查看: 1721|回复: 5
【已出】出个Virmach新泽西6.2刀年付
发表于 2021-8-25 17:32:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
位置:新泽西(移动友好)
cpu:1核
内存:1G内存
硬盘:20G
流量:1.42T
续费:6.20美元
到期:2021.12.13
测速链接:http://107.175.37.194:9001
邮箱:带foxmail邮箱
价格:50元
Node: NYCKVM17
交易:先款
出给了@panghu
有意的话,私信我tg
发表于 2021-8-25 17:44:54 | 只看该作者
哇,你的这个好高呀
 楼主| 发表于 2021-8-25 17:40:57 | 只看该作者
lemonbench测速脚本:https://paste.ubuntu.com/p/s2ZmYg9sKb/
  1. LemonBench Linux System Benchmark Utility Version 20201005 Intl BetaVersion
  2. Bench Start Time:        2021-08-25 05:34:06
  3. Bench Finish Time:        2021-08-25 05:39:07
  4. Test Mode:                Fast Mode
  5. -> System Information
  6. OS Release:                CentOS Linux 7.9.2009 (x86_64)
  7. CPU Model:                Intel Xeon E312xx (Sandy Bridge, IBRS update)  2.50 GHz
  8. CPU Cache Size:        4096 KB
  9. CPU Number:                1 vCPU
  10. Virt Type:                KVM
  11. Memory Usage:                198.86 MB / 981.09 MB
  12. Swap Usage:                268 KB / 256.00 MB
  13. Disk Usage:                2.65 GB / 20.35 GB
  14. Boot Device:                /dev/vda1
  15. Load (1/5/15min):        0.01 0.19 0.16
  16. CPU Usage:                11.2% used, 0.0% iowait, 5.6% steal
  17. Kernel Version:        5.13.9-1.el7.elrepo.x86_64
  18. Network CC Method:        bbr + fq_pie
  19. -> Network Information
  20. IPV4 - IP Address:        [US] 107.175.37.*
  21. IPV4 - ASN Info:        36352 (AS-COLOCROSSING - ColoCrossing, US)
  22. IPV4 - Region:                United States New Jersey Piscataway Township
  23. -> Media Unlock Test
  24. HBO Now:                                Yes
  25. Bahamut Anime:                                No
  26. Abema.TV:                                No
  27. Princess Connect Re:Dive Japan:        Yes
  28. BBC:                                        No
  29. Bilibili China Mainland Only:                No
  30. Bilibili Hongkong/Macau/Taiwan:        No
  31. Bilibili Taiwan Only:                        No
  32. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  33. 1 Thread Test:                        610 Scores
  34. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  35. 1 Thread - Read Test :                12218.21 MB/s
  36. 1 Thread - Write Test:                6277.71 MB/s
  37. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  38. Test Name                Write Speed                                Read Speed
  39. 100MB-4K Block                13.4 MB/s (3280 IOPS, 7.80 s)                13.3 MB/s (3252 IOPS, 7.87 s)
  40. 1GB-1M Block                631 MB/s (602 IOPS, 1.66 s)                1.0 GB/s (999 IOPS, 1.00 s)
  41. -> Speedtest.net Network Speed Test
  42. Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
  43. Speedtest Default                91.70 MB/s        35.23 MB/s        35.49 ms        Kansas Research and Education Network (United States Wichita, KS)
  44. China, Beijing CU                  Fail: Timeout Exceeded after 60 seconds
  45. China, Shanghai CT                 27.35 MB/s        35.04 MB/s        201.75 ms        China Telecom (China Shanghai)
  46. China, Hangzhou CM                 23.56 MB/s        37.56 MB/s        281.12 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
  47. -> Traceroute Test (IPV4)
  48. Traceroute to China, Beijing CU (TCP Mode, Max 30 Hop)
  49. ============================================================
  50. traceroute to 123.125.99.1 (123.125.99.1), 30 hops max, 32 byte packets
  51. 1  10.3.0.249  0.73 ms  *  LAN Address
  52. 2  10.3.0.145  2.07 ms  *  LAN Address
  53. 3  108.61.16.81  15.74 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  54. 4  10.64.3.221  1.34 ms  *  LAN Address
  55. 5  10.64.4.217  1.10 ms  *  LAN Address
  56. 6  10.64.0.249  2.89 ms  *  LAN Address
  57. 7  *
  58. 8  *
  59. 9  219.158.96.25  216.86 ms  AS4837  China, Beijing, ChinaUnicom
  60. 10  219.158.3.145  213.82 ms  AS4837  China, Beijing, ChinaUnicom
  61. 11  *
  62. 12  *
  63. 13  61.148.7.82  209.32 ms  AS4808  China, Beijing, ChinaUnicom
  64. 14  61.148.158.102  212.31 ms  AS4808  China, Beijing, ChinaUnicom
  65. 15  61.148.158.102  212.54 ms  AS4808  China, Beijing, ChinaUnicom
  66. 16  *
  67. 17  *
  68. 18  123.125.99.1  235.75 ms  AS4808  China, Beijing, ChinaUnicom
  69. Traceroute to China, Beijing CT (TCP Mode, Max 30 Hop)
  70. ============================================================
  71. traceroute to 180.149.128.9 (180.149.128.9), 30 hops max, 32 byte packets
  72. 1  10.3.0.249  0.64 ms  *  LAN Address
  73. 2  10.3.1.213  0.94 ms  *  LAN Address
  74. 3  108.61.16.85  1.65 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  75. 4  10.64.3.221  2.07 ms  *  LAN Address
  76. 5  10.64.4.197  1.04 ms  *  LAN Address
  77. 6  10.64.0.249  19.52 ms  *  LAN Address
  78. 7  63.218.9.241  1.74 ms  AS3491,AS31713  United States, New York, New York City, pccw.com
  79. 8  63.223.54.30  7.27 ms  AS3491,AS31713  United States, Virginia, Ashburn, pccw.com
  80. 9  202.97.66.237  89.58 ms  *  United States, California, Los Angeles, ChinaTelecom
  81. 10  202.97.66.237  77.28 ms  *  United States, California, Los Angeles, ChinaTelecom
  82. 11  202.97.59.105  212.99 ms  AS4134  China, Beijing, ChinaTelecom
  83. 12  *
  84. 13  180.149.128.9  223.56 ms  AS23724  China, Beijing, ChinaTelecom
  85. Traceroute to China, Beijing CM (TCP Mode, Max 30 Hop)
  86. ============================================================
  87. traceroute to 211.136.25.153 (211.136.25.153), 30 hops max, 32 byte packets
  88. 1  10.3.0.249  1.00 ms  *  LAN Address
  89. 2  10.3.1.213  1.52 ms  *  LAN Address
  90. 3  108.61.16.85  13.28 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  91. 4  10.64.3.221  14.89 ms  *  LAN Address
  92. 5  10.64.4.217  1.25 ms  *  LAN Address
  93. 6  10.64.0.249  1.43 ms  *  LAN Address
  94. 7  223.120.7.45  70.32 ms  AS58453  United States, ChinaMobile
  95. 8  223.120.7.45  73.70 ms  AS58453  United States, ChinaMobile
  96. 9  223.120.6.49  79.20 ms  AS58453  United States, Washington, Seattle, ChinaMobile
  97. 10  *
  98. 11  *
  99. 12  *
  100. 13  111.24.2.101  248.49 ms  AS9808  China, Beijing, ChinaMobile
  101. 14  111.24.2.237  266.72 ms  AS9808  China, Beijing, ChinaMobile
  102. 15  *
  103. 16  *
  104. 17  211.136.63.66  250.43 ms  AS56048  China, Beijing, ChinaMobile
  105. 18  *
  106. 19  211.136.95.226  254.08 ms  AS56048  China, Beijing, ChinaMobile
  107. 20  *
  108. 21  211.136.25.153  250.39 ms  AS56048  China, Beijing, ChinaMobile
  109. Traceroute to China, Shanghai CU (TCP Mode, Max 30 Hop)
  110. ============================================================
  111. traceroute to 58.247.8.158 (58.247.8.158), 30 hops max, 32 byte packets
  112. 1  10.3.0.249  1.37 ms  *  LAN Address
  113. 2  10.3.1.213  4.03 ms  *  LAN Address
  114. 3  108.61.16.85  1.01 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  115. 4  10.64.3.221  24.03 ms  *  LAN Address
  116. 5  10.64.4.197  1.91 ms  *  LAN Address
  117. 6  10.64.0.249  2.25 ms  *  LAN Address
  118. 7  *
  119. 8  4.69.209.165  72.96 ms  AS3356  United States, California, San Jose, level3.com
  120. 9  4.53.208.102  245.90 ms  AS3356  United States, California, San Jose, level3.com
  121. 10  219.158.19.78  217.88 ms  AS4837  China, Shanghai, ChinaUnicom
  122. 11  219.158.19.78  213.61 ms  AS4837  China, Shanghai, ChinaUnicom
  123. 12  *
  124. 13  *
  125. 14  58.247.221.178  213.67 ms  AS17621  China, Shanghai, ChinaUnicom
  126. 15  139.226.225.22  209.59 ms  AS17621  China, Shanghai, ChinaUnicom
  127. 16  *
  128. 17  *
  129. 18  *
  130. 19  *
  131. 20  *
  132. 21  *
  133. 22  *
  134. 23  *
  135. 24  *
  136. 25  *
  137. 26  *
  138. 27  *
  139. 28  *
  140. 29  *
  141. 30  *
  142. Traceroute to China, Shanghai CT (TCP Mode, Max 30 Hop)
  143. ============================================================
  144. traceroute to 180.153.28.5 (180.153.28.5), 30 hops max, 32 byte packets
  145. 1  10.3.0.249  2.46 ms  *  LAN Address
  146. 2  10.3.0.145  0.94 ms  *  LAN Address
  147. 3  108.61.16.81  2.87 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  148. 4  10.64.3.221  3.40 ms  *  LAN Address
  149. 5  10.64.4.197  3.33 ms  *  LAN Address
  150. 6  *
  151. 7  63.218.9.241  2.16 ms  AS3491,AS31713  United States, New York, New York City, pccw.com
  152. 8  63.223.54.30  7.01 ms  AS3491,AS31713  United States, Virginia, Ashburn, pccw.com
  153. 9  4.53.210.110  79.00 ms  AS3356  United States, California, San Jose, level3.com
  154. 10  202.97.50.61  77.36 ms  AS4134  United States, California, San Jose, ChinaTelecom
  155. 11  *
  156. 12  202.97.74.2  199.76 ms  *  China, Shanghai, ChinaTelecom
  157. 13  101.95.88.81  200.63 ms  AS4812  China, Shanghai, ChinaTelecom
  158. 14  61.152.25.177  204.46 ms  AS4812  China, Shanghai, ChinaTelecom
  159. 15  124.74.232.242  205.86 ms  AS4811  China, Shanghai, ChinaTelecom
  160. 16  101.95.225.218  243.14 ms  AS4811  China, Shanghai, ChinaTelecom
  161. 17  180.153.28.5  202.11 ms  AS4812  China, Shanghai, ChinaTelecom
  162. Traceroute to China, Shanghai CM (TCP Mode, Max 30 Hop)
  163. ============================================================
  164. traceroute to 221.183.55.22 (221.183.55.22), 30 hops max, 32 byte packets
  165. 1  10.3.0.249  1.06 ms  *  LAN Address
  166. 2  10.3.0.145  0.87 ms  *  LAN Address
  167. 3  108.61.16.81  0.86 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  168. 4  10.64.3.221  1.11 ms  *  LAN Address
  169. 5  10.64.4.197  28.70 ms  *  LAN Address
  170. 6  198.32.160.230  35.08 ms  AS52320  United States, New York, New York City, nyiix.net
  171. 7  223.120.7.45  70.04 ms  AS58453  United States, ChinaMobile
  172. 8  223.120.6.13  72.85 ms  AS58453  United States, California, Los Angeles, ChinaMobile
  173. 9  223.120.6.13  73.00 ms  AS58453  United States, California, Los Angeles, ChinaMobile
  174. 10  221.183.55.22  232.28 ms  AS9808  China, Shanghai, ChinaMobile
  175. Traceroute to China, Guangzhou CU (TCP Mode, Max 30 Hop)
  176. ============================================================
  177. traceroute to 210.21.4.130 (210.21.4.130), 30 hops max, 32 byte packets
  178. 1  10.3.0.249  0.89 ms  *  LAN Address
  179. 2  10.3.0.145  0.90 ms  *  LAN Address
  180. 3  108.61.16.85  12.60 ms  AS20473  United States, New Jersey, Piscataway Township, choopa.com
  181. 4  10.64.3.221  1.09 ms  *  LAN Address
  182. 5  10.64.4.217  13.55 ms  *  LAN Address
  183. 6  10.64.0.249  9.88 ms  *  LAN Address
  184. 7  4.69.153.125  68.65 ms  AS3356  United States, California, Los Angeles, level3.com
  185. 8  4.69.153.125  70.93 ms  AS3356  United States, California, Los Angeles, level3.com
  186. 9  219.158.98.49  258.96 ms  AS4837  China, Guangdong, Guangzhou, ChinaUnicom
  187. 10  219.158.103.29  235.20 ms  AS4837  China, Guangdong, Guangzhou, ChinaUnicom
  188. 11  219.158.103.217  236.17 ms  AS4837  China, Guangdong, Guangzhou, ChinaUnicom
  189. 12  219.158.103.217  241.44 ms  AS4837  China, Guangdong, Guangzhou, ChinaUnicom
  190. 13  120.80.170.250  234.93 ms  AS17622  China, Guangdong, Guangzhou, ChinaUnicom
  191. 14  120.80.170.250  234.08 ms  AS17622  China, Guangdong, Guangzhou, ChinaUnicom
  192. Generated by LemonBench on 2021-08-25T09:39:08Z Version 20201005 Intl BetaVersion, Hosted by DMIT.IO
发表于 2021-8-25 17:59:02 | 只看该作者
看到了 不错
GMT+8, 2026-4-23 22:07 , Processed in 0.069701 second(s), 10 queries , Gzip On, MemCache On.
