查看: 1567|回复: 6
昨晚的PR单核居然达到了812。恭喜我
发表于 2021-3-21 09:52:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Bench Start Time:        2021-03-21 01:42:00
Bench Finish Time:        2021-03-21 01:45:52
Test Mode:                Fast Mode
-> System Information
OS Release:                Ubuntu 20.04.1 LTS (Focal Fossa)  (x86_64)
CPU Model:                Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz  2.60 GHz
CPU Cache Size:        16384 KB
CPU Number:                4 vCPU
Virt Type:                KVM
Memory Usage:                294.25 MB / 5.81 GB
Swap Usage:                [ No Swapfile / Swap partition ]
Disk Usage:                2.58 GB / 82.50 GB
Boot Device:                /dev/vda2
Load (1/5/15min):        0.62 0.24 0.08
CPU Usage:                3.1% used, 0.0% iowait, 0.0% steal
Kernel Version:        5.4.0-42-generic
Network CC Method:        bbr + fq
-> Network Information
IPV4 - IP Address:        [US] 155.94.128.*
IPV4 - ASN Info:        8100 (ASN-QUADRANET-GLOBAL - QuadraNet Enterprises LLC, US)
IPV4 - Region:                United States California Los Angeles
-> Media Unlock Test
HBO Now:                                Yes
Bahamut Anime:                                No
Abema.TV:                                No
Princess Connect Reive Japan:        No
BBC:                                        No
Bilibili China Mainland Only:                No
Bilibili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                        No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                        812 Scores
4 Threads Test:                2903 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :                17282.87 MB/s
1 Thread - Write Test:                13691.09 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name                Write Speed                                Read Speed
100MB-4K Block                23.8 MB/s (5801 IOPS, 4.41 s)                32.6 MB/s (7961 IOPS, 3.22 s)
1GB-1M Block                207 MB/s (197 IOPS, 5.07 s)                1.9 GB/s (1768 IOPS, 0.57 s)
-> Speedtest.net Network Speed Test
Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
Speedtest Default                107.04 MB/s        107.32 MB/s        0.50 ms                Windstream (United States Los Angeles, CA)
China, Beijing CU                  46.41 MB/s        21.55 MB/s        186.63 ms        Beijing Unicom (China Beijing)
China, Shanghai CT                 11.28 MB/s        67.88 MB/s        133.29 ms        China Telecom (China Shanghai)
China, Hangzhou CM                 Fail: Timeout Exceeded after 60 seconds
发表于 2021-3-21 09:58:04 来自手机 | 只看该作者
https://loc.qiche.eu.org/forum.php?mod=viewthread&tid=820866
发表于 2021-3-21 10:00:21 | 只看该作者
喜获传家宝
 楼主| 发表于 2021-3-21 10:00:38 | 只看该作者
昨晚我DD win两次都不成功,vnc又打不开,所以还是只有用ubuntu了。买都买了还不是只有将就用来吃灰。
发表于 2021-3-21 10:02:19 | 只看该作者
lovexu 发表于 2021-3-21 10:00
昨晚我DD win两次都不成功,vnc又打不开,所以还是只有用ubuntu了。买都买了还不是只有将就用来吃灰。 ...
别D了,上一个Dwin的已经封机了
GMT+8, 2026-4-22 02:34 , Processed in 0.066239 second(s), 10 queries , Gzip On, MemCache On.
