查看: 1299|回复: 5
宝塔面板装了nginx php-fpm mysql如何监视这些进程并自动重启额
发表于 2021-10-13 10:38:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看了nginx 的启动命令是 /www/server/nginx/sbin/nginx -c /www/server/nginx/conf/nginx.conf
mysql的启动命令是  /www/server/mysql/bin/mysqld --basedir=/www/server/mysql --datadir=/www/server/data --plugin-dir=/www/server/mysql/lib/plugin --user=mysql --sql-mode=NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION --log-error=localhost.err --open-files-limit=65535 --pid-file=/www/server/data/localhost.pid --socket=/tmp/mysql.sock --port=3306
php-fpm只查到
master process (/www/server/php/56/etc/php-fpm.conf)
感谢楼下的解答
后来查看了下他们的释放内存代码  拿他们的代码改下就行
#!/bin/bash
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:~/bin
export PATH
#+ 宝塔释放内存脚本
endDate=`date +"%Y-%m-%d %H:%M:%S"`
log="释放内存!"
echo "★[$endDate] $log"
echo '----------------------------------------------------------------------------'
if [ -f "/etc/init.d/php-fpm-52" ];then
        /etc/init.d/php-fpm-52 reload
fi
if [ -f "/etc/init.d/php-fpm-53" ];then
        /etc/init.d/php-fpm-53 reload
fi
if [ -f "/etc/init.d/php-fpm-54" ];then
        /etc/init.d/php-fpm-54 reload
fi
if [ -f "/etc/init.d/php-fpm-55" ];then
        /etc/init.d/php-fpm-55 reload
fi
if [ -f "/etc/init.d/php-fpm-56" ];then
        /etc/init.d/php-fpm-56 reload
fi
if [ -f "/etc/init.d/php-fpm-70" ];then
        /etc/init.d/php-fpm-70 reload
fi
if [ -f "/etc/init.d/php-fpm-71" ];then
        /etc/init.d/php-fpm-71 reload
fi
if [ -f "/etc/init.d/php-fpm-72" ];then
        /etc/init.d/php-fpm-72 reload
fi
if [ -f "/etc/init.d/php-fpm-73" ];then
        /etc/init.d/php-fpm-73 reload
fi
if [ -f "/etc/init.d/php-fpm-74" ];then
        /etc/init.d/php-fpm-74 reload
fi
if [ -f "/etc/init.d/mysqld" ];then
        /etc/init.d/mysqld reload
fi
if [ -f "/etc/init.d/nginx" ];then
        /etc/init.d/nginx reload
fi
if [ -f "/etc/init.d/httpd" ];then
        /etc/init.d/httpd graceful
fi
if [ -f "/etc/init.d/pure-ftpd" ];then
        pkill -9 pure-ftpd
        sleep 0.3
        /etc/init.d/pure-ftpd start 2>/dev/null
fi
sync
sleep 2
sync
echo 3 > /proc/sys/vm/drop_caches
发表于 2021-10-13 10:42:13 | 只看该作者
计划任务里设置 释放内存脚本就会重启这三个
发表于 2021-10-13 10:43:57 | 只看该作者
shell写脚本判断进程是否存活,不活就自动执行重启
发表于 2021-10-13 10:55:06 | 只看该作者
直接用supervisor
发表于 2021-10-13 10:56:54 | 只看该作者
supervisor 直接进程守护,
发表于 2021-10-13 16:17:29 | 只看该作者
GMT+8, 2026-4-30 05:37 , Processed in 0.062866 second(s), 11 queries , Gzip On, MemCache On.
