查看: 4337|回复: 28
Kurun 新款 月付9.99刀 年付99.9刀 测试
发表于 2021-5-13 10:24:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4C 4G 40G数据盘 2T流量  口子是1G共享带宽 回程 GIA+9929 netflix正常解锁
-> System Information
OS Release:            Debian GNU/Linux "Buster" 10.3 (x86_64)
CPU Model:             Intel(R) Xeon(R) CPU E5-2696 v2 @ 2.50GHz  2.50 GHz
CPU Cache Size:        16384 KB
CPU Number:            4 vCPU
VirtReady:             Yes (Nested Virtualization)
Virt Type:             KVM
Memory Usage:          94.99 MB / 3.86 GB
Swap Usage:            [ No Swapfile/Swap Partition ]
Boot Device:           /dev/vda1
Disk Usage:            1.03 GB / 41.25 GB
CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
Load (1/5/15min):      0.11 0.07 0.01
Uptime:                0 Days, 1 Hours, 2 Minutes, 29 Seconds
Kernel Version:        4.19.0-8-cloud-amd64
Network CC Method:     bbr + fq
-> Network Infomation
IPV4 - IP Address:     [US] 154.23.*.*
IPV4 - ASN Info:       AS395886 (KURUN-AS-US - KURUN CLOUD INC, US)
IPV4 - Region:         United States California Los Angeles
-> Media Unlock Test
HBO Now:                               No
Bahamut Anime:                         No
Abema.TV:                              No
Princess Connect Reive Japan:        Yes
BBC:                                   No
BiliBili China Mainland Only:          No
BiliBili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                  No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                 559 Scores
4 Threads Test:                2686 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :         14322.93 MB/s
1 Thread - Write Test:         10456.39 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name              Write Speed                             Read Speed
100MB-4K Block         30.2 MB/s (7379 IOPS, 3.47s)            27.7 MB/s (6764 IOPS, 3.78s)
1GB-1M Block           716 MB/s (682 IOPS, 1.46s)              1.6 GB/s (1497 IOPS, 0.67s)
Superspeed测速
———————————————————SuperSpeed 全面测速版——————————————————
       bash <(curl -Lso- https://git.io/superspeed)
       全部节点列表:  https://git.io/superspeedList
       节点更新: 2020/04/09  | 脚本更新: 2020/04/09
  测速类型:    1. 三网测速    2. 取消测速
               3. 电信节点    4. 联通节点    5. 移动节点
  请输入数字选择测速类型: 1
ID    测速服务器信息       上传/Mbps   下载/Mbps   延迟/ms
3633  电信|上海      ↑ 391.58    ↓ 116.29    129.58
17145 电信|安徽合肥5G  ↑ 534.82    ↓ 159.60    136.72
27594 电信|广东广州5G  ↑ 500.65    ↓ 778.96    160.65
27575 电信|新疆乌鲁木齐  ↑ 384.53    ↓ 781.63    206.06
5396  电信|江苏苏州5G  ↑ 556.75    ↓ 757.94    135.48
3973  电信|甘肃兰州    ↑ 406.13    ↓ 703.28    176.69
24447 联通|上海5G    ↑ 530.36    ↓ 803.65    153.43
5145  联通|北京      ↑ 556.48    ↓ 127.55    151.38
27154 联通|天津5G    ↑ 526.26    ↓ 133.45    153.89
26180 联通|山东济南5G  ↑ 496.91    ↓ 139.14    165.18
13704 联通|江苏南京    ↑ 311.94    ↓ 722.00    156.69
4870  联通|湖南长沙    ↑ 513.61    ↓ 437.48    160.34
4863  联通|陕西西安    ↑ 448.37    ↓ 722.26    189.56
30232 移动|内蒙呼和浩特5G↑ 422.91    ↓ 898.80    192.66
17184 移动|天津5G    ↑ 460.66    ↓ 885.15    169.12
26938 移动|新疆乌鲁木齐5G↑ 56.77     ↓ 894.58    213.24
16398 移动|贵州贵阳    ↑ 495.64    ↓ 922.71    168.57
  测试完成, 本次测速耗时: 9 分 9 秒
  当前时间: 2021-05-13 02:21:19
发表于 2021-5-13 10:25:46 | 只看该作者
tracerouter都没有吗?
发表于 2021-5-13 10:27:40 | 只看该作者
99刀,我看成了99了。。让了让了
发表于 2021-5-13 10:28:20 | 只看该作者
这个cpu 分数咋样
 楼主| 发表于 2021-5-13 10:29:02 | 只看该作者
Marlene 发表于 2021-5-13 10:25
tracerouter都没有吗?
超出帖子长度了,等下
发表于 2021-5-13 10:30:42 | 只看该作者
tracerouter都没有吗?
gia混9929要啥traceroute
发表于 2021-5-13 10:34:11 | 只看该作者
 楼主| 发表于 2021-5-13 10:35:42 | 只看该作者
补上回程
-> Traceroute Test (IPV4)
Traceroute to China, Beijing CU (TCP Mode, Max 30 Hop)
traceroute to 123.125.99.1 (123.125.99.1), 30 hops max, 32 byte packets
1  10.0.111.1  0.16 ms  *  LAN Address
2  192.168.255.244  14.69 ms  *  LAN Address
3  192.168.222.0  10.18 ms  *  LAN Address
4  192.168.222.254  0.62 ms  *  LAN Address
5  162.219.85.241  132.21 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  133.00 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.201  131.47 ms  AS9929  China, ChinaUnicom
8  218.105.131.125  155.68 ms  AS9929  China, ChinaUnicom
9  210.78.28.82  150.89 ms  *  China, Beijing, ChinaUnicom
10  219.158.35.45  154.72 ms  AS4837  China, ChinaUnicom
11  219.158.5.129  178.06 ms  AS4837  China, ChinaUnicom
12  61.49.214.38  174.95 ms  AS4808  China, Beijing, ChinaUnicom
13  61.148.157.170  177.50 ms  AS4808  China, Beijing, ChinaUnicom
14  61.148.158.102  177.43 ms  AS4808  China, Beijing, ChinaUnicom
15  61.135.113.158  175.31 ms  AS4808  China, Beijing, ChinaUnicom
16  *
17  *
18  123.125.99.1  153.80 ms  AS4808  China, Beijing, ChinaUnicom
Traceroute to China, Beijing CT (TCP Mode, Max 30 Hop)
traceroute to 180.149.128.9 (180.149.128.9), 30 hops max, 32 byte packets
1  10.0.111.1  0.23 ms  *  LAN Address
2  192.168.255.246  11.63 ms  *  LAN Address
3  192.168.222.0  15.68 ms  *  LAN Address
4  192.168.222.254  0.76 ms  *  LAN Address
5  218.30.49.149  0.89 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.182.81  128.10 ms  *  China, ChinaTelecom
7  59.43.182.225  152.44 ms  *  China, ChinaTelecom
8  *
9  59.43.132.9  149.74 ms  *  China, ChinaTelecom
10  *
11  36.110.244.46  158.21 ms  AS23724  China, Beijing, ChinaTelecom
12  36.110.246.198  165.11 ms  AS23724  China, Beijing, ChinaTelecom
13  180.149.128.9  153.94 ms  AS23724  China, Beijing, ChinaTelecom
Traceroute to China, Beijing CM (TCP Mode, Max 30 Hop)
traceroute to 211.136.25.153 (211.136.25.153), 30 hops max, 32 byte packets
1  10.0.111.1  0.30 ms  *  LAN Address
2  192.168.255.246  11.52 ms  *  LAN Address
3  192.168.222.0  7.74 ms  *  LAN Address
4  192.168.222.254  0.80 ms  *  LAN Address
5  162.219.85.241  132.42 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  133.96 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.93  145.87 ms  AS9929  China, ChinaUnicom
8  218.105.131.101  151.05 ms  AS9929  China, ChinaUnicom
9  210.78.28.74  150.53 ms  *  China, Beijing, ChinaUnicom
10  219.158.35.17  154.04 ms  AS4837  China, ChinaUnicom
11  219.158.38.214  164.85 ms  AS4837  China, ChinaUnicom
12  221.183.25.53  172.11 ms  AS9808  China, ChinaMobile
13  111.24.2.245  172.64 ms  AS9808  China, ChinaMobile
14  111.24.2.134  166.79 ms  AS9808  China, ChinaMobile
15  211.136.67.106  182.63 ms  AS56048  China, Beijing, ChinaMobile
16  211.136.67.166  167.05 ms  AS56048  China, Beijing, ChinaMobile
17  211.136.95.226  176.09 ms  AS56048  China, Beijing, ChinaMobile
18  211.136.95.226  176.86 ms  AS56048  China, Beijing, ChinaMobile
19  *
20  211.136.25.153  173.33 ms  AS56048  China, Beijing, ChinaMobile
Traceroute to China, Shanghai CU (TCP Mode, Max 30 Hop)
traceroute to 58.247.8.158 (58.247.8.158), 30 hops max, 32 byte packets
1  10.0.111.1  0.18 ms  *  LAN Address
2  192.168.255.244  11.43 ms  *  LAN Address
3  192.168.222.0  10.52 ms  *  LAN Address
4  192.168.222.254  0.74 ms  *  LAN Address
5  162.219.85.241  132.51 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  134.21 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.93  141.37 ms  AS9929  China, ChinaUnicom
8  218.105.2.150  157.21 ms  AS9929  China, ChinaUnicom
9  *
10  219.158.9.97  154.65 ms  AS4837  China, ChinaUnicom
11  139.226.210.94  176.28 ms  AS17621  China, Shanghai, ChinaUnicom
12  58.247.221.178  152.80 ms  AS17621  China, Shanghai, ChinaUnicom
13  139.226.225.22  158.93 ms  AS17621  China, Shanghai, ChinaUnicom
14  58.247.8.153  185.31 ms  AS17621  China, Shanghai, ChinaUnicom
15  *
16  *
17  *
18  *
19  *
20  *
21  *
22  *
23  *
24  *
25  *
26  *
27  *
28  *
29  *
30  *
Traceroute to China, Shanghai CT (TCP Mode, Max 30 Hop)
traceroute to 180.153.28.5 (180.153.28.5), 30 hops max, 32 byte packets
1  10.0.111.1  0.26 ms  *  LAN Address
2  192.168.255.244  9.30 ms  *  LAN Address
3  192.168.222.0  9.47 ms  *  LAN Address
4  192.168.222.254  1.19 ms  *  LAN Address
5  218.30.49.149  1.23 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.189.33  127.81 ms  *  China, ChinaTelecom
7  *
8  59.43.130.205  136.09 ms  *  China, ChinaTelecom
9  101.95.88.58  128.39 ms  AS4812  China, Shanghai, ChinaTelecom
10  124.74.166.134  132.36 ms  AS4812  China, Shanghai, ChinaTelecom
11  124.74.232.66  131.07 ms  AS4811  China, Shanghai, ChinaTelecom
12  101.227.255.34  157.50 ms  AS4812  China, Shanghai, ChinaTelecom
13  180.153.28.5  131.16 ms  AS4812  China, Shanghai, ChinaTelecom
Traceroute to China, Shanghai CM (TCP Mode, Max 30 Hop)
traceroute to 221.183.55.22 (221.183.55.22), 30 hops max, 32 byte packets
1  10.0.111.1  0.12 ms  *  LAN Address
2  192.168.255.244  11.12 ms  *  LAN Address
3  192.168.222.0  11.05 ms  *  LAN Address
4  192.168.222.254  0.77 ms  *  LAN Address
5  162.219.85.241  132.30 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  133.94 ms  AS10099  China, Hong Kong, ChinaUnicom
8  218.105.2.174  131.26 ms  AS9929  China, ChinaUnicom
9  *
10  219.158.42.130  154.62 ms  AS4837  China, ChinaUnicom
11  221.183.86.110  157.87 ms  AS9808  China, ChinaMobile
12  *
13  221.176.22.10  157.74 ms  AS9808  China, ChinaMobile
 楼主| 发表于 2021-5-13 10:36:43 | 只看该作者
Traceroute to China, Guangzhou CU (TCP Mode, Max 30 Hop)
traceroute to 210.21.4.130 (210.21.4.130), 30 hops max, 32 byte packets
2  192.168.255.244  11.31 ms  *  LAN Address
3  192.168.222.0  12.39 ms  *  LAN Address
5  162.219.85.241  132.49 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  135.45 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.93  132.06 ms  AS9929  China, ChinaUnicom
8  218.105.131.181  159.22 ms  AS9929  China, ChinaUnicom
9  210.14.161.150  156.84 ms  *  China, ChinaUnicom
10  *
11  219.158.10.249  180.12 ms  AS4837  China, ChinaUnicom
12  120.86.0.182  179.89 ms  AS17816  China, Guangdong, Foshan, ChinaUnicom
13  120.80.79.194  169.83 ms  AS17622  China, Guangdong, Guangzhou, ChinaUnicom
14  *
15  *
16  *
17  *
Traceroute to China, Guangzhou CT (TCP Mode, Max 30 Hop)
traceroute to 113.108.209.1 (113.108.209.1), 30 hops max, 32 byte packets
1  10.0.111.1  0.21 ms  *  LAN Address
2  192.168.255.246  14.39 ms  *  LAN Address
3  192.168.222.0  11.58 ms  *  LAN Address
4  192.168.222.254  0.91 ms  *  LAN Address
5  218.30.49.149  1.35 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.189.41  160.36 ms  *  China, ChinaTelecom
7  *
8  59.43.130.113  165.21 ms  *  China, ChinaTelecom
9  59.43.80.126  156.62 ms  *  China, ChinaTelecom
10  113.96.0.93  156.91 ms  AS58466  China, Guangdong, Guangzhou, ChinaTelecom
11  113.108.209.1  158.52 ms  AS58466  China, Guangdong, Guangzhou, ChinaTelecom
Traceroute to China, Guangzhou CM (TCP Mode, Max 30 Hop)
traceroute to 120.196.212.25 (120.196.212.25), 30 hops max, 32 byte packets
1  10.0.111.1  0.10 ms  *  LAN Address
2  192.168.255.244  14.52 ms  *  LAN Address
3  192.168.222.0  9.69 ms  *  LAN Address
4  192.168.222.254  0.82 ms  *  LAN Address
5  162.219.85.241  132.32 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  133.82 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.205  131.38 ms  AS9929  China, ChinaUnicom
8  218.105.131.197  157.43 ms  AS9929  China, ChinaUnicom
9  210.14.161.62  173.24 ms  *  China, ChinaUnicom
10  *
11  219.158.34.26  153.16 ms  AS4837  China, ChinaUnicom
12  221.183.23.53  166.97 ms  AS9808  China, ChinaMobile
13  111.24.5.177  152.85 ms  AS9808  China, ChinaMobile
14  111.24.5.30  159.67 ms  AS9808  China, ChinaMobile
15  211.136.208.249  158.69 ms  AS56040  China, Guangdong, Guangzhou, ChinaMobile
16  211.136.249.121  162.19 ms  AS56040  China, Guangdong, Guangzhou, ChinaMobile
17  211.136.214.138  163.47 ms  AS56040  China, Guangdong, Guangzhou, ChinaMobile
18  120.196.212.25  155.85 ms  AS56040  China, Guangdong, Guangzhou, ChinaMobile
Traceroute to China, Shanghai CU AS9929 (TCP Mode, Max 30 Hop)
traceroute to 210.13.66.238 (210.13.66.238), 30 hops max, 32 byte packets
1  10.0.111.1  0.19 ms  *  LAN Address
2  192.168.255.244  9.56 ms  *  LAN Address
3  192.168.222.0  12.03 ms  *  LAN Address
4  192.168.222.254  0.92 ms  *  LAN Address
5  162.219.85.241  132.46 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  134.85 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.89  132.12 ms  AS9929  China, ChinaUnicom
8  218.105.2.198  130.59 ms  AS9929  China, ChinaUnicom
9  210.13.112.254  144.74 ms  AS9929  China, Shanghai, ChinaUnicom
10  210.13.66.237  166.31 ms  AS9929  China, Shanghai, ChinaUnicom
11  210.13.66.238  147.02 ms  AS9929  China, Shanghai, ChinaUnicom
Traceroute to China, Shanghai CT CN2 (TCP Mode, Max 30 Hop)
traceroute to 58.32.0.1 (58.32.0.1), 30 hops max, 32 byte packets
2  192.168.255.244  12.04 ms  *  LAN Address
3  192.168.222.0  10.70 ms  *  LAN Address
4  192.168.222.254  0.72 ms  *  LAN Address
5  218.30.49.149  1.29 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.189.33  127.99 ms  *  China, ChinaTelecom
7  *
8  59.43.130.213  132.59 ms  *  China, ChinaTelecom
9  101.95.88.222  129.96 ms  AS4812  China, Shanghai, ChinaTelecom
10  *
11  *
12  58.32.0.1  130.35 ms  AS4812  China, Shanghai, ChinaTelecom
Traceroute to China, Guangzhou CT CN2 Gaming Broadband (TCP Mode, Max 30 Hop)
traceroute to 119.121.0.1 (119.121.0.1), 30 hops max, 32 byte packets
2  192.168.255.244  17.15 ms  *  LAN Address
3  192.168.222.0  7.44 ms  *  LAN Address
4  192.168.222.254  1.22 ms  *  LAN Address
5  218.30.49.149  0.93 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.182.78  196.09 ms  *  China, ChinaTelecom
7  *
8  59.43.130.117  167.35 ms  *  China, ChinaTelecom
9  *
10  *
11  119.121.0.1  167.91 ms  AS134773  China, Guangdong, Guangzhou, ChinaTelecom
Traceroute to China, Beijing Dr.Peng Home Network (TCP Mode, Max 30 Hop)
traceroute to 14.131.128.1 (14.131.128.1), 30 hops max, 32 byte packets
1  10.0.111.1  0.27 ms  *  LAN Address
2  192.168.255.246  12.58 ms  *  LAN Address
3  192.168.222.0  10.25 ms  *  LAN Address
4  192.168.222.254  1.03 ms  *  LAN Address
5  162.219.85.241  132.59 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  132.91 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.201  131.89 ms  AS9929  China, ChinaUnicom
8  218.105.131.125  155.89 ms  AS9929  China, ChinaUnicom
9  210.78.28.82  151.02 ms  *  China, Beijing, ChinaUnicom
10  219.158.35.17  156.30 ms  AS4837  China, ChinaUnicom
11  219.158.3.65  153.69 ms  AS4837  China, ChinaUnicom
12  124.65.194.22  154.08 ms  AS4808  China, Beijing, ChinaUnicom
13  202.96.13.190  153.57 ms  AS4808  China, Beijing, ChinaUnicom
14  *
15  *
16  *
17  *
Traceroute to China, Beijing Dr.Peng Network IDC Network (TCP Mode, Max 30 Hop)
traceroute to 211.167.230.100 (211.167.230.100), 30 hops max, 32 byte packets
1  10.0.111.1  0.24 ms  *  LAN Address
2  192.168.255.246  12.20 ms  *  LAN Address
3  192.168.222.0  12.09 ms  *  LAN Address
4  192.168.222.254  0.94 ms  *  LAN Address
5  162.219.85.241  132.35 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  132.84 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.205  131.34 ms  AS9929  China, ChinaUnicom
8  218.105.131.125  155.77 ms  AS9929  China, ChinaUnicom
9  210.78.28.82  150.99 ms  *  China, Beijing, ChinaUnicom
10  219.158.35.17  155.11 ms  AS4837  China, ChinaUnicom
11  219.158.3.65  159.01 ms  AS4837  China, ChinaUnicom
12  *
13  202.96.13.210  152.04 ms  AS4808  China, Beijing, ChinaUnicom
14  61.51.37.206  173.53 ms  AS4808  China, Beijing, ChinaUnicom
15  218.241.244.2  153.71 ms  AS4808  China, Beijing, DRPENG
16  124.205.97.166  154.68 ms  AS4808  China, Beijing, DRPENG
17  218.241.253.214  158.93 ms  AS4808  China, Beijing, DRPENG
18  218.241.245.158  159.80 ms  AS4808  China, Beijing, DRPENG
19  *
20  211.167.230.100  152.80 ms  AS17964  China, Beijing, DRPENG
Traceroute to China, Beijing CERNET (TCP Mode, Max 30 Hop)
traceroute to 202.205.109.205 (202.205.109.205), 30 hops max, 32 byte packets
1  10.0.111.1  0.22 ms  *  LAN Address
2  192.168.255.246  9.72 ms  *  LAN Address
3  192.168.222.0  13.81 ms  *  LAN Address
4  192.168.222.254  11.19 ms  *  LAN Address
5  162.219.85.241  132.55 ms  AS10099  China, Hong Kong, ChinaUnicom
6  203.160.75.218  132.75 ms  AS10099  China, Hong Kong, ChinaUnicom
7  218.105.2.89  132.03 ms  AS9929  China, ChinaUnicom
8  218.105.2.150  158.90 ms  AS9929  China, ChinaUnicom
9  *
10  219.158.113.197  177.84 ms  AS4837  China, ChinaUnicom
11  *
12  *
13  101.4.117.193  161.47 ms  AS4538  China, CHINAEDU
14  *
15  101.4.117.30  181.63 ms  AS4538  China, CHINAEDU
16  101.4.116.118  184.96 ms  AS4538  China, CHINAEDU
17  101.4.112.69  154.61 ms  AS4538  China, CHINAEDU
18  101.4.113.110  159.05 ms  AS4538  China, CHINAEDU
19  219.224.102.230  154.83 ms  AS4538  China, CHINAEDU
20  202.112.38.158  154.80 ms  AS4538  China, CHINAEDU
21  202.205.109.205  154.25 ms  AS4538  China, Beijing, CHINAEDU
Traceroute to China, Beijing CSTNET (TCP Mode, Max 30 Hop)
traceroute to 159.226.254.1 (159.226.254.1), 30 hops max, 32 byte packets
2  192.168.255.244  11.79 ms  *  LAN Address
3  192.168.222.0  13.68 ms  *  LAN Address
4  192.168.222.254  1.01 ms  *  LAN Address
5  218.30.49.149  1.14 ms  AS4134  United States, California, Los Angeles, ChinaTelecom
6  59.43.182.89  128.73 ms  *  China, ChinaTelecom
7  59.43.246.217  128.16 ms  *  China, ChinaTelecom
8  63.218.211.9  150.67 ms  AS3491,AS31713  China, Hong Kong, pccw.com
GMT+8, 2026-4-20 09:38 , Processed in 0.069401 second(s), 10 queries , Gzip On, MemCache On.
