CeraNetworks网络延迟测速工具IP归属甄别
查看: 3400|回复: 0
kloxo安装变成127.0.0.1后 重装kloxo遇到问题解决办法~~
发表于 2011-10-14 16:45:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Transaction Check Error:
file /usr/lib/mysql/libmysqlclient.so.15.0.0 conflicts between attempted installs of mysql-libs-5.0.92-lxcenter.1.i386 and
mysqlclient15-5.0.92-lxcenter.1.i386
file /usr/lib/mysql/libmysqlclient_r.so.15.0.0 conflicts between attempted installs of mysql-libs-5.0.92-lxcenter.1.i386 and
Error Summary
Yum Gave Error... Trying Again...
Installing packages php-mbstring php-mysql which gcc-c++ php-imap php-pear php-devel lxlighttpd httpd mod_ssl zip unzip lxphp
lxzend mysql mysql-server mysqlclient* curl autoconf automake libtool bogofilter gcc cpp openssl pure-ftpd yum-protectbase...
解决办法
1. 卸载mysqlclient "yum remove mysqlclient*"
2. 编辑和添加 "vi /etc/yum.repos.d/lxcenter.repo"
# LxCenter Repository
[lxcenter-updates]
name=centos-5-$releasever - LxCenter-Updates
baseurl=http://download.lxcenter.org/download/update/centos-5/$basearch/
gpgcheck=0
enabled=1
exclude=mysqlclient*
#packages used/produced in the build but not released
[lxcenter-extra]
name=centos-5-$releasever - LxCenter-Extra
baseurl=http://download.lxcenter.org/download/update/lxgeneral
gpgcheck=0
enabled=1
# LxCenter test packages
# Do not enable/use this. Use it at your own risc.
# It can damage your production server.
[lxcenter-test]
name=centos-5-$releasever - LxCenter-Test
baseurl=http://download.lxcenter.org/download/test/centos-5/$basearch/
gpgcheck=0
enabled=0
3. 运行 "chattr +i /etc/yum.repos.d/lxcenter.repo"
4.安装kloxo
5. 安装成功后 输入"chattr -i /etc/yum.repos.d/lxcenter.repo"
据说这个问题是mysqlclient15安装包的问题
GMT+8, 2026-1-18 08:51 , Processed in 0.058933 second(s), 9 queries , Gzip On, MemCache On.
