查看: 11034|回复: 54
volumedrive的新机器
发表于 2011-10-16 02:32:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
型号
  1. System Information
  2.         Manufacturer: Supermicro
  3.         Product Name: X9SCL/X9SCM
  4.         Version: 0123456789
  5.         Serial Number: xx
  6.         UUID: xx
  7.         Wake-up Type: Power Switch
  8.         SKU Number: To be filled by O.E.M.
  9.         Family: To be filled by O.E.M.
CPU
  1. Processor Information
  2.         Socket Designation: CPU
  3.         Type: Central Processor
  4.         Family: Xeon
  5.         Manufacturer: Intel
  6.         ID: A7 06 02 00 FF FB EB BF
  7.         Signature: Type 0, Family 6, Model 42, Stepping 7
  8.         Flags:
  9.                 FPU (Floating-point unit on-chip)
  10.                 VME (Virtual mode extension)
  11.                 DE (Debugging extension)
  12.                 PSE (Page size extension)
  13.                 TSC (Time stamp counter)
  14.                 MSR (Model specific registers)
  15.                 PAE (Physical address extension)
  16.                 MCE (Machine check exception)
  17.                 CX8 (CMPXCHG8 instruction supported)
  18.                 APIC (On-chip APIC hardware supported)
  19.                 SEP (Fast system call)
  20.                 MTRR (Memory type range registers)
  21.                 PGE (Page global enable)
  22.                 MCA (Machine check architecture)
  23.                 CMOV (Conditional move instruction supported)
  24.                 PAT (Page attribute table)
  25.                 PSE-36 (36-bit page size extension)
  26.                 CLFSH (CLFLUSH instruction supported)
  27.                 DS (Debug store)
  28.                 ACPI (ACPI supported)
  29.                 MMX (MMX technology supported)
  30.                 FXSR (Fast floating-point save and restore)
  31.                 SSE (Streaming SIMD extensions)
  32.                 SSE2 (Streaming SIMD extensions 2)
  33.                 SS (Self-snoop)
  34.                 HTT (Hyper-threading technology)
  35.                 TM (Thermal monitor supported)
  36.                 PBE (Pending break enabled)
  37.         Version: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz
  38.         Voltage: 0.0 V
  39.         External Clock: 100 MHz
  40.         Max Speed: 3800 MHz
  41.         Current Speed: 3200 MHz
  42.         Status: Populated, Enabled
  43.         Upgrade: <OUT OF SPEC>
  44.         L1 Cache Handle: 0x0004
  45.         L2 Cache Handle: 0x0005
  46.         L3 Cache Handle: 0x0006
  47.         Serial Number: Not Specified
  48.         Asset Tag: Not Specified
  49.         Part Number: Not Specified
  50.         Core Count: 4
  51.         Core Enabled: 4
  52.         Thread Count: 8
  53.         Characteristics:
  54.                 64-bit capable
硬盘
  1. === START OF INFORMATION SECTION ===
  2. Device Model:     Hitachi HDS721010CLA332
  3. Serial Number:    xx
  4. Firmware Version: JP4OA3MA
  5. User Capacity:    1,000,204,886,016 bytes
  6. Device is:        Not in smartctl database [for details use: -P showall]
  7. ATA Version is:   8
  8. ATA Standard is:  ATA-8-ACS revision 4
  9. Local Time is:    Sat Oct 15 09:56:38 2011 EDT
  10. SMART support is: Available - device has SMART capability.
  11. SMART support is: Enabled
[ 本帖最后由 Porter 于 2011-10-16 02:57 编辑 ]
 楼主| 发表于 2011-10-16 02:35:38 | 只看该作者
呃,kvm管理地址可以上了。
  1. --2011-10-15 09:46:35--  http://cachefly.cachefly.net/100mb.test
  2. Resolving cachefly.cachefly.net... 205.234.175.175
  3. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  4. HTTP request sent, awaiting response... 200 OK
  5. Length: 104857600 (100M) [application/octet-stream]
  6. Saving to: “100mb.test”
  7. 100%[=======================================================================================>] 104,857,600 90.5M/s   in 1.1s
  8. 2011-10-15 09:46:37 (90.5 MB/s) - “100mb.test” saved [104857600/104857600]
更新跑分
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3.    System: xx: GNU/Linux
  4.    OS: GNU/Linux -- 2.6.32-5-amd64 -- #1 SMP Mon Oct 3 03:59:20 UTC 2011
  5.    Machine: x86_64 (unknown)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.7 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  9.    CPU 1: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  11.    CPU 2: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  13.    CPU 3: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  14.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  15.    CPU 4: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  16.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  17.    CPU 5: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.5 bogomips)
  18.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  19.    CPU 6: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  20.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  21.    CPU 7: Intel(R) Xeon(R) CPU E31230 @ 3.20GHz (6385.4 bogomips)
  22.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  23.    14:06:45 up 33 min,  2 users,  load average: 0.30, 0.27, 0.14; runlevel 2
  24. ------------------------------------------------------------------------
  25. Benchmark Run: Sun Oct 16 2011 14:06:45 - 14:35:07
  26. 8 CPUs in system; running 1 parallel copy of tests
  27. Dhrystone 2 using register variables       35040293.2 lps   (10.0 s, 7 samples)
  28. Double-Precision Whetstone                     3840.6 MWIPS (9.9 s, 7 samples)
  29. Execl Throughput                               4949.9 lps   (29.8 s, 2 samples)
  30. File Copy 1024 bufsize 2000 maxblocks       1195317.7 KBps  (30.0 s, 2 samples)
  31. File Copy 256 bufsize 500 maxblocks          322868.0 KBps  (30.0 s, 2 samples)
  32. File Copy 4096 bufsize 8000 maxblocks       2885209.5 KBps  (30.0 s, 2 samples)
  33. Pipe Throughput                             2565867.8 lps   (10.0 s, 7 samples)
  34. Pipe-based Context Switching                 222319.6 lps   (10.0 s, 7 samples)
  35. Process Creation                              20111.0 lps   (30.0 s, 2 samples)
  36. Shell Scripts (1 concurrent)                  11172.6 lpm   (60.0 s, 2 samples)
  37. Shell Scripts (8 concurrent)                   4913.8 lpm   (60.0 s, 2 samples)
  38. System Call Overhead                        4409899.4 lps   (10.0 s, 7 samples)
  39. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  40. Dhrystone 2 using register variables         116700.0   35040293.2   3002.6
  41. Double-Precision Whetstone                       55.0       3840.6    698.3
  42. Execl Throughput                                 43.0       4949.9   1151.1
  43. File Copy 1024 bufsize 2000 maxblocks          3960.0    1195317.7   3018.5
  44. File Copy 256 bufsize 500 maxblocks            1655.0     322868.0   1950.9
  45. File Copy 4096 bufsize 8000 maxblocks          5800.0    2885209.5   4974.5
  46. Pipe Throughput                               12440.0    2565867.8   2062.6
  47. Pipe-based Context Switching                   4000.0     222319.6    555.8
  48. Process Creation                                126.0      20111.0   1596.1
  49. Shell Scripts (1 concurrent)                     42.4      11172.6   2635.0
  50. Shell Scripts (8 concurrent)                      6.0       4913.8   8189.7
  51. System Call Overhead                          15000.0    4409899.4   2939.9
  52.        ========
  53. System Benchmarks Index Score                                        2119.3
  54. ------------------------------------------------------------------------
  55. Benchmark Run: Sun Oct 16 2011 14:35:07 - 15:03:45
  56. 8 CPUs in system; running 8 parallel copies of tests
  57. Dhrystone 2 using register variables      153018632.8 lps   (10.0 s, 7 samples)
  58. Double-Precision Whetstone                    25973.9 MWIPS (9.9 s, 7 samples)
  59. Execl Throughput                              34430.4 lps   (29.8 s, 2 samples)
  60. File Copy 1024 bufsize 2000 maxblocks        818862.9 KBps  (30.0 s, 2 samples)
  61. File Copy 256 bufsize 500 maxblocks          198420.3 KBps  (30.0 s, 2 samples)
  62. File Copy 4096 bufsize 8000 maxblocks       2484702.5 KBps  (30.0 s, 2 samples)
  63. Pipe Throughput                            12354118.1 lps   (10.0 s, 7 samples)
  64. Pipe-based Context Switching                2804960.0 lps   (10.0 s, 7 samples)
  65. Process Creation                             106161.3 lps   (30.0 s, 2 samples)
  66. Shell Scripts (1 concurrent)                  46737.0 lpm   (60.0 s, 2 samples)
  67. Shell Scripts (8 concurrent)                   6124.6 lpm   (60.0 s, 2 samples)
  68. System Call Overhead                        9130909.9 lps   (10.0 s, 7 samples)
  69. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  70. Dhrystone 2 using register variables         116700.0  153018632.8  13112.1
  71. Double-Precision Whetstone                       55.0      25973.9   4722.5
  72. Execl Throughput                                 43.0      34430.4   8007.1
  73. File Copy 1024 bufsize 2000 maxblocks          3960.0     818862.9   2067.8
  74. File Copy 256 bufsize 500 maxblocks            1655.0     198420.3   1198.9
  75. File Copy 4096 bufsize 8000 maxblocks          5800.0    2484702.5   4284.0
  76. Pipe Throughput                               12440.0   12354118.1   9931.0
  77. Pipe-based Context Switching                   4000.0    2804960.0   7012.4
  78. Process Creation                                126.0     106161.3   8425.5
  79. Shell Scripts (1 concurrent)                     42.4      46737.0  11022.9
  80. Shell Scripts (8 concurrent)                      6.0       6124.6  10207.7
  81. System Call Overhead                          15000.0    9130909.9   6087.3
  82.        ========
  83. System Benchmarks Index Score                                        5985.9
[ 本帖最后由 Porter 于 2011-10-16 15:06 编辑 ]
发表于 2011-10-16 02:40:44 | 只看该作者
很晚了,早点睡咯
参与人数 1威望 +5 收起 理由
Porter + 5 通宵加班伤不起
发表于 2011-10-16 02:44:56 | 只看该作者
发表于 2011-10-16 02:48:27 | 只看该作者
这个哪里的 有测试IP没。。
 楼主| 发表于 2011-10-16 02:50:05 | 只看该作者
发表于 2011-10-16 02:50:44 | 只看该作者
发表于 2011-10-16 02:51:17 | 只看该作者
很牛。买了。等开通。试试。
发表于 2011-10-16 02:52:40 | 只看该作者
 楼主| 发表于 2011-10-16 03:01:50 | 只看该作者
没有硬件raid的IO真悲剧。
GMT+8, 2026-4-23 11:35 , Processed in 0.074769 second(s), 15 queries , Gzip On, MemCache On.
