查看: 12206|回复: 99
VirMach Ryzen 封测
发表于 2021-9-29 17:45:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
时隔了大半年,VirMach 的第一个 Ryzen 节点终于上线了!今天开始封测,给大家看看 YABS 结果:
注:由于这还只是封测,VirMach 有可能会再继续优化线路和性能
  3. #                     v2021-06-05                    #
  6. Wed Sep 29 05:11:39 EDT 2021
  7. Basic System Information:
  9. Processor  : AMD Ryzen 9 3900X 12-Core Processor
  10. CPU cores  : 3 @ 3799.998 MHz
  11. AES-NI     : ✔ Enabled
  12. VM-x/AMD-V : ❌ Disabled
  13. RAM        : 3.9 GiB
  14. Swap       : 256.0 MiB
  15. Disk       : 98.2 GiB
  16. fio Disk Speed Tests (Mixed R/W 50/50):
  17. ---------------------------------
  18. Block Size | 4k            (IOPS) | 64k           (IOPS)
  19.   ------   | ---            ----  | ----           ----
  20. Read       | 348.19 MB/s  (87.0k) | 581.49 MB/s   (9.0k)
  21. Write      | 349.11 MB/s  (87.2k) | 584.55 MB/s   (9.1k)
  22. Total      | 697.30 MB/s (174.3k) | 1.16 GB/s    (18.2k)
  23.            |                      |
  24. Block Size | 512k          (IOPS) | 1m            (IOPS)
  25.   ------   | ---            ----  | ----           ----
  26. Read       | 688.30 MB/s   (1.3k) | 722.00 MB/s    (705)
  27. Write      | 724.87 MB/s   (1.4k) | 770.09 MB/s    (752)
  28. Total      | 1.41 GB/s     (2.7k) | 1.49 GB/s     (1.4k)
  29. iperf3 Network Speed Tests (IPv4):
  30. ---------------------------------
  31. Provider        | Location (Link)           | Send Speed      | Recv Speed
  32.                 |                           |                 |
  33. Clouvider       | London, UK (10G)          | 774 Mbits/sec   | 173 Mbits/sec
  34. Online.net      | Paris, FR (10G)           | 832 Mbits/sec   | 193 Mbits/sec
  35. WorldStream     | The Netherlands (10G)     | 782 Mbits/sec   | 174 Mbits/sec
  36. Biznet          | Jakarta, Indonesia (1G)   | busy            | busy
  37. Clouvider       | NYC, NY, US (10G)         | 877 Mbits/sec   | 525 Mbits/sec
  38. Velocity Online | Tallahassee, FL, US (10G) | 898 Mbits/sec   | 582 Mbits/sec
  39. Clouvider       | Los Angeles, CA, US (10G) | 940 Mbits/sec   | 941 Mbits/sec
  40. Iveloz Telecom  | Sao Paulo, BR (2G)        | 733 Mbits/sec   | 193 Mbits/sec
  41. Geekbench 5 Benchmark Test:
  43. Test            | Value
  44.                 |
  45. Single Core     | 1368
  46. Multi Core      | 3643
  47. Full Test       | https://browser.geekbench.com/v5/cpu/10136897
ping.pe
如果你们有什么脚本想要我执行的我尽量帮你们执行,有建设性的建议也可以在下面留言
(再次声明我并不是 VirMach 的员工,有关注我在其他论坛的留言就会知道我也有对他们不满的时候)
解锁测试:
  1. ============[ Multination ]============
  2. Dazn:                                  No
  3. HotStar:                               No
  4. Disney+:                               Yes (Region: US)
  5. Netflix:                               Originals Only
  6. 有图比 Premium:                       Yes (Region: US)
  7. Amazon Prime Video:                    Yes (Region: US)
  8. TVBAnywhere+:                          Yes
  9. Tiktok Region:                         US (IDC IP Detected)
  10. iQyi Oversea Region:                   US
  11. Viu.com:                               No
  12. 有图比 CDN:                           Amsterdam
  13. Netflix Preferred CDN:                 Los Angeles
  14. Steam Currency:                        USD
  15. =======================================
  16. ===========[ North America ]===========
  17. FOX:                                   Yes
  18. Hulu:                                  No
  19. Epix:                                  No
  20. Starz:                                 No
  21. HBO Now:                               Yes
  22. HBO Max:                               Yes
  23. BritBox:                               Yes
  24. NBA TV:                                Yes
  25. Fubo TV:                               Yes
  26. Sling TV:                              Yes
  27. Pluto TV:                              Yes
  28. SHOWTIME:                              Yes
  29. AT&T NOW:                              Yes
  30. encoreTVB:                             Yes
  31. CineMax Go:                            Yes
  32. Paramount+:                            Yes
  33. Peacock TV:                            Yes
  34. CBC Gem:                               No
  35. Acorn TV:                              Yes
  36. Crave:                                 Failed (Network Connection)
  37. =======================================
发表于 2021-9-29 17:50:54 | 只看该作者
不是员工 几年不上LOC   。特意跑过来帮VIR通知下
太热心了 应该颁个奖
cherbim 该用户已被删除
发表于 2021-9-29 17:47:33 | 只看该作者
发表于 2021-9-30 21:11:29 来自手机 | 只看该作者
 楼主| 发表于 2021-9-30 20:55:13 | 只看该作者
FranzkafkaYu 发表于 2021-9-29 23:31
楼主您好,想问一下黑五有什么重磅活动吗?作为LET社区管理员,有没有什么内部消息可以透露吗 ...
也不算内幕消息,今年有可能会和去年一样办个多商家闪购吧,希望你们能多多支持
 楼主| 发表于 2021-9-29 20:38:35 | 只看该作者
kenutu 发表于 2021-9-29 20:23
我就想知道kvm和kvm lite的区别,都是自己测试出来的,所以想听听官方怎么说 ...
基本上 kvm lite 无法要求特别 ISO 或安装 Win,硬盘大小需要自己扩充,差不多就这样的限制而已
发表于 2021-9-29 20:23:46 | 只看该作者
发表于 2021-9-29 18:56:51 | 只看该作者
商家用AMD用NVME和最终用户有个毛的关系。
对商家来说,才是真的重要,以前1台母鸡可以开200个,那现在就开400个。
MJJ总是不明白这个道理。
 楼主| 发表于 2021-9-29 17:57:49 | 只看该作者
太热心了 应该颁个奖
唉,我对 VirMach 就是又爱又恨,有时候回复要几个月,但活动的时候又很疯狂,但我还是对他努力提供便宜小鸡的精神给感动了
我一开始也不看好他们能有 Ryzen,但等了那么久终于开始封测了
发表于 2021-9-29 17:50:08 | 只看该作者
cherbim 发表于 2021-9-29 17:47
请帮我问问vir为什么4核跑分才300多
而且我的还是18年黑五kvm,不是kvm lite
所以说vir性价比最高的机器就是1核 ,   以后上按摩店情况不知道会不会好点
发表于 2021-9-29 17:47:24 | 只看该作者
沙发
发表于 2021-9-29 17:48:49 | 只看该作者
好家伙,这么拉可还行
正常,VIR的多核看看就好  发表于 2021-9-29 18:18
发表于 2021-9-29 17:49:04 来自手机 | 只看该作者
黑五有生之年能免费搬迁吗
发表于 2021-9-29 17:49:18 | 只看该作者
前排沙发
发表于 2021-9-29 17:51:10 | 只看该作者
什么时候搬迁amd?
GMT+8, 2026-4-19 00:59 , Processed in 0.070023 second(s), 11 queries , Gzip On, MemCache On.
