查看: 3392|回复: 16
[不限流量] 绿云UK测试
发表于 2021-10-28 17:46:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pr20.21续费太恶心了,抢这个看看怎么样。
  1. -> System Information
  2. OS Release:                CentOS Linux 7.9.2009 (x86_64)
  3. CPU Model:                AMD EPYC 7502P 32-Core Processor  2.50 GHz
  4. CPU Cache Size:        512 KB
  5. CPU Number:                8 vCPU
  6. Virt Type:                KVM
  7. Memory Usage:                214.90 MB / 7.64 GB
  8. Swap Usage:                0 KB / 2.00 GB
  9. Boot Device:                /dev/vda1
  10. Disk Usage:                1.80 GB / 88.69 GB
  11. CPU Usage:                0.0% used, 0.0% iowait, 0.0% steal
  12. Load (1/5/15min):        0.09 0.07 0.08
  13. Uptime:                0 Days, 0 Hours, 14 Minutes, 31 Seconds
  14. Kernel Version:        3.10.0-862.2.3.el7.x86_64
  15. Network CC Method:        cubic + pfifo_fast
  16. -> Network Infomation
  17. IPV4 - IP Address:        [GB] xxxxx
  18. IPV4 - ASN Info:        AS42831 (UKSERVERS-AS - UK Dedicated Servers Limited, GB)
  19. IPV4 - Region:                United Kingdom West Midlands County Coventry
  20. -> Media Unlock Test
  21. HBO Now:                                Yes
  22. Bahamut Anime:                                No
  23. Abema.TV:                                No
  24. Princess Connect Re:Dive Japan:        Yes
  25. BBC:                                        Yes
  26. BiliBili China Mainland Only:                No
  27. BiliBili Hongkong/Macau/Taiwan:        No
  28. Bilibili Taiwan Only:                        No
  29. -> CPU Performance Test (Fast Mode, 1-Pass [url=home.php?mod=space&uid=175]@[/url] 5sec)
  30. 1 Thread Test:                 1652 Scores
  31. 8 Threads Test:                 13136 Scores
  32. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  33. 1 Thread - Read Test :                43323.03 MB/s
  34. 1 Thread - Write Test:                19171.07 MB/s
  35. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  36. Test Name                Write Speed                                Read Speed
  37. 100MB-4K Block                17.3 MB/s (4211 IOPS, 6.08s)                58.2 MB/s (14217 IOPS, 1.80s)
  38. 1GB-1M Block                1.9 GB/s (1839 IOPS, 0.54s)                1.9 GB/s (1792 IOPS, 0.56s)
  39. -> Speedtest.net Network Speed Test
  40. Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
  41. Speedtest Default                84.21 MB/s        106.42 MB/s        6.04 ms                Internetty Ltd (United Kingdom Stone)
  42. China, Beijing CU                  Fail: Timeout Exceeded after 60 seconds
  43. China, Shanghai CT                 0.18 MB/s        25.16 MB/s        271.20 ms        China Telecom (China Shanghai)
  44. China, Hangzhou CM                 0.07 MB/s        74.26 MB/s        336.06 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
  1. ** NetFlix 解锁检测小工具 By @sjlleo **
  2. [IPV4测试]
  3. NetFlix在您测试的出口IP所在的地区提供服务,宽松版权的自制剧可以解锁
  4. ->> 正在检查是否完整支持自制剧 <<-
  5. 支持解锁全部的自制剧
  6. ->> 正在检查支持的NetFlix地区 <<-
  7. 支持解锁非自制剧
  8. 原生IP地域解锁信息:英国区 NetFlix
发表于 2021-10-28 17:58:19 | 只看该作者
刹那 发表于 2021-10-28 17:49
没找到脚本,你发一个我测一下。
收集的一些MJJ发过的脚本:
https://www.pigji.com/399.html
发表于 2021-10-28 17:47:32 | 只看该作者
电信延迟比新加坡还低
发表于 2021-10-28 17:47:35 | 只看该作者
刹那果然抓住了未来
 楼主| 发表于 2021-10-28 17:49:00 | 只看该作者
没找到脚本,你发一个我测一下。
发表于 2021-10-28 17:49:17 来自手机 | 只看该作者
这配置,这价格,挺划算的
发表于 2021-10-28 17:49:52 | 只看该作者
膜拜能抢到的大佬
发表于 2021-10-28 17:54:14 | 只看该作者
没找到脚本,你发一个我测一下。
我就是不会才等大佬评测
GMT+8, 2026-4-27 16:44 , Processed in 0.066763 second(s), 11 queries , Gzip On, MemCache On.
