CeraNetworks网络延迟测速工具IP归属甄别
查看: 4582|回复: 0
ServerstsAdium出台活动特价高配机器-已出
发表于 2021-5-9 15:10:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
续费54刀  不溢价直接50刀出了 大厂机器值得拥有
OS Release:            CentOS Linux 7.9.2009 (x86_64)
CPU Model:             Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz  2.76~2.90 GHz
CPU Cache Size:        20480 KB
CPU Number:            2 Physical CPU(s), 8 Cores/CPU, 16 Threads/CPU (Total 16 Cores, 32 Threads)
VirtReady:             Yes (Based on )
Virt Type:             Dedicated with American Megatrends Inc. BIOS
Memory Usage:          3.05 GB / 125.88 GB
Swap Usage:            0 KB / 4.00 GB
Boot Device:           /dev/mapper/vg-root
Disk Usage:            9.89 GB / 955.88 GB
CPU Usage:             0.4% used, 0.0% iowait, 0.0% steal
Load (1/5/15min):      0.18 0.10 0.02
Uptime:                3 Days, 15 Hours, 58 Minutes, 10 Seconds
Kernel Version:        4.14.129-bbrplus
Network CC Method:     bbrplus + fq
-> Network Infomation
IPV4 - IP Address:     [US] 208.115.96.74
IPV4 - ASN Info:       AS23033 (WOW - Wowrack.com, US)
IPV4 - Region:         United States Washington Seattle
-> Media Unlock Test
HBO Now:                               Yes
Bahamut Anime:                         Failed (due to parse fail)
Abema.TV:                              No
Princess Connect Reive Japan:        No
BBC:                                   No
BiliBili China Mainland Only:          No
BiliBili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                  No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                 848 Scores
32 Threads Test:               19526 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :         15862.61 MB/s
1 Thread - Write Test:         12609.65 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name              Write Speed                             Read Speed
100MB-4K Block         75.9 MB/s (0.05 IOPS, 1.38s))           89.9 MB/秒 (21947 IOPS, 1.17s)
1GB-1M Block           255 MB/s (243 IOPS, 4.11s)              267 MB/秒 (254 IOPS, 3.93s)
-> Speedtest.net Network Speed Test
Node Name                      Upload Speed    Download Speed  Ping Latency    Server Name
Speedtest Default              33.70 MB/s      108.60 MB/s     45.93 ms        S&A Telephone (United States Allen, KS)
China, Beijing CU              18.63 MB/s      4.82 MB/s       177.43 ms       Beijing Unicom (China Beijing)
China, Shanghai CT             16.54 MB/s      100.99 MB/s     164.49 ms       China Telecom (China Shanghai)
China, Hangzhou CM             Fail: Timeout Exceeded after 60 seconds
GMT+8, 2026-4-22 12:57 , Processed in 0.056065 second(s), 9 queries , Gzip On, MemCache On.
