查看: 2973|回复: 12
Virmach 10刀脚本娱乐测试
发表于 2021-9-22 09:34:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我购买的区域为:Seattle,购买链接:https://billing.virmach.com/cart.php?a=add&pid=20  优惠码:LEB83BF2018
使用的一键脚本:
  1. wget git.io/vpstest && bash vpstest
[首先测试的是bench.sh:
  1. ----------------------------------------------------------------------
  2. CPU Model             : Intel(R) Xeon(R) CPU E5-2670 v2 [url=home.php?mod=space&uid=175]@[/url] 2.50GHz
  3. CPU Cores             : 2
  4. CPU Frequency         : 2499.998 MHz
  5. CPU Cache             : 4096 KB
  6. Total Disk            : 40.0 GB (2.1 GB Used)
  7. Total Mem             : 1997 MB (111 MB Used)
  8. Total Swap            : 255 MB (0 MB Used)
  9. System uptime         : 0 days, 0 hour 3 min
  10. Load average          : 0.01, 0.05, 0.02
  11. OS                    : CentOS Linux release 7.9.2009 (Core)
  12. Arch                  : x86_64 (64 Bit)
  13. Kernel                : 4.9.215-36.el7.x86_64
  14. TCP CC                : bbr
  15. Virtualization        : KVM
  16. Organization          : AS36352 ColoCrossing
  17. Location              : Seattle / US
  18. Region                : Washington
  19. ----------------------------------------------------------------------
  20. I/O Speed(1st run)    : 327 MB/s
  21. I/O Speed(2nd run)    : 786 MB/s
  22. I/O Speed(3rd run)    : 845 MB/s
  23. Average I/O speed     : 652.7 MB/s
  24. ----------------------------------------------------------------------
  25. Node Name        Upload Speed      Download Speed      Latency
  26. Speedtest.net    1726.30 Mbps      879.25 Mbps         0.42 ms
  27. Shanghai   CT    304.14 Mbps       680.01 Mbps         161.58 ms
  28. Shanghai   CU    475.91 Mbps       616.96 Mbps         169.39 ms
  29. Guangzhou  CT    319.75 Mbps       11.69 Mbps          183.71 ms
  30. Guangzhou  CU    434.51 Mbps       616.20 Mbps         192.42 ms
  31. Hongkong   CN    438.29 Mbps       712.93 Mbps         186.29 ms
  32. Singapore  SG    422.81 Mbps       483.33 Mbps         192.46 ms
  33. Tokyo      JP    275.41 Mbps       5.38 Mbps           100.85 ms
  34. ----------------------------------------------------------------------
然后测试的是LemonBench:
  1. [Info] Bench Start Time: 2021-09-21 21:17:14
  2. [Info] Test Mode: Fast Mode
  3. -> System Information
  4. OS Release:            CentOS Linux 7.9.2009 (x86_64)
  5. CPU Model:             Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz  2.50 GHz
  6. CPU Cache Size:        4096 KB
  7. CPU Number:            2 vCPU
  8. Virt Type:             KVM
  9. Memory Usage:          139.88 MB / 1.95 GB
  10. Swap Usage:            0 KB / 256.00 MB
  11. Boot Device:           /dev/vda1
  12. Disk Usage:            2.18 GB / 40.99 GB
  13. CPU Usage:             8.6% used, 0.0% iowait, 0.0% steal
  14. Load (1/5/15min):      0.43 0.24 0.11
  15. Uptime:                0 Days, 0 Hours, 9 Minutes, 28 Seconds
  16. Kernel Version:        4.9.215-36.el7.x86_64
  17. Network CC Method:     bbr + fq
  18. -> Network Infomation
  19. IPV4 - IP Address:     [US] 192.3.251.*
  20. IPV4 - ASN Info:       AS36352 (AS-COLOCROSSING - ColoCrossing, US)
  21. IPV4 - Region:         United States Washington Seattle
  22. -> Media Unlock Test
  23. HBO Now:                               Yes
  24. Bahamut Anime:                         No
  25. Abema.TV:                              No
  26. Princess Connect Re:Dive Japan:        Yes
  27. BBC:                                   No
  28. BiliBili China Mainland Only:          No
  29. BiliBili Hongkong/Macau/Taiwan:        No
  30. Bilibili Taiwan Only:                  No
  31. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  32. 1 Thread Test:                 648 Scores
  33. 2 Threads Test:                1200 Scores
  34. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  35. 1 Thread - Read Test :         13146.64 MB/s
  36. 1 Thread - Write Test:         10944.59 MB/s
  37. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  38. Test Name              Write Speed                             Read Speed
  39. 100MB-4K Block         20.8 MB/s (5078 IOPS, 5.04s)            23.2 MB/秒 (5674 IOPS, 4.51s)
  40. 1GB-1M Block           992 MB/s (945 IOPS, 1.06s)              830 MB/秒 (791 IOPS, 1.26s)
  41. -> Speedtest.net Network Speed Test
  42. Node Name                      Upload Speed    Download Speed  Ping Latency    Server Name
  43. Speedtest Default              200.58 MB/s     105.74 MB/s     0.46 ms         Wowrack (United States Seattle, WA)
  44. China, Beijing CU              Fail: Timeout Exceeded after 60 seconds
  45. China, Shanghai CT             37.19 MB/s      64.15 MB/s      170.80 ms       China Telecom (China Shanghai)
  46. China, Hangzhou CM             0.73 MB/s       62.44 MB/s      273.96 ms       China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
  47. -> Traceroute Test (IPV4)
  48. Traceroute to China, Beijing CU (TCP Mode, Max 30 Hop)
  49. ============================================================
  50. traceroute to 123.125.99.1 (123.125.99.1), 30 hops max, 32 byte packets
  51. 1  10.6.0.121  1.16 ms  *  LAN Address
  52. 2  10.6.0.89  0.92 ms  *  LAN Address
  53. 3  216.176.187.113  0.47 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  54. 4  216.244.88.178  0.57 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  55. 5  216.244.88.171  0.44 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  56. 6  62.115.32.142  0.81 ms  AS1299  United States, Washington, Seattle, telia.com
  57. 7  *
  58. 8  123.125.99.1  192.58 ms  AS4808  China, Beijing, ChinaUnicom
  59. Traceroute to China, Beijing CT (TCP Mode, Max 30 Hop)
  60. ============================================================
  61. traceroute to 180.149.128.9 (180.149.128.9), 30 hops max, 32 byte packets
  62. 1  10.6.0.121  1.19 ms  *  LAN Address
  63. 2  10.6.0.197  1.02 ms  *  LAN Address
  64. 3  216.176.187.113  0.46 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  65. 4  216.244.88.178  0.54 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  66. 5  38.142.48.25  1.44 ms  AS174  United States, Washington, Seattle, cogentco.com
  67. 6  154.54.86.105  19.70 ms  AS174  United States, California, San Francisco, cogentco.com
  68. 7  218.30.54.181  24.97 ms  AS4134  United States, California, San Jose, ChinaTelecom
  69. 8  202.97.51.194  162.48 ms  AS4134  China, Beijing, ChinaTelecom
  70. 9  202.97.51.194  159.52 ms  AS4134  China, Beijing, ChinaTelecom
  71. 10  *
  72. 11  180.149.159.10  179.80 ms  AS23724  China, Beijing, ChinaTelecom
  73. 12  *
  74. 13  180.149.128.9  175.77 ms  AS23724  China, Beijing, ChinaTelecom
  75. Traceroute to China, Beijing CM (TCP Mode, Max 30 Hop)
  76. ============================================================
  77. traceroute to 211.136.25.153 (211.136.25.153), 30 hops max, 32 byte packets
  78. 1  10.6.0.121  2.51 ms  *  LAN Address
  79. 2  10.6.0.197  0.88 ms  *  LAN Address
  80. 3  216.244.87.217  0.54 ms  AS27323  United States, Washington, Seattle, wowtechnologiesinc.com
  81. 4  216.244.88.178  15.12 ms  AS23033  United States, Washington, Seattle, wowtechnologiesinc.com
  82. 5  38.142.48.25  1.19 ms  AS174  United States, Washington, Seattle, cogentco.com
  83. 6  62.115.118.169  23.56 ms  AS1299  United States, California, San Jose, telia.com
  84. 7  62.115.171.215  22.49 ms  AS1299  United States, California, San Jose, telia.com
  85. 8  223.120.6.69  22.23 ms  AS58453  United States, California, San Jose, ChinaMobile
  86. 9  *
  87. 10  *
  88. 11  223.120.6.217  84.70 ms  AS58453  United States, California, Los Angeles, ChinaMobile
  89. 12  *
  90. 13  *
  91. 14  111.24.3.18  306.98 ms  AS9808  China, Beijing, ChinaMobile
  92. 15  *
  93. 16  211.136.67.166  304.19 ms  AS56048  China, Beijing, ChinaMobile
  94. 17  *
  95. 18  *
  96. 19  *
  97. 20  *
  98. 21  *
  99. 22  211.136.25.153  303.92 ms  AS56048  China, Beijing, ChinaMobile
最后再来个yabs.sh:
  1. 2021年 09月 21日 星期二 21:22:03 EDT
  2. Basic System Information:
  3. ---------------------------------
  4. Processor  : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
  5. CPU cores  : 2 @ 2499.998 MHz
  6. AES-NI     : ✔ Enabled
  7. VM-x/AMD-V : ❌ Disabled
  8. RAM        : 1.9 GiB
  9. Swap       : 256.0 MiB
  10. Disk       : 39.1 GiB
  11. fio Disk Speed Tests (Mixed R/W 50/50):
  12. ---------------------------------
  13. Block Size | 4k            (IOPS) | 64k           (IOPS)
  14.   ------   | ---            ----  | ----           ----
  15. Read       | 75.63 MB/s   (18.9k) | 487.22 MB/s   (7.6k)
  16. Write      | 75.83 MB/s   (18.9k) | 489.78 MB/s   (7.6k)
  17. Total      | 151.47 MB/s  (37.8k) | 977.00 MB/s  (15.2k)
  18.            |                      |
  19. Block Size | 512k          (IOPS) | 1m            (IOPS)
  20.   ------   | ---            ----  | ----           ----
  21. Read       | 772.35 MB/s   (1.5k) | 752.24 MB/s    (734)
  22. Write      | 813.39 MB/s   (1.5k) | 802.34 MB/s    (783)
  23. Total      | 1.58 GB/s     (3.0k) | 1.55 GB/s     (1.5k)
  24. iperf3 Network Speed Tests (IPv4):
  25. ---------------------------------
  26. Provider        | Location (Link)           | Send Speed      | Recv Speed
  27.                 |                           |                 |
  28. Clouvider       | London, UK (10G)          | 1.16 Gbits/sec  | 25.2 Mbits/sec
  29. Online.net      | Paris, FR (10G)           | 1.25 Gbits/sec  | 222 Mbits/sec
  30. WorldStream     | The Netherlands (10G)     | busy            | busy
  31. Biznet          | Jakarta, Indonesia (1G)   | busy            | busy
  32. Clouvider       | NYC, NY, US (10G)         | 1.72 Gbits/sec  | 296 Mbits/sec
  33. Velocity Online | Tallahassee, FL, US (10G) | 826 Mbits/sec   | 230 Mbits/sec
  34. Clouvider       | Los Angeles, CA, US (10G) | 1.77 Gbits/sec  | 450 Mbits/sec
  35. Iveloz Telecom  | Sao Paulo, BR (2G)        | 739 Mbits/sec   | 98.7 Mbits/sec
  36. Geekbench 5 Benchmark Test:
  37. ---------------------------------
  38. Test            | Value
  39.                 |
  40. Single Core     | 468
  41. Multi Core      | 861
  42. Full Test       | https://browser.geekbench.com/v5/cpu/9987913
发表于 2021-9-22 09:53:59 | 只看该作者
简配的 KVM,一直是心中的痛
发表于 2021-9-22 09:40:48 | 只看该作者
看着还行啊
发表于 2021-9-22 09:41:45 | 只看该作者
其实性能也不是很差
发表于 2021-9-22 09:42:37 | 只看该作者
看起来还行
发表于 2021-9-22 09:44:27 | 只看该作者
前几天买亏了
发表于 2021-9-22 09:47:15 | 只看该作者
大佬。这个是循环的扣费,还是第二年要涨的?
这价格比闪购好啊。
 楼主| 发表于 2021-9-22 09:51:22 | 只看该作者
这价格比闪购好啊。
是循环折扣
发表于 2021-9-22 09:54:03 来自手机 | 只看该作者
手里美国机太多了 白女票的 0.5刀年付的都吃灰了 让了
GMT+8, 2026-4-23 02:49 , Processed in 0.064866 second(s), 11 queries , Gzip On, MemCache On.
