查看: 3343|回复: 7
[疑问] 英语好的来帮下忙,帮忙看下 老外给回得信啥意思
发表于 2011-11-25 17:33:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Ping reply was fine.
Perhaps it's something you installed on the VPS? No other complaints for network outages on x5.
Please check your VPS or perhaps even your internet connection to make sure it's not just an issue you're experiencing due to your connection.
Also, please do NOT open multiple tickets for the same issue as it won't yield a fast answer. One ticket is plenty.
If you require additional support regarding this issue feel free to reopen this ticket.
If you require additional support regarding a new issue please open a new ticket with a detailed description and properly addressed subject line.
Regards,
Aaron
发表于 2011-11-25 17:42:00 | 只看该作者
ping的结果是没问题的
可能是你在vps上安装了什么?没有其他人抱怨x5节点网络问题
检查你的VPS和你的网络,可能是你的网络连接导致的问题
不要开多个故障单,不会增快处理速度,一个足够
如果你对这个事件还有问题,重新开这个故障单
如果对其他事件有问题,开新的故障单,在主题栏注明详细的介绍
祝福
阿郎
 楼主| 发表于 2011-11-25 17:44:51 | 只看该作者
回复 2# jacobhere 的帖子
谢谢了
发表于 2011-11-25 17:45:01 | 只看该作者
发表于 2011-11-25 17:45:48 | 只看该作者
尼麻,跟给我的回复一样。还叫我重装操作系统。我崩溃。
发表于 2011-11-25 17:49:07 | 只看该作者
来晚了,嘿嘿
发表于 2011-11-25 18:42:50 | 只看该作者
翻译得8错
发表于 2011-11-25 19:10:41 | 只看该作者
二楼强人
GMT+8, 2026-4-24 01:24 , Processed in 0.064919 second(s), 10 queries , Gzip On, MemCache On.
