查看: 3195|回复: 10
[Windows VPS] rclone 授权时提示没用权限,大佬们咋整?
发表于 2021-10-14 11:04:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
rclone想在本地win10上获取授权码,提示没用权限,找了一圈也没找到解决方法,求助一下大佬们。
没有其他应用占用这个授权的端口。
 楼主| 发表于 2021-10-14 11:05:44 | 只看该作者
 楼主| 发表于 2021-10-14 11:10:46 | 只看该作者
大佬推荐个图床
发表于 2021-10-14 11:13:31 | 只看该作者
说清楚点
发表于 2021-10-14 11:14:19 来自手机 | 只看该作者
rclone authorize  onedrive --auth-no-open-browser
 楼主| 发表于 2021-10-14 11:14:51 | 只看该作者
执行rclone authorize "onedrive"的时候,报如下错误:
2021/10/14 11:01:27 NOTICE: Config file "C:\\Users\\lth\\AppData\\Roaming\\rclone\\rclone.conf" not found - using defaults
Error: config failed to refresh token: failed to start auth webserver: listen tcp 127.0.0.1:53682: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
Usage:
  rclone authorize [flags]
Flags:
      --auth-no-open-browser   Do not automatically open auth link in default browser
  -h, --help                   help for authorize
Use "rclone [command] --help" for more information about a command.
Use "rclone help flags" for to see the global flags.
Use "rclone help backends" for a list of supported services.
2021/10/14 11:01:27 Fatal error: config failed to refresh token: failed to start auth webserver: listen tcp 127.0.0.1:53682: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
发表于 2021-10-14 11:16:22 来自手机 | 只看该作者
https://forum.rclone.org/t/windows-10-rclone-authorize-not-working/24108
 楼主| 发表于 2021-10-14 11:18:13 | 只看该作者
这个看了,没解决。
发表于 2021-10-14 12:04:34 | 只看该作者
是不是防火墙的问题?
GMT+8, 2026-5-1 12:22 , Processed in 0.062651 second(s), 10 queries , Gzip On, MemCache On.
