查看: 11654|回复: 61
20.21PR的CPU性能翻车了,从昨天开始的
发表于 2021-3-25 20:40:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
亏我那样相信PR,这是买的第二个,结果这才不到一周,就从500单核,变成了现在的200不到!!
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3.    System: XXXXXXXXXXXXX: GNU/Linux
  4.    OS: GNU/Linux -- 5.4.0-70-generic -- #78-Ubuntu SMP Fri Mar 19 13:29:52 UTC 2021
  5.    Machine: x86_64 (x86_64)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU E5-2650 v2 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz (5200.0 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  9.    CPU 1: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  11.    CPU 2: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  13.    CPU 3: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  14.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  15.    19:41:16 up  1:54,  2 users,  load average: 0.91, 2.23, 2.79; runlevel 5
  16. ------------------------------------------------------------------------
  17. Benchmark Run: Thu Mar 25 2021 19:41:16 - 20:09:27
  18. 4 CPUs in system; running 1 parallel copy of tests
  19. Dhrystone 2 using register variables        7441283.5 lps   (10.0 s, 7 samples)
  20. Double-Precision Whetstone                     1196.9 MWIPS (9.8 s, 7 samples)
  21. Execl Throughput                                553.1 lps   (29.9 s, 2 samples)
  22. File Copy 1024 bufsize 2000 maxblocks         81475.1 KBps  (30.1 s, 2 samples)
  23. File Copy 256 bufsize 500 maxblocks           22571.4 KBps  (30.0 s, 2 samples)
  24. File Copy 4096 bufsize 8000 maxblocks        228155.5 KBps  (30.0 s, 2 samples)
  25. Pipe Throughput                              140352.5 lps   (10.0 s, 7 samples)
  26. Pipe-based Context Switching                  12133.6 lps   (10.1 s, 7 samples)
  27. Process Creation                               1438.2 lps   (30.0 s, 2 samples)
  28. Shell Scripts (1 concurrent)                   2313.7 lpm   (60.0 s, 2 samples)
  29. Shell Scripts (8 concurrent)                    361.2 lpm   (60.1 s, 2 samples)
  30. System Call Overhead                          90826.3 lps   (10.1 s, 7 samples)
  31. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  32. Dhrystone 2 using register variables         116700.0    7441283.5    637.6
  33. Double-Precision Whetstone                       55.0       1196.9    217.6
  34. Execl Throughput                                 43.0        553.1    128.6
  35. File Copy 1024 bufsize 2000 maxblocks          3960.0      81475.1    205.7
  36. File Copy 256 bufsize 500 maxblocks            1655.0      22571.4    136.4
  37. File Copy 4096 bufsize 8000 maxblocks          5800.0     228155.5    393.4
  38. Pipe Throughput                               12440.0     140352.5    112.8
  39. Pipe-based Context Switching                   4000.0      12133.6     30.3
  40. Process Creation                                126.0       1438.2    114.1
  41. Shell Scripts (1 concurrent)                     42.4       2313.7    545.7
  42. Shell Scripts (8 concurrent)                      6.0        361.2    602.1
  43. System Call Overhead                          15000.0      90826.3     60.6
  44.        ========
  45. System Benchmarks Index Score                                         184.3
  46. ------------------------------------------------------------------------
  47. Benchmark Run: Thu Mar 25 2021 20:09:27 - 20:37:52
  48. 4 CPUs in system; running 4 parallel copies of tests
  49. Dhrystone 2 using register variables       25116617.9 lps   (10.1 s, 7 samples)
  50. Double-Precision Whetstone                     4548.5 MWIPS (9.8 s, 7 samples)
  51. Execl Throughput                               1733.2 lps   (30.0 s, 2 samples)
  52. File Copy 1024 bufsize 2000 maxblocks        141888.8 KBps  (30.0 s, 2 samples)
  53. File Copy 256 bufsize 500 maxblocks           38450.6 KBps  (30.0 s, 2 samples)
  54. File Copy 4096 bufsize 8000 maxblocks        418783.7 KBps  (30.0 s, 2 samples)
  55. Pipe Throughput                              467805.1 lps   (10.0 s, 7 samples)
  56. Pipe-based Context Switching                  83888.2 lps   (10.1 s, 7 samples)
  57. Process Creation                               3060.3 lps   (30.1 s, 2 samples)
  58. Shell Scripts (1 concurrent)                   2551.8 lpm   (60.1 s, 2 samples)
  59. Shell Scripts (8 concurrent)                    370.7 lpm   (60.3 s, 2 samples)
  60. System Call Overhead                         291906.5 lps   (10.1 s, 7 samples)
  61. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  62. Dhrystone 2 using register variables         116700.0   25116617.9   2152.2
  63. Double-Precision Whetstone                       55.0       4548.5    827.0
  64. Execl Throughput                                 43.0       1733.2    403.1
  65. File Copy 1024 bufsize 2000 maxblocks          3960.0     141888.8    358.3
  66. File Copy 256 bufsize 500 maxblocks            1655.0      38450.6    232.3
  67. File Copy 4096 bufsize 8000 maxblocks          5800.0     418783.7    722.0
  68. Pipe Throughput                               12440.0     467805.1    376.0
  69. Pipe-based Context Switching                   4000.0      83888.2    209.7
  70. Process Creation                                126.0       3060.3    242.9
  71. Shell Scripts (1 concurrent)                     42.4       2551.8    601.8
  72. Shell Scripts (8 concurrent)                      6.0        370.7    617.9
  73. System Call Overhead                          15000.0     291906.5    194.6
  74.        ========
  75. System Benchmarks Index Score                                         444.7
  76. ======= Script description and score comparison completed! =======
刚又用柠檬测了一次,一样的!
  1. -> CPU Performance Test (Standard Mode, 3-Pass @ 30sec)
  2. 1 Thread Test:                 191 Scores
  3. 4 Threads Test:                664 Scores
发表于 2021-3-25 20:45:44 来自手机 | 只看该作者
下次接着上车
哈哈哈哈哈,xswl  发表于 2021-3-26 02:01
笑死我了  发表于 2021-3-25 21:38
发表于 2021-3-25 21:52:05 | 只看该作者
楼主 @lovexu 是不是 @alenxu 的小号~
发表于 2021-3-26 08:58:39 来自手机 | 只看该作者
商家都说了能ssh就行了,还要求这么高
发表于 2021-3-26 02:21:59 | 只看该作者
发表于 2021-3-25 22:48:16 | 只看该作者
一家毫无信誉的商家,立身之本都被他们拿去塞pi眼了。
看见低价“高配”,就又一窝蜂的扑上去买。
说到底买的人还是赌一把嘛,垃圾pr赌你们心痒手贱,你们赌pr不跑路良心捡回来一次。
怎么看,怎么都是双赢的局面(一方买了,一方没跑路,皆大欢喜皆大欢喜)。
期待垃圾pr下一次的惊喜价,图的就是个热闹
发表于 2021-3-25 20:53:44 | 只看该作者
换个开心脚本自己开心一下
发表于 2021-3-26 05:40:57 | 只看该作者
发表于 2021-3-25 20:53:38 | 只看该作者
真的被 新活动 15刀的,挤一挤??
发表于 2021-3-25 20:49:06 | 只看该作者
没啥好说的,只想
哈哈哈哈哈哈
发表于 2021-3-25 20:43:22 | 只看该作者
喜闻乐见 MJJ就是没有记性
 楼主| 发表于 2021-3-25 20:44:53 | 只看该作者
ccf 发表于 2021-3-25 20:43
喜闻乐见 MJJ就是没有记性
四核分数还没买的时候单核分数高!这是什么操作!!还没我之前在PR买的双核性能高!
发表于 2021-3-25 20:46:32 | 只看该作者
不是以LemonBench为准吗
发表于 2021-3-25 20:47:19 | 只看该作者
发表于 2021-3-25 20:47:58 | 只看该作者
就是多你一个小白,增加了他们的收入,以后别进坑了
GMT+8, 2026-4-22 02:36 , Processed in 0.080779 second(s), 12 queries , Gzip On, MemCache On.
