhead                          15000.0    4393008.7   2928.7
  59.        ========
  60. System Benchmarks Index Score                                        2738.9
  61. ======= Script description and score comparison completed! =======
 楼主| 发表于 2021-11-5 19:30:56 | 只看该作者
这个太爽了把
GMT+8, 2026-4-16 15:29 , Processed in 0.067905 second(s), 11 queries , Gzip On, MemCache On.
