查看: 1900|回复: 10
[Windows VPS] 腾讯云清凉一键脚本安装seafile报错,求助
发表于 2021-10-18 13:07:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
腾讯云广州清凉,官方一键脚本安装seafile报错,这怎么回事呀
用过的带佬捞捞
Downloading http://mirrors.tencentyun.com/pypi/packages/36/7a/87837f39d0296e723bb9b62bbb257d0355c7f6128853c78955f57342a56d/python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
     |████████████████████████████████| 247 kB 21.3 MB/s
Building wheels for collected packages: future, mysqlclient, pylibmc, django-simple-captcha, docopt, django-ranged-response
  Building wheel for future (setup.py) ... done
  Created wheel for future: filename=future-0.18.2-py3-none-any.whl size=491058 sha256=7d9683fcf25b23f800ef67692d04e2971275f6dd65915c7428fc96d9ac5a7d9c
  Stored in directory: /root/.cache/pip/wheels/87/c2/bd/746c7f9c3aa603279a2d3b6dfc0ad5ed51f5c3a1f18358929e
  Building wheel for mysqlclient (setup.py) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-7o3wt0dg
       cwd: /tmp/pip-install-ihltv1nu/mysqlclient/
  Complete output (44 lines):
  mysql_config --version
  ['8.0.26']
  mysql_config --libs
  ['-L/usr/lib/x86_64-linux-gnu', '-lmysqlclient', '-lpthread', '-ldl', '-lz', '-lssl', '-lcrypto', '-lresolv', '-lm', '-lrt']
  mysql_config --cflags
  ['-I/usr/include/mysql']
  ext_options:
    library_dirs: ['/usr/lib/x86_64-linux-gnu']
    libraries: ['mysqlclient', 'pthread', 'dl', 'resolv', 'm', 'rt']
    extra_compile_args: ['-std=c99']
    extra_link_args: []
    include_dirs: ['/usr/include/mysql']
    extra_objects: []
    define_macros: [('version_info', "(2,0,3,'final',0)"), ('__version__', '2.0.3')]
  running bdist_wheel
  creating build/lib.linux-x86_64-3.8/MySQLdb
  creating build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/__init__.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/CLIENT.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/CR.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/ER.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/FIELD_TYPE.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  copying MySQLdb/constants/FLAG.py -> build/lib.linux-x86_64-3.8/MySQLdb/constants
  running build_ext
  building 'MySQLdb._mysql' extension
  creating build/temp.linux-x86_64-3.8
  creating build/temp.linux-x86_64-3.8/MySQLdb
  x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -Dversion_info=(2,0,3,'final',0) -D__version__=2.0.3 -I/usr/include/mysql -I/usr/include/python3.8 -c MySQLdb/_mysql.c -o build/temp.linux-x86_64-3.8/MySQLdb/_mysql.o -std=c99
  MySQLdb/_mysql.c:46:10: fatal error: Python.h: No such file or directory
     46 | #include "Python.h"
  compilation terminated.
  error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
  ERROR: Failed building wheel for mysqlclient
  Running setup.py clean for mysqlclient
  Building wheel for pylibmc (setup.py) ... error
   command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ihltv1nu/pylibmc/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ihltv1nu/pylibmc/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-riu91258
       cwd: /tmp/pip-install-ihltv1nu/pylibmc/
  Complete output (28 lines):
  /tmp/pip-install-ihltv1nu/pylibmc/setup.py:98: DeprecationWarning: 'U' mode is deprecated
    with open("README.rst", "U", encoding="utf-8") as r:
  /tmp/pip-install-ihltv1nu/pylibmc/setup.py:100: DeprecationWarning: 'U' mode is deprecated
    with open("src/pylibmc-version.h", "U", encoding="utf-8") as r:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/autoconf.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/test.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/__main__.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/pools.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/client.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/__init__.py -> build/lib.linux-x86_64-3.8/pylibmc
  copying src/pylibmc/consts.py -> build/lib.linux-x86_64-3.8/pylibmc
  running build_ext
  building '_pylibmc' extension
  creating build/temp.linux-x86_64-3.8/src
  x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE_ZLIB -I/usr/include/python3.8 -c src/_pylibmcmodule.c -o build/temp.linux-x86_64-3.8/src/_pylibmcmodule.o -fno-strict-aliasing -std=c99
  In file included from src/_pylibmcmodule.c:34:
  src/_pylibmcmodule.h:41:10: fatal error: Python.h: No such file or directory
     41 | #include <Python.h>
  ERROR: Failed building wheel for pylibmc
  Running setup.py clean for pylibmc
  Building wheel for django-simple-captcha (setup.py) ... done
  Created wheel for django-simple-captcha: filename=django_simple_captcha-0.5.14-py2.py3-none-any.whl size=92780 sha256=88e5073c88aef16ffc923ccb8b7df300e8f87555044cf587d71f4e8f872c09e8
  Stored in directory: /root/.cache/pip/wheels/f4/9d/0a/0469a1c0079574cbbbba4a708bcd23279fed57db14dc11580a
  Building wheel for docopt (setup.py) ... done
  Created wheel for docopt: filename=docopt-0.6.2-py2.py3-none-any.whl size=13704 sha256=a7e9c483a95204febc030582b4b36d542b93bea783bcb3937d64f05f2d41feb6
  Stored in directory: /root/.cache/pip/wheels/34/92/96/4d7b02c09b500e72de9fa9d3396a3e95e686c1a927f0b5a71f
  Building wheel for django-ranged-response (setup.py) ... done
  Created wheel for django-ranged-response: filename=django_ranged_response-0.2.0-py3-none-any.whl size=3132 sha256=c1c39e802fa16f95af6c562b8a5d9741598fb8149d864fdf8ec1591362a79ecc
  Stored in directory: /root/.cache/pip/wheels/e8/cf/04/0b1bba8074afd2e32dfcc7f803e2360f841948a287a9d46e78
Successfully built future django-simple-captcha docopt django-ranged-response
Failed to build mysqlclient pylibmc
Installing collected packages: pytz, sqlparse, django, future, mysqlclient, pymysql, Pillow, pylibmc, captcha, greenlet, sqlalchemy, numpy, tifffile, cycler, kiwisolver, pyparsing, python-dateutil, matplotlib, networkx, PyWavelets, scipy, imageio, scikit-image, docopt, aggdraw, psd-tools, django-pylibmc, django-ranged-response, django-simple-captcha
    Running setup.py install for mysqlclient ... error
     command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-yfv03l7o/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.8/mysqlclient
    ['8.0.26']
    mysql_config --libs
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ihltv1nu/mysqlclient/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-yfv03l7o/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.8/mysqlclient Check the logs for full command output.
发表于 2021-10-18 13:10:23 来自手机 | 只看该作者
重装系统吧
发表于 2021-10-18 13:10:40 来自手机 | 只看该作者
你什么都没贴,就一句报错,神人啊
发表于 2021-10-18 13:28:49 | 只看该作者
Faxlok 发表于 2021-10-18 13:10
你什么都没贴,就一句报错,神人啊
可太正常了
 楼主| 发表于 2021-10-18 13:30:20 | 只看该作者
你什么都没贴,就一句报错,神人啊
就问问看有没有相同的。我是用新的重置ubuntu 20.04 LTS ,一键脚本
起码要把脚本 报错发出来吧,不然云了个寂寞  发表于 2021-10-18 13:38
 楼主| 发表于 2021-10-18 16:44:17 | 只看该作者
有了,请看
发表于 2021-10-18 18:50:30 | 只看该作者
用什么一键脚本啊 , docker多香
 楼主| 发表于 2021-10-18 19:19:10 | 只看该作者
大喵先生 发表于 2021-10-18 18:50
用什么一键脚本啊 , docker多香
一键方便呀,结果折腾了老半天没好,我
发表于 2021-10-18 19:22:13 | 只看该作者
Luyee 发表于 2021-10-18 19:19
一键方便呀,结果折腾了老半天没好,我
docker部署seafile不比一键麻烦多少 , 一键问题多
 楼主| 发表于 2021-10-18 21:22:41 | 只看该作者
我还以为很友好,结果大失所望我擦!
GMT+8, 2026-4-30 04:42 , Processed in 0.070981 second(s), 11 queries , Gzip On, MemCache On.
