查看: 9442|回复: 16
求助Nginx 设置分流后,不能启动
发表于 2021-5-21 08:52:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
按教程 Nginx 设置分流后,不能启动。提示443被占用,改为4433还是被占用。
没有进程占用,用命令,宝塔安全选项,后台网络进程都没有占用。
把分流删掉,就可以启动。
自己看不出来问题,特此求助,感谢
*号为敏感字符
  1. user  www www;
  2. worker_processes auto;
  3. error_log  /www/wwwlogs/nginx_error.log  crit;
  4. pid        /www/server/nginx/logs/nginx.pid;
  5. worker_rlimit_nofile 51200;
  6. events
  7.     {
  8.         use epoll;
  9.         worker_connections 51200;
  10.         multi_accept on;
  11.     }
  12. stream {
  13.     # 这里就是 SNI 识别,将域名映射成一个配置名
  14.     map $ssl_preread_server_name $backend_name {
  15.         **30103.icu web;
  16.         rn.**30103.icu tro***;
  17.     # 域名都不匹配情况下的默认值
  18.         default web;
  19.     }
  20.     # web,配置转发详情
  21.     upstream web {
  22.         server 127.0.0.1:4433;
  23.     }
  24.     # tro***,配置转发详情
  25.     upstream tro*** {
  26.         server 127.0.0.1:1112;
  27.     }
  28.     # 监听 443 并开启 ssl_preread
  29.     server {
  30.         listen 443 reuseport;
  31.         listen [::]:443 reuseport;
  32.         proxy_pass  $backend_name;
  33.         ssl_preread on;
  34.     }
  35. }
  36. http
  37.     {
  38.         include       mime.types;
  39.                 #include luawaf.conf;
  40.                 include proxy.conf;
  41.         default_type  application/octet-stream;
  42.         server_names_hash_bucket_size 512;
  43.         client_header_buffer_size 32k;
  44.         large_client_header_buffers 4 32k;
  45.         client_max_body_size 50m;
  46.         sendfile   on;
  47.         tcp_nopush on;
  48.         keepalive_timeout 60;
  49.         tcp_nodelay on;
  50.         fastcgi_connect_timeout 300;
  51.         fastcgi_send_timeout 300;
  52.         fastcgi_read_timeout 300;
  53.         fastcgi_buffer_size 64k;
  54.         fastcgi_buffers 4 64k;
  55.         fastcgi_busy_buffers_size 128k;
  56.         fastcgi_temp_file_write_size 256k;
  57.                 fastcgi_intercept_errors on;
  58.         gzip on;
  59.         gzip_min_length  1k;
  60.         gzip_buffers     4 16k;
  61.         gzip_http_version 1.1;
  62.         gzip_comp_level 2;
  63.         gzip_types     text/plain application/javascript application/x-javascript text/javascript text/css application/xml;
  64.         gzip_vary on;
  65.         gzip_proxied   expired no-cache no-store private auth;
  66.         gzip_disable   "MSIE [1-6]\.";
  67.         limit_conn_zone $binary_remote_addr zone=perip:10m;
  68.                 limit_conn_zone $server_name zone=perserver:10m;
  69.         server_tokens off;
  70.         access_log off;
  71. server
  72.     {
  73.         listen 888;
  74.         server_name phpmyadmin;
  75.         index index.html index.htm index.php;
  76.         root  /www/server/phpmyadmin;
  77.             location ~ /tmp/ {
  78.                 return 403;
  79.             }
  80.         #error_page   404   /404.html;
  81.         include enable-php.conf;
  82.         location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
  83.         {
  84.             expires      30d;
  85.         }
  86.         location ~ .*\.(js|css)?$
  87.         {
  88.             expires      12h;
  89.         }
  90.         location ~ /\.
  91.         {
  92.             deny all;
  93.         }
  94.         access_log  /www/wwwlogs/access.log;
  95.     }
  96. include /www/server/panel/vhost/nginx/*.conf;
  97. }
补充1:
警告消息:
nginx: [emerg] bind() to 0.0.0.0:443 failed (98: Address already in use)
nginx: [emerg] still could not bind()
补充2:
网页配置
  1. server
  2. {
  3.     listen 80;
  4.          listen 4433 ssl http2;
  5.     server_name rn.**30103.icu;
  6.     index index.php index.html index.htm default.php default.htm default.html;
  7.     root /www/wwwroot/rn.**30103.icu;
  8.
  9.     #SSL-START SSL相关配置,请勿删除或修改下一行带注释的404规则
  10.     #error_page 404/404.html;
  11.     #HTTP_TO_HTTPS_START
  12.     if ($server_port !~ 4433){
  13.         rewrite ^(/.*)$ https://$host$1 permanent;
  14.     }
  15.     #HTTP_TO_HTTPS_END
  16.     ssl_certificate    /www/server/panel/vhost/cert/rn.**30103.icu/fullchain.pem;
  17.     ssl_certificate_key    /www/server/panel/vhost/cert/rn.**30103.icu/privkey.pem;
  18.     ssl_protocols TLSv1.1 TLSv1.2 TLSv1.3;
  19.     ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
  20.     ssl_prefer_server_ciphers on;
  21.     ssl_session_cache shared:SSL:10m;
  22.     ssl_session_timeout 10m;
  23.     add_header Strict-Transport-Security "max-age=31536000";
  24.     error_page 497  https://$host$request_uri;
  25.     #SSL-END
  26.
  27.     #ERROR-PAGE-START  错误页配置,可以注释、删除或修改
  28.     #error_page 404 /404.html;
  29.     #error_page 502 /502.html;
  30.     #ERROR-PAGE-END
  31.
  32.     #PHP-INFO-START  PHP引用配置,可以注释或修改
  33.     include enable-php-74.conf;
  34.     #PHP-INFO-END
  35.
  36.     #REWRITE-START URL重写规则引用,修改后将导致面板设置的伪静态规则失效
  37.     include /www/server/panel/vhost/rewrite/rn.**30103.icu.conf;
  38.     #REWRITE-END
  39.
  40.     #禁止访问的文件或目录
  41.     location ~ ^/(\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)
  42.     {
  43.         return 404;
  44.     }
  45.
  46.     #一键申请SSL证书验证目录相关设置
  47.     location ~ \.well-known{
  48.         allow all;
  49.     }
  50.
  51.     location ~ .*\.(gif|jpg|jpeg|png|bmp|swf)$
  52.     {
  53.         expires      30d;
  54.         error_log off;
  55.         access_log /dev/null;
  56.     }
  57.
  58.     location ~ .*\.(js|css)?$
  59.     {
  60.         expires      12h;
  61.         error_log off;
  62.         access_log /dev/null;
  63.     }
  64.     access_log  /www/wwwlogs/rn.**30103.icu.log;
  65.     error_log  /www/wwwlogs/rn.**30103.icu.error.log;
  66. }
  67. server
  68. {
  69.     listen 1116;
  70.     server_name rn.**30103.icu;
  71.     location / {
  72.         if ($http_host !~ "^**30103.icu$") {
  73.           rewrite  ^(.*)    https://**30103.icu$1 permanent;
  74.         }
  75.        if ($server_port !~ 4433){
  76.         rewrite ^(.*)   https://**30103.icu$1 permanent;
  77.     }
  78.         proxy_redirect off;
  79.         proxy_set_header Host $host;
  80.         proxy_set_header X-Real-IP $remote_addr;
  81.         proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
  82.     }
  83.     access_log logs/aaa.com_access.log;
  84. }
 楼主| 发表于 2021-5-21 08:58:17 | 只看该作者
      大佬们都没起床吗
  ∮⊱⊱⊱     我们都有一个通病,和爱的人吵架,却和陌生人讲心里话。   ⊰⊰⊰∮
  尾巴不止能用来挠痒痒
   还能凑字数-不定时更新
发表于 2021-5-21 08:59:45 | 只看该作者
报错发出来
 楼主| 发表于 2021-5-21 09:07:38 | 只看该作者
报错内容就是说443被占用,我后台查看 没有占用。 吧443改为4443一样提示4443被占用
我第一次搭建的时候,也是提示这个,忘记怎么搞定的。
就算我吧第一次的配置同样配置,只改域名。还是提示占用
警告消息:
发表于 2021-5-21 09:14:27 | 只看该作者
你是建站而且开SSL了吧,所以你的80 443已经被nginx用了,但是4443被占用就很神奇了。
 楼主| 发表于 2021-5-21 09:18:23 | 只看该作者
zzx396 发表于 2021-5-21 09:14
你是建站而且开SSL了吧,所以你的80 443已经被nginx用了,但是4443被占用就很神奇了。 ...
       明明按照教程来操作。就是找不出问题。
发表于 2021-5-21 09:24:34 | 只看该作者
祝MJJ财源广进 发表于 2021-5-21 09:18
明明按照教程来操作。就是找不出问题。
用的宝塔吧?安全里看看443是否显示未使用,如果显示正常,所有站点的443端口都需要偏移。
 楼主| 发表于 2021-5-21 09:27:31 | 只看该作者
zzx396 发表于 2021-5-21 09:24
用的宝塔吧?安全里看看443是否显示未使用,如果显示正常,所有站点的443端口都需要偏移。 ...
    443未使用 。为什么要偏移端口。
发表于 2021-5-21 09:29:02 | 只看该作者
lsof -i :4443 看一下是哪个占用4443
发表于 2021-5-21 09:32:00 | 只看该作者
v2和tr,哈哈哈扶墙...( _ _)ノ|
GMT+8, 2026-4-18 20:47 , Processed in 0.069051 second(s), 10 queries , Gzip On, MemCache On.
