查看: 1482|回复: 8
我也来一波pr在线测速,蹭个快照
发表于 2021-3-21 13:26:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在线测速地址,开了BBR
pr.want.ml
四川电信现在是能给我带宽跑满的
  1. wget -qO- yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2020-12-29                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Sun Mar 21 04:12:55 UTC 2021
  8. Basic System Information:
  9. ---------------------------------
  10. Processor  : Intel(R) Xeon(R) CPU E5-2650 v2 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  11. CPU cores  : 4 @ 2599.998 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 5.8 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 78.7 GiB
  17. fio Disk Speed Tests (Mixed R/W 50/50):
  18. ---------------------------------
  19. Block Size | 4k            (IOPS) | 64k           (IOPS)
  20.   ------   | ---            ----  | ----           ----
  21. Read       | 136.38 MB/s  (34.0k) | 1.11 GB/s    (17.3k)
  22. Write      | 136.73 MB/s  (34.1k) | 1.11 GB/s    (17.4k)
  23. Total      | 273.11 MB/s  (68.2k) | 2.22 GB/s    (34.8k)
  24.            |                      |
  25. Block Size | 512k          (IOPS) | 1m            (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 1.18 GB/s     (2.3k) | 1.19 GB/s     (1.1k)
  28. Write      | 1.24 GB/s     (2.4k) | 1.27 GB/s     (1.2k)
  29. Total      | 2.42 GB/s     (4.7k) | 2.47 GB/s     (2.4k)
  30. iperf3 Network Speed Tests (IPv4):
  31. ---------------------------------
  32. Provider        | Location (Link)           | Send Speed      | Recv Speed
  33.                 |                           |                 |
  34. Clouvider       | London, UK (10G)          | 852 Mbits/sec   | 258 Mbits/sec
  35. Online.net      | Paris, FR (10G)           | 849 Mbits/sec   | 155 Mbits/sec
  36. WorldStream     | The Netherlands (10G)     | 726 Mbits/sec   | 357 Mbits/sec
  37. Biznet          | Jakarta, Indonesia (1G)   | 728 Mbits/sec   | 155 Mbits/sec
  38. Clouvider       | NYC, NY, US (10G)         | 907 Mbits/sec   | 358 Mbits/sec
  39. Velocity Online | Tallahassee, FL, US (10G) | 877 Mbits/sec   | 267 Mbits/sec
  40. Clouvider       | Los Angeles, CA, US (10G) | 901 Mbits/sec   | 889 Mbits/sec
  41. Iveloz Telecom  | Sao Paulo, BR (2G)        | 732 Mbits/sec   | 115 Mbits/sec
  42. Geekbench 5 Benchmark Test:
  43. ---------------------------------
  44. Test            | Value
  45.                 |
  46. Single Core     | 609
  47. Multi Core      | 2149
  48. Full Test       | https://browser.geekbench.com/v5/cpu/7048001
发表于 2021-3-21 13:36:49 | 只看该作者
牛逼,我这边下载居然有10多M, 测速的平台用什么脚本搭建的? 给一个,我也去建一个测测
 楼主| 发表于 2021-3-21 13:43:19 | 只看该作者
tempok 发表于 2021-3-21 13:36
牛逼,我这边下载居然有10多M, 测速的平台用什么脚本搭建的? 给一个,我也去建一个测测 ...
就是Nginx,我是ubuntu,
  1. apt-get install nginx
安装Nginx,然后在 /etc/nginx/conf.d/ 目录下建一个nginx.conf配置文件,里面的配置是:
  1. server {
  2.         listen       80; #端口
  3.         server_name  pr.want.ml; #服务名
  4.         charset utf-8;  #避免中文乱码
  5.         root   /download; #显示的根索引目录,注意这里要改成你自己的,目录要存在
  6.         location / {
  7.             autoindex on; #开启索引功能
  8.             autoindex_exact_size off; #关闭计算文件确切大小(单位bytes),只显示大概大小(单位kb、mb、gb)
  9.             autoindex_localtime on; #显示本机时间而非 GMT 时间
  10.         }
  11. }
然后nginx -s reload 刷新一下Nginx的配置就可以了
在/目录下面建一个文件夹 download
  1. dd if=/dev/zero of=50M bs=1M count=50
这样可以造空文件,of=后面这个是文件名,count=这个后面是多少兆的文件,这个命令在/download 的目录下执行
发表于 2021-3-21 13:45:04 | 只看该作者
谢谢,我试试
发表于 2021-3-21 13:47:10 来自手机 | 只看该作者
300k/s 北方电信
发表于 2021-3-21 13:52:52 来自手机 | 只看该作者
快照得发测速贴子才给吗?是的话我也发一个
好像是得发个评测贴,测速到不一定  发表于 2021-3-21 13:56
发表于 2021-3-21 14:01:34 | 只看该作者
我只能说峰值最高900KB,然后速度越来越垃,不知道是不是同时测的多了
可能地区不同吧,我这里现在还能跑满带宽  发表于 2021-3-21 14:04
GMT+8, 2026-4-24 15:56 , Processed in 0.068797 second(s), 15 queries , Gzip On, MemCache On.
