查看: 2919|回复: 9
[经验] T楼所得UCVPS简单的评测
发表于 2011-11-17 21:52:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
呃。。基本上如前面两位一样,,那就再来一遍吧
DD,速度递增。。我们几个是不是凑到一块儿DD了
[root@xxoo ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 11.634 seconds, 23.1 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 9.76183 seconds, 27.5 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 8.73662 seconds, 30.7 MB/s
速度:
[root@xxoo ~]# wget http://cachefly.cachefly.net/100mb.test
--09:33:34--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test'
100%[=======================================>] 104,857,600 74.6M/s   in 1.3s
09:33:43 (74.6 MB/s) - `100mb.test' saved [104857600/104857600]
CPU:
[root@xxoo ~]# cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 30
model name      : Intel(R) Xeon(R) CPU           X3440  @ 2.53GHz
stepping        : 5
cpu MHz         : 2533.409
cache size      : 8192 KB
physical id     : 0
siblings        : 8
core id         : 0
cpu cores       : 4
apicid          : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov
pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm syscall nx rdtscp lm const
ant_tsc ida nonstop_tsc pni monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr sse4_
1 sse4_2 popcnt lahf_lm
bogomips        : 5066.81
clflush size    : 64
cache_alignment : 64
address sizes   : 36 bits physical, 48 bits virtual
power management: [8]
processor       : 1
cpu family      : 6
model           : 30
stepping        : 5
cpu MHz         : 2533.409
physical id     : 0
siblings        : 8
core id         : 1
cpu cores       : 4
apicid          : 2
fpu             : yes
fpu_exception   : yes
cpuid level     : 11
wp              : yes
bogomips        : 5066.66
clflush size    : 64
Ping: ucvps.jpg (143.48 KB, 下载次数: 6)
发表于 2011-11-17 22:30:47 | 只看该作者
什么时候T的?俺从来木有获得到过···
 楼主| 发表于 2011-11-17 21:58:41 | 只看该作者
原帖由 lazyzhu 于 2011-11-17 21:54 发表
DD,速度递增?
那你继续DD,D到1000吧
随便你怎么理解……
发表于 2011-11-17 21:56:00 | 只看该作者
亮点啊
发表于 2011-11-17 21:54:09 | 只看该作者
DD,速度递增?
那你继续DD,D到1000吧
发表于 2011-11-17 21:54:25 | 只看该作者
发表于 2011-11-17 21:54:53 | 只看该作者
发表于 2011-11-17 21:57:16 | 只看该作者
发表于 2011-11-17 22:04:20 | 只看该作者
不允许PT的哦亲。。。
参与人数 1威望 +5 收起 理由
kwx + 5 亲。。我们亲。。
发表于 2011-11-17 22:19:18 | 只看该作者
要是允许挂PT马上入手一个
GMT+8, 2026-4-16 04:33 , Processed in 0.072995 second(s), 12 queries , Gzip On, MemCache On.
