查看: 1747|回复: 6
[不限流量] deepvm 简单评测
发表于 2021-9-22 22:14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
迁移了之后配置升级了,简单测试下。
  1. [Info] Bench Start Time: 2021-09-22 22:08:40
  2. [Info] Test Mode: Fast Mode
  3. -> System Information
  4. OS Release:                CentOS Linux 7.6.1810 (x86_64)
  5. CPU Model:                Intel(R) Xeon(R) CPU E5-2660 v3 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz  2.60 GHz
  6. CPU Cache Size:        16384 KB
  7. CPU Number:                1 vCPU
  8. VirtReady:                Yes (Nested Virtualization)
  9. Virt Type:                KVM
  10. Memory Usage:                79.61 MB / 991.11 MB
  11. Swap Usage:                [ No Swapfile/Swap Partition ]
  12. Boot Device:                /dev/vda1
  13. Disk Usage:                1.32 GB / 20.58 GB
  14. CPU Usage:                0.0% used, 0.0% iowait, 0.0% steal
  15. Load (1/5/15min):        0.10 0.14 0.25
  16. Uptime:                0 Days, 9 Hours, 18 Minutes, 4 Seconds
  17. Kernel Version:        3.10.0-957.el7.x86_64
  18. Network CC Method:        cubic + pfifo_fast
  19. -> Network Infomation
  20. IPV4 - ASN Info:        AS201106 (SPARTANHOST - Spartan Host Ltd, GB)
  21. IPV4 - Region:                United States Washington Seattle
  22. -> Media Unlock Test
  23. HBO Now:                                Yes
  24. Bahamut Anime:                                No
  25. Abema.TV:                                No
  26. Princess Connect Re:Dive Japan:        Yes
  27. BBC:                                        Yes
  28. BiliBili China Mainland Only:                No
  29. BiliBili Hongkong/Macau/Taiwan:        No
  30. Bilibili Taiwan Only:                        No
  31. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  32. 1 Thread Test:                 781 Scores
  33. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  34. 1 Thread - Read Test :                17936.63 MB/s
  35. 1 Thread - Write Test:                12883.42 MB/s
  36. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  37. Test Name                Write Speed                                Read Speed
  38. 100MB-4K Block                30.1 MB/s (7357 IOPS, 3.48s)                45.2 MB/s (11029 IOPS, 2.32s)
  39. 1GB-1M Block                707 MB/s (673 IOPS, 1.48s)                1.0 GB/s (989 IOPS, 1.01s)
  40. -> Speedtest.net Network Speed Test
  41. Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
  42. Speedtest Default                227.43 MB/s        208.60 MB/s        5.34 ms                Netprotect (United States Seattle, WA)
  43. China, Beijing CU                  Fail: Timeout Exceeded after 60 seconds
  44. China, Shanghai CT                 42.79 MB/s        66.03 MB/s        153.18 ms        China Telecom (China Shanghai)
  45. China, Hangzhou CM                 5.40 MB/s        133.58 MB/s        227.69 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
发表于 2021-9-22 22:26:52 | 只看该作者
测评都没有回程,不专业
发表于 2021-9-22 22:27:42 | 只看该作者
发表于 2021-9-22 22:28:49 | 只看该作者
和kurun的2刀比怎么样
 楼主| 发表于 2021-9-22 23:22:02 | 只看该作者
zxxx 发表于 2021-9-22 22:28
和kurun的2刀比怎么样
我没有kurun的2刀
发表于 2021-9-22 23:23:50 来自手机 | 只看该作者
如果能稳定,倒也是还可以的价格了
 楼主| 发表于 2021-9-22 23:49:28 | 只看该作者
诡谲 发表于 2021-9-22 23:23
如果能稳定,倒也是还可以的价格了
感觉还行,先用着看看吧,新商家,希望稳定吧
GMT+8, 2026-4-26 08:52 , Processed in 0.068904 second(s), 10 queries , Gzip On, MemCache On.
