查看: 2798|回复: 11
[疑问] 求人帮忙看看kloxo或者Virtualmin安装不成功?
发表于 2011-10-24 17:32:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有高人帮我看看吗?我安装N次总是提示不成功,也不明白到底是哪里的问题,有高手帮我看看吗? 有帮忙的高人可以PM我ROOT资料,谢谢!
发表于 2011-10-24 17:33:35 | 只看该作者
如果有hostinabox就方便了,直接cenos自带kloxo
 楼主| 发表于 2011-10-24 18:48:19 | 只看该作者
提示如下,好像是下载升级包时出现问题!
Error Downloading Packages:
  openssl-devel-0.9.8e-20.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 1.9 M
  krb5-devel-1.6.1-62.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 1.9 M
  cpp-4.1.2-51.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 2.7 M
  kernel-devel-2.6.18-274.7.1.el5.i686: Insufficient space in download directory /var/cache/yum/updates/packages
    * free   892 k
    * needed 5.6 M
  db4-devel-4.3.29-10.el5_5.2.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 1.9 M
  gcc-4.1.2-51.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 5.2 M
  mesa-libGL-6.5.1-7.8.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 9.6 M
  mod_perl-2.0.4-6.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 4.0 M
  glibc-devel-2.5-65.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 2.0 M
  libstdc++-devel-4.1.2-51.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 2.8 M
  gcc-c++-4.1.2-51.el5.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 3.4 M
  ncurses-devel-5.5-24.20060715.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 1.6 M
  libxml2-devel-2.6.26-2.1.12.i386: Insufficient space in download directory /var/cache/yum/base/packages
    * free   892 k
    * needed 2.1 M
发表于 2011-10-24 18:49:56 | 只看该作者
PM有偿服务
发表于 2011-10-24 18:50:27 | 只看该作者
PM无偿服务
发表于 2011-10-24 19:06:24 | 只看该作者
不懂,没有装过
发表于 2011-10-24 19:31:06 | 只看该作者
直接按官方命令,没有一次不成功的路过.
参与人数 1威望 +10 收起 理由
Kvm + 10 kloxo有部分rpm包丢失.............
发表于 2011-10-24 19:39:01 | 只看该作者
PM有偿服务
 楼主| 发表于 2011-10-24 19:57:39 | 只看该作者
已经搞定,原来是分配硬盘时出错了,本来是20G,确是1G,已经发TK处理完毕,谢谢!
发表于 2011-10-24 19:58:27 | 只看该作者
回复 9# 6526978 的帖子
原来是硬盘满了.
GMT+8, 2026-4-16 15:48 , Processed in 0.066657 second(s), 14 queries , Gzip On, MemCache On.
