查看: 2737|回复: 11
[Windows VPS] cc 双12的机子性能看着咋样
发表于 2021-5-14 17:35:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天买的一个坛友的,2c+2g+40ssd的,测试了下,cpu单核 466.9 双核 881.8,
发现网络倒是还可以的
  1. ----------------------------------------------------------------------
  2. CPU Model            : Intel Xeon E312xx (Sandy Bridge, IBRS update)
  3. CPU Cores            : 2 Cores 2194.842 MHz x86_64
  4. CPU Cache            : 16384 KB
  5. OS                   : Ubuntu 18.04.2 LTS (64 Bit) KVM
  6. Kernel               : 4.15.0-50-generic
  7. Total Space          : 2.4 GB / 40.0 GB
  8. Total RAM            : 183 MB / 1984 MB (1321 MB Buff)
  9. Total SWAP           : 0 MB / 0 MB
  10. Uptime               : 0 days 1 hour 21 min
  11. Load Average         : 0.58, 0.39, 1.19
  12. TCP CC               : cubic
  13. ASN & ISP            : AS35916, Multacom Corporation
  14. Organization         : Multacom Corporation
  15. Location             : Canyon Country, United States / US
  16. Region               : California
  17. ----------------------------------------------------------------------
  18. I/O Speed( 1.0GB )   : 316 MB/s
  19. I/O Speed( 1.0GB )   : 783 MB/s
  20. I/O Speed( 1.0GB )   : 850 MB/s
  21. Average I/O Speed    : 649.7 MB/s
  22. ----------------------------------------------------------------------
  23. Node Name        Upload Speed      Download Speed      Latency
  24. Speedtest.net    134.00 Mbit/s     702.77 Mbit/s       (*)51.22 ms
  25. Fast.com         0.00 Mbit/s       142.9 Mbit/s        -
  26. Nanjing 5G   CT  519.79 Mbit/s     856.55 Mbit/s       147.91 ms
  27. Hefei 5G     CT  575.39 Mbit/s     745.42 Mbit/s       140.35 ms
  28. Guangzhou 5G CT  542.09 Mbit/s     867.63 Mbit/s       158.22 ms
  29. TianJin 5G   CU  408.74 Mbit/s     849.29 Mbit/s       154.64 ms
  30. Shanghai 5G  CU  681.60 Mbit/s     294.59 Mbit/s       156.28 ms
  31. Tianjin 5G   CM  486.19 Mbit/s     546.22 Mbit/s       193.40 ms
  32. Wuxi 5G      CM  312.11 Mbit/s     6.22 Mbit/s         207.73 ms
  33. Nanjing 5G   CM  280.82 Mbit/s     689.77 Mbit/s       204.32 ms
  34. Hefei 5G     CM  269.94 Mbit/s     613.47 Mbit/s       196.19 ms
  35. Changsha 5G  CM  63.82 Mbit/s      633.98 Mbit/s       198.77 ms
  36. ----------------------------------------------------------------------
发表于 2021-5-14 17:37:00 | 只看该作者
腾讯云轻量单核1000,
PR单核700
vir单核600
PR单核700怕不是搞笑。。  发表于 2021-5-14 19:51
发表于 2021-5-14 17:41:27 | 只看该作者
路过帮顶,话说我的黑五带快照应该是出不去了T_T
 楼主| 发表于 2021-5-14 17:42:31 | 只看该作者
主要一般不怎么会拿来做站,快照没啥用,这个双11和双12还是可以的
发表于 2021-5-14 17:44:13 | 只看该作者
 楼主| 发表于 2021-5-14 17:44:46 | 只看该作者
lei6 发表于 2021-5-14 17:37
腾讯云轻量单核1000,
PR单核700
vir单核600
PR主要是,,我不是优质客户,,vir上次有人出16.69的没收到,良心云还是不错的,
 楼主| 发表于 2021-5-14 17:46:15 | 只看该作者
lolmi 发表于 2021-5-14 17:44
我咋只能跑250呢
脚本多少
我再试试
不会吧,250?那是15一年的吧,我用的这个 wget --no-check-certificate https://github.com/zq/unixbench/raw/master/unixbench.sh&&chmod +x unixbench.sh&&./unixbench.sh|tee unixbench.log
发表于 2021-5-14 17:54:58 | 只看该作者
屌鸡5900X机器半核1400分
发表于 2021-5-14 18:09:45 | 只看该作者
够用就好
GMT+8, 2026-4-16 15:57 , Processed in 0.065767 second(s), 11 queries , Gzip On, MemCache On.
