查看: 8202|回复: 41
绿云新加坡20刀补货,不过INTEL Xeon Gold CPU了
发表于 2021-7-13 13:02:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Xeon10GbpsSG-1  Stock 45 Available Left 0 Available
1024MB RAM
1024MB SWAP
30GB NVMe RAID-10 SSD
1 core Xeon Gold 6132 @ 2.6GHz+ CPU
1 IPv4
/112 IPv6
1TB Bandwidth
10Gbps Port
Linux OS
Singapore DC2 Location
SolusVM Control Panel
No refund/money back on this plan Note
aff:
https://greencloudvps.com/billing/aff.php?aff=3011&pid=638
no aff:
https://greencloudvps.com/billing/cart.php?a=add&pid=638
需要的买去吧,落地鸡的话,amd和intel都够用了
电信线路绕美,差;
联通移动绕日,一般。
随机ip落地,可解锁nf。
实在不解锁说被墙要换Ip,花3刀。
测试IP:
https://greencloudvps.com/data-centers.php
SG DC2: 103.254.153.18
转自let@yoursunny
  1. Superbench.sh -- https://www.oldking.net/350.html
  2. Mode  : Standard    Version : 1.1.7
  3. Usage : wget -qO- sb.oldking.net | bash
  4. ----------------------------------------------------------------------
  5. CPU Model            : Intel(R) Xeon(R) Gold 6132 CPU @ 2.60GHz
  6. CPU Cores            : 1 Cores 2593.906 MHz x86_64
  7. CPU Cache            : 16384 KB
  8. OS                   : CentOS 7.9.2009 (64 Bit) KVM
  9. Kernel               : 3.10.0-862.2.3.el7.x86_64
  10. Total Space          : 1.8 GB / 29.0 GB
  11. Total RAM            : 79 MB / 991 MB (223 MB Buff)
  12. Total SWAP           : 3 MB / 1023 MB
  13. Uptime               : 0 days 0 hour 38 min
  14. Load Average         : 0.08, 0.11, 0.13
  15. TCP CC               : cubic
  16. ASN & ISP            : AS59253, Leaseweb Asia Pacific pte. ltd.
  17. Organization         : 365 Group LLC
  18. Location             : Osaka, Japan / JP
  19. Region               : saka
  20. ----------------------------------------------------------------------
  21. I/O Speed( 1.0GB )   : 784 MB/s
  22. I/O Speed( 1.0GB )   : 1.1 GB/s                                                              I/O Speed( 1.0GB )   : 1.1 GB/s
  23. Average I/O Speed    : 1012.3 MB/s
  24. ----------------------------------------------------------------------                        Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    6934.18 Mbit/s    3034.16 Mbit/s      0.71 ms
  26. Fast.com         0.00 Mbit/s       138.9 Mbit/s        -
  27. Nanjing 5G   CT  119.92 Mbit/s     860.15 Mbit/s       378.49 ms
  28. Hefei 5G     CT  3.38 Mbit/s       2216.98 Mbit/s      319.16 ms
  29. TianJin 5G   CU  16.48 Mbit/s      0.33 Mbit/s         239.39 ms
  30. Shanghai 5G  CU  1020.89 Mbit/s    0.44 Mbit/s         215.15 ms
  31. Guangzhou 5G CU  332.59 Mbit/s     0.36 Mbit/s         228.49 ms
  32. Tianjin 5G   CM  103.99 Mbit/s     5207.57 Mbit/s      135.24 ms
  33. Wuxi 5G      CM  139.90 Mbit/s     17.81 Mbit/s        146.79 ms
  34. Nanjing 5G   CM  1532.87 Mbit/s    178.29 Mbit/s       97.28 ms
  35. Hefei 5G     CM  206.47 Mbit/s     4989.14 Mbit/s      138.62 ms
  36. Changsha 5G  CM  549.44 Mbit/s     4240.70 Mbit/s      88.67 ms
  37. ----------------------------------------------------------------------
  38. Finished in  : 6 min 14 sec
  39. Timestamp    : 2021-07-13 13:21:16 GMT+8
  40. Results      : ./superbench.log
  41. ----------------------------------------------------------------------
  42. Share result:
  43.   https://www.speedtest.net/result/c/c241bd10-9f89-413c-bb20-c15d18422fc9
  44.   https://paste.ubuntu.com/p/J5VPg9YvMy/
  45. ----------------------------------------------------------------------
  1. [root@GreenCloud ~]# curl -sL yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2021-06-05                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Tue Jul 13 00:57:58 EDT 2021
  8. Basic System Information:
  9. ---------------------------------
  10. Processor  : Intel(R) Xeon(R) Gold 6132 CPU @ 2.60GHz
  11. CPU cores  : 1 @ 2593.906 MHz
  12. AES-NI     :  Enabled
  13. VM-x/AMD-V :  Enabled
  14. RAM        : 991.6 MiB
  15. Swap       : 1024.0 MiB
  16. Disk       : 28.5 GiB
  17. fio Disk Speed Tests (Mixed R/W 50/50):
  18. ---------------------------------
  19. Block Size | 4k            (IOPS) | 64k           (IOPS)
  20.   ------   | ---            ----  | ----           ----
  21. Read       | 284.52 MB/s  (71.1k) | 2.26 GB/s    (35.4k)
  22. Write      | 285.27 MB/s  (71.3k) | 2.28 GB/s    (35.6k)
  23. Total      | 569.79 MB/s (142.4k) | 4.54 GB/s    (71.0k)
  24.            |                      |
  25. Block Size | 512k          (IOPS) | 1m            (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 2.93 GB/s     (5.7k) | 3.52 GB/s     (3.4k)
  28. Write      | 3.08 GB/s     (6.0k) | 3.76 GB/s     (3.6k)
  29. Total      | 6.01 GB/s    (11.7k) | 7.29 GB/s     (7.1k)
  30. iperf3 Network Speed Tests (IPv4):
  31. ---------------------------------
  32. Provider        | Location (Link)           | Send Speed      | Recv Speed
  33.                 |                           |                 |
  34. Clouvider       | London, UK (10G)          | 1.03 Gbits/sec  | 992 Mbits/sec
  35. Online.net      | Paris, FR (10G)           | 1.40 Gbits/sec  | 1.15 Gbits/sec
  36. WorldStream     | The Netherlands (10G)     | 895 Mbits/sec   | 858 Mbits/sec
  37. Biznet          | Jakarta, Indonesia (1G)   | 4.22 Gbits/sec  | 5.31 Gbits/sec
  38. Clouvider       | NYC, NY, US (10G)         | 723 Mbits/sec   | 710 Mbits/sec
  39. Velocity Online | Tallahassee, FL, US (10G) | 649 Mbits/sec   | 730 Mbits/sec
  40. Clouvider       | Los Angeles, CA, US (10G) | 967 Mbits/sec   | 949 Mbits/sec
  41. Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 407 Mbits/sec
  42. iperf3 Network Speed Tests (IPv6):
  43. ---------------------------------
  44. Provider        | Location (Link)           | Send Speed      | Recv Speed
  45.                 |                           |                 |
  46. Clouvider       | London, UK (10G)          | 982 Mbits/sec   | 996 Mbits/sec
  47. Online.net      | Paris, FR (10G)           | 853 Mbits/sec   | 712 Mbits/sec
  48. WorldStream     | The Netherlands (10G)     | 992 Mbits/sec   | 1.06 Gbits/sec
  49. Clouvider       | NYC, NY, US (10G)         | 772 Mbits/sec   | 742 Mbits/sec
  50. Clouvider       | Los Angeles, CA, US (10G) | 976 Mbits/sec   | 947 Mbits/sec
  51. Geekbench 5 Benchmark Test:
  52. ---------------------------------
  53. Test            | Value
  54.                 |
  55. Single Core     | 960
  56. Multi Core      | 956
  57. Full Test       | https://browser.geekbench.com/v5/cpu/8796946
发表于 2021-7-13 13:04:42 | 只看该作者
帮顶
* 不断颠覆,不断否定
发表于 2021-7-13 13:07:15 来自手机 | 只看该作者
也给也行吧,解锁个流媒体
发表于 2021-7-13 13:09:01 | 只看该作者
能解锁什么流媒体
发表于 2021-7-13 13:18:01 来自手机 | 只看该作者
大佬们速来,能开到195的ip就赚了
发表于 2021-7-13 13:20:14 | 只看该作者
ansheng 发表于 2021-7-13 13:18
大佬们速来,能开到195的ip就赚了
什么意思
难道不是开出来所有机器都是解锁的吗
发表于 2021-7-13 13:21:34 | 只看该作者
赶紧上车吧
发表于 2021-7-13 13:22:27 来自手机 | 只看该作者
移动神器,可惜用不上,等黑五
发表于 2021-7-13 13:23:47 | 只看该作者
新加坡怎么都绕了
发表于 2021-7-13 13:24:06 来自手机 | 只看该作者
大佬们速来,能开到195的ip就赚了
195有什么优势吗
GMT+8, 2026-5-3 21:17 , Processed in 0.073117 second(s), 11 queries , Gzip On, MemCache On.
