查看: 2999|回复: 5
[不限流量] 前几天还在吹amd,今天开了一台轻量7k62发现跑分不太对劲
发表于 2021-6-7 01:17:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BYTE UNIX Benchmarks (Version 5.1.3)
   System: VM-4-15-ubuntu: GNU/Linux
   OS: GNU/Linux -- 5.4.0-72-generic -- #80-Ubuntu SMP Mon Apr 12 17:35:00 UTC 2021
   Machine: x86_64 (x86_64)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: AMD EPYC 7K62 48-Core Processor (5190.2 bogomips)
          x86-64, MMX, AMD MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
   00:41:49 up 1 min,  1 user,  load average: 2.21, 0.71, 0.25; runlevel 5
Benchmark Run: Mon Jun 07 2021 00:41:49 - 01:10:08
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       14855814.5 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3316.4 MWIPS (9.8 s, 7 samples)
Execl Throughput                               1862.2 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        372839.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          101061.8 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        944119.6 KBps  (30.0 s, 2 samples)
Pipe Throughput                              701068.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 104987.3 lps   (10.0 s, 7 samples)
Process Creation                               4551.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   2963.3 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    392.6 lpm   (60.1 s, 2 samples)
System Call Overhead                        1126477.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   14855814.5   1273.0
Double-Precision Whetstone                       55.0       3316.4    603.0
Execl Throughput                                 43.0       1862.2    433.1
File Copy 1024 bufsize 2000 maxblocks          3960.0     372839.6    941.5
File Copy 256 bufsize 500 maxblocks            1655.0     101061.8    610.6
File Copy 4096 bufsize 8000 maxblocks          5800.0     944119.6   1627.8
Pipe Throughput                               12440.0     701068.4    563.6
Pipe-based Context Switching                   4000.0     104987.3    262.5
Process Creation                                126.0       4551.1    361.2
Shell Scripts (1 concurrent)                     42.4       2963.3    698.9
Shell Scripts (8 concurrent)                      6.0        392.6    654.3
System Call Overhead                          15000.0    1126477.6    751.0
System Benchmarks Index Score                                         650.2
过年买的246单核都能上1500了,同样的机器,难道无忧故意缩水了?
发表于 2021-6-7 01:19:58 来自手机 | 只看该作者
关键词:超售
发表于 2021-6-7 01:23:40 | 只看该作者
直接退款吧,看开到超售款
 楼主| 发表于 2021-6-7 01:23:53 | 只看该作者
013 发表于 2021-6-7 01:19
关键词:超售
感觉是有邻居在挖矿擦,这u单核比6133还低我是真不信
发表于 2021-6-7 01:26:54 | 只看该作者
来,我给你开台amd yes,你能跑超过10分算你狠
发表于 2021-6-7 02:33:43 | 只看该作者
看CPU性能不够挖了
GMT+8, 2026-4-16 15:43 , Processed in 0.069957 second(s), 10 queries , Gzip On, MemCache On.
