CeraNetworks网络延迟测速工具IP归属甄别
查看: 11102|回复: 10
FDC丹佛机房这2天频繁丢包!郁闷死了!
发表于 2009-12-30 12:54:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Reply from 76.73.0.4: bytes=32 time=394ms TTL=48
Request timed out.
Reply from 76.73.0.4: bytes=32 time=393ms TTL=48
Request timed out.
Reply from 76.73.0.4: bytes=32 time=412ms TTL=48
Reply from 76.73.0.4: bytes=32 time=408ms TTL=48
Request timed out.
Reply from 76.73.0.4: bytes=32 time=406ms TTL=48
Reply from 76.73.0.4: bytes=32 time=395ms TTL=48
Reply from 76.73.0.4: bytes=32 time=401ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 76.73.0.4: bytes=32 time=404ms TTL=48
Request timed out.
Request timed out.
Reply from 76.73.0.4: bytes=32 time=402ms TTL=48
Reply from 76.73.0.4: bytes=32 time=405ms TTL=48
Reply from 76.73.0.4: bytes=32 time=413ms TTL=48
Reply from 76.73.0.4: bytes=32 time=407ms TTL=48
Reply from 76.73.0.4: bytes=32 time=409ms TTL=48
Reply from 76.73.0.4: bytes=32 time=418ms TTL=48
Reply from 76.73.0.4: bytes=32 time=414ms TTL=48
Reply from 76.73.0.4: bytes=32 time=397ms TTL=48
Request timed out.
Request timed out.
Reply from 76.73.0.4: bytes=32 time=396ms TTL=48
Request timed out.
Reply from 76.73.0.4: bytes=32 time=398ms TTL=48
 楼主| 发表于 2009-12-30 12:57:41 | 只看该作者
1    21 ms    18 ms    17 ms  58.211.79.129
  2     1 ms    <1 ms    <1 ms  61.155.129.205
  3     2 ms     1 ms     1 ms  61.155.132.117
  4     2 ms     2 ms     2 ms  61.155.132.38
  5     5 ms     5 ms     5 ms  202.97.27.101
  6     7 ms     7 ms     7 ms  202.97.39.137
  7     7 ms    15 ms     7 ms  202.97.33.66
  8    10 ms     8 ms     8 ms  202.97.34.46
  9   263 ms   265 ms   257 ms  202.97.51.78
10   372 ms     *      439 ms  te-8-1.car4.SanJose1.Level3.net [4.71.114.101]
11     *      226 ms   216 ms  vlan69.csw1.SanJose1.Level3.net [4.68.18.62]
12   195 ms   197 ms   198 ms  ae-62-62.ebr2.SanJose1.Level3.net [4.69.134.209]
13   218 ms   231 ms   220 ms  ae-3.ebr1.Denver1.Level3.net [4.69.132.58]
14   220 ms     *      235 ms  ae-11-51.car1.Denver1.Level3.net [4.68.107.6]
15     *      356 ms     *     PACKET-EXCH.car1.Denver1.Level3.net [4.53.10.106
16     *        *      364 ms  . [76.73.0.4]
Trace complete.
 楼主| 发表于 2009-12-30 12:58:22 | 只看该作者
之前我这里速度还不错,也比较稳定。
看大家说现在走Level3了?
我没注意,以前走的什么线路?
发表于 2009-12-30 13:29:51 | 只看该作者
时好时坏,现在又好了
发表于 2009-12-30 13:46:10 | 只看该作者
不单是这个机房有问题,.LP等大量存在问题。
发表于 2009-12-30 19:56:01 | 只看该作者
回复 2# 的帖子
国内ISP跟Level3线路连接不通畅。
发表于 2009-12-30 19:56:37 | 只看该作者
原帖由 jess22 于 2009-12-30 13:46 发表
基本都是国内ISP跟国外线路连接处存在的。
 楼主| 发表于 2009-12-30 21:03:54 | 只看该作者
原帖由 cpuer 于 2009-12-30 19:56 发表
我怀疑是故意的
一点问题没有。用国外的越来越多....
发表于 2009-12-30 23:07:19 | 只看该作者
回复 8# 的帖子
太多了,所以迟早是会出问题。
发表于 2010-1-1 15:34:03 | 只看该作者
這幾天..有很多家也出現掉包問題
GMT+8, 2026-4-20 21:30 , Processed in 0.066143 second(s), 10 queries , Gzip On, MemCache On.
