查看: 2189|回复: 26
【单核352分4核800分】PR20.21测试Unix Bench和lemonbench,翻车警告!
发表于 2021-3-20 17:27:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
节点STACK-3630-2
  1. LemonBench Server Test Tookit 20201005 Intl BetaVersion (C)iLemonrain. All Rights Reserved.
  2. ==========================================================================================
  3. [Info] Bench Start Time: 2021-03-20 16:59:12
  4. [Info] Test Mode: Fast Mode
  5. -> System Information
  6. OS Release:            CentOS Linux 7.8.2003 (x86_64)
  7. CPU Model:             Intel(R) Xeon(R) CPU E5-2650 v2 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz  2.60 GHz
  8. CPU Cache Size:        16384 KB
  9. CPU Number:            4 vCPU
  10. VirtReady:             Yes (Nested Virtualization)
  11. Virt Type:             KVM
  12. Memory Usage:          191.27 MB / 5.67 GB
  13. Swap Usage:            [ No Swapfile/Swap Partition ]
  14. Boot Device:           /dev/vda1
  15. Disk Usage:            1.78 GB / 82.54 GB
  16. CPU Usage:             3.0% used, 0.0% iowait, 4.5% steal
  17. Load (1/5/15min):      0.28 0.23 0.80
  18. Uptime:                0 Days, 4 Hours, 53 Minutes, 16 Seconds
  19. Kernel Version:        3.10.0-1127.el7.x86_64
  20. Network CC Method:     cubic + pfifo_fast
  21. -> Network Infomation
  22. IPV4 - IP Address:     [US] 107.150.6.22
  23. IPV4 - ASN Info:       AS8100 (ASN-QUADRANET-GLOBAL - QuadraNet Enterprises LLC, US)
  24. IPV4 - Region:         United States California Los Angeles
  25. -> Media Unlock Test
  26. HBO Now:                               Yes
  27. Bahamut Anime:                         No
  28. Abema.TV:                              No
  29. Princess Connect Re:Dive Japan:        No
  30. BBC:                                   No
  31. BiliBili China Mainland Only:          No
  32. BiliBili Hongkong/Macau/Taiwan:        No
  33. Bilibili Taiwan Only:                  No
  34. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  35. 1 Thread Test:                 669 Scores
  36. 4 Threads Test:                2408 Scores
  37. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  38. 1 Thread - Read Test :         13577.81 MB/s
  39. 1 Thread - Write Test:         9471.01 MB/s
  40. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  41. Test Name              Write Speed                             Read Speed
  42. 100MB-4K Block         6.7 MB/s (1644 IOPS, 15.57s)            8.8 MB/s (2156 IOPS, 11.87s)
  43. 1GB-1M Block           298 MB/s (283 IOPS, 3.52s)              581 MB/s (553 IOPS, 1.81s)
  44. -> Speedtest.net Network Speed Test
  45. Node Name                      Upload Speed    Download Speed  Ping Latency   Server Name
  46. Speedtest Default              86.43 MB/s      28.61 MB/s      25.46 ms       Frontier (United States Los Angeles, CA)
  47. China, Beijing CU              0.30 MB/s       2.51 MB/s       171.35 ms      Beijing Unicom (China Beijing)
  48. China, Shanghai CT             0.08 MB/s       0.67 MB/s       148.22 ms      China Telecom (China Shanghai)
  49. China, Hangzhou CM             Fail: Timeout Exceeded after 60 seconds
unix bench
  1.    BYTE UNIX Benchmarks (Version 5.1.3)
  2.    System: C20210320118376: GNU/Linux
  3.    OS: GNU/Linux -- 3.10.0-1127.el7.x86_64 -- #1 SMP Tue Mar 31 23:36:51 UTC 2020
  4.    Machine: x86_64 (x86_64)
  5.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  6.    CPU 0: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  7.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  8.    CPU 1: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  9.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  10.    CPU 2: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  11.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  12.    CPU 3: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  13.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
  14.    17:42:18 up  5:36,  1 user,  load average: 0.15, 0.17, 0.14; runlevel 3
  15. ------------------------------------------------------------------------
  16. Benchmark Run: Sat Mar 20 2021 17:42:18 - 18:10:32
  17. 4 CPUs in system; running 1 parallel copy of tests
  18. Dhrystone 2 using register variables       22908008.7 lps   (10.0 s, 7 samples)
  19. Double-Precision Whetstone                     3671.6 MWIPS (9.7 s, 7 samples)
  20. Execl Throughput                                467.4 lps   (29.7 s, 2 samples)
  21. File Copy 1024 bufsize 2000 maxblocks        200650.0 KBps  (30.0 s, 2 samples)
  22. File Copy 256 bufsize 500 maxblocks           53696.5 KBps  (30.0 s, 2 samples)
  23. File Copy 4096 bufsize 8000 maxblocks        542557.0 KBps  (30.0 s, 2 samples)
  24. Pipe Throughput                              322398.6 lps   (10.0 s, 7 samples)
  25. Pipe-based Context Switching                  24927.5 lps   (10.0 s, 7 samples)
  26. Process Creation                               2583.4 lps   (30.0 s, 2 samples)
  27. Shell Scripts (1 concurrent)                   1302.2 lpm   (60.0 s, 2 samples)
  28. Shell Scripts (8 concurrent)                    438.0 lpm   (60.1 s, 2 samples)
  29. System Call Overhead                         343141.6 lps   (10.0 s, 7 samples)
  30. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  31. Dhrystone 2 using register variables         116700.0   22908008.7   1963.0
  32. Double-Precision Whetstone                       55.0       3671.6    667.6
  33. Execl Throughput                                 43.0        467.4    108.7
  34. File Copy 1024 bufsize 2000 maxblocks          3960.0     200650.0    506.7
  35. File Copy 256 bufsize 500 maxblocks            1655.0      53696.5    324.5
  36. File Copy 4096 bufsize 8000 maxblocks          5800.0     542557.0    935.4
  37. Pipe Throughput                               12440.0     322398.6    259.2
  38. Pipe-based Context Switching                   4000.0      24927.5     62.3
  39. Process Creation                                126.0       2583.4    205.0
  40. Shell Scripts (1 concurrent)                     42.4       1302.2    307.1
  41. Shell Scripts (8 concurrent)                      6.0        438.0    730.0
  42. System Call Overhead                          15000.0     343141.6    228.8
  43.        ========
  44. System Benchmarks Index Score                                         352.8
  45. ------------------------------------------------------------------------
  46. Benchmark Run: Sat Mar 20 2021 18:10:32 - 18:39:59
  47. 4 CPUs in system; running 4 parallel copies of tests
  48. Dhrystone 2 using register variables       61723832.4 lps   (10.0 s, 7 samples)
  49. Double-Precision Whetstone                    13953.5 MWIPS (10.1 s, 7 samples)
  50. Execl Throughput                               1609.0 lps   (29.7 s, 2 samples)
  51. File Copy 1024 bufsize 2000 maxblocks        224055.4 KBps  (30.0 s, 2 samples)
  52. File Copy 256 bufsize 500 maxblocks           73775.1 KBps  (30.0 s, 2 samples)
  53. File Copy 4096 bufsize 8000 maxblocks        806289.1 KBps  (30.0 s, 2 samples)
  54. Pipe Throughput                              974428.9 lps   (10.0 s, 7 samples)
  55. Pipe-based Context Switching                 146759.9 lps   (10.0 s, 7 samples)
  56. Process Creation                               4887.8 lps   (30.0 s, 2 samples)
  57. Shell Scripts (1 concurrent)                   4024.6 lpm   (60.1 s, 2 samples)
  58. Shell Scripts (8 concurrent)                    901.1 lpm   (60.1 s, 2 samples)
  59. System Call Overhead                         931619.5 lps   (10.0 s, 7 samples)
  60. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  61. Dhrystone 2 using register variables         116700.0   61723832.4   5289.1
  62. Double-Precision Whetstone                       55.0      13953.5   2537.0
  63. Execl Throughput                                 43.0       1609.0    374.2
  64. File Copy 1024 bufsize 2000 maxblocks          3960.0     224055.4    565.8
  65. File Copy 256 bufsize 500 maxblocks            1655.0      73775.1    445.8
  66. File Copy 4096 bufsize 8000 maxblocks          5800.0     806289.1   1390.2
  67. Pipe Throughput                               12440.0     974428.9    783.3
  68. Pipe-based Context Switching                   4000.0     146759.9    366.9
  69. Process Creation                                126.0       4887.8    387.9
  70. Shell Scripts (1 concurrent)                     42.4       4024.6    949.2
  71. Shell Scripts (8 concurrent)                      6.0        901.1   1501.9
  72. System Call Overhead                          15000.0     931619.5    621.1
  73.        ========
  74. System Benchmarks Index Score                                         864.3
宝塔跑分
单核352.8分,4核总分864分,我是不是翻车了?
别人宝塔8000多接近9000分,我的只有一半??
出来解释一下?
@PacificRack.com
来自 12#
 楼主| 发表于 2021-3-20 20:43:29 | 只看该作者
hxuf 发表于 2021-3-20 20:41
跑个yabs
curl -sL yabs.sh | bash
  1. wget -qO- yabs.sh | bash
  2. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  3. #              Yet-Another-Bench-Script              #
  4. #                     v2020-12-29                    #
  5. # https://github.com/masonr/yet-another-bench-script #
  6. # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
  7. Sat Mar 20 20:32:22 CST 2021
  8. Basic System Information:
  9. ---------------------------------
  10. Processor  : Intel(R) Xeon(R) CPU E5-2650 v2 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz
  11. CPU cores  : 4 @ 2599.998 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 5.7 GiB
  15. Swap       : 0.0 KiB
  16. Disk       : 78.7 GiB
  17. fio Disk Speed Tests (Mixed R/W 50/50):
  18. ---------------------------------
  19. Block Size | 4k            (IOPS) | 64k           (IOPS)
  20.   ------   | ---            ----  | ----           ----
  21. Read       | 24.92 MB/s    (6.2k) | 166.61 MB/s   (2.6k)
  22. Write      | 24.93 MB/s    (6.2k) | 167.48 MB/s   (2.6k)
  23. Total      | 49.86 MB/s   (12.4k) | 334.10 MB/s   (5.2k)
  24.            |                      |
  25. Block Size | 512k          (IOPS) | 1m            (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 273.99 MB/s    (535) | 348.36 MB/s    (340)
  28. Write      | 288.54 MB/s    (563) | 371.56 MB/s    (362)
  29. Total      | 562.54 MB/s   (1.0k) | 719.92 MB/s    (702)
  30. iperf3 Network Speed Tests (IPv4):
  31. ---------------------------------
  32. Provider        | Location (Link)           | Send Speed      | Recv Speed
  33.                 |                           |                 |
  34. Clouvider       | London, UK (10G)          | 684 Mbits/sec   | 121 Mbits/sec
  35. Online.net      | Paris, FR (10G)           | 638 Mbits/sec   | 36.4 Mbits/sec
  36. WorldStream     | The Netherlands (10G)     | 286 Mbits/sec   | 119 Mbits/sec
  37. Biznet          | Jakarta, Indonesia (1G)   | 563 Mbits/sec   | 51.7 Mbits/sec
  38. Clouvider       | NYC, NY, US (10G)         | 608 Mbits/sec   | 56.0 Mbits/sec
  39. Velocity Online | Tallahassee, FL, US (10G) | 696 Mbits/sec   | 151 Mbits/sec
  40. Clouvider       | Los Angeles, CA, US (10G) | 664 Mbits/sec   | 449 Mbits/sec
  41. Iveloz Telecom  | Sao Paulo, BR (2G)        | 459 Mbits/sec   | 31.2 Mbits/sec
  42. Geekbench 5 Benchmark Test:
  43. ---------------------------------
  44. Test            | Value
  45.                 |
  46. Single Core     | 364
  47. Multi Core      | 871
  48. Full Test       | https://browser.geekbench.com/v5/cpu/7037960
来自 14#
 楼主| 发表于 2021-3-20 20:47:57 | 只看该作者
hxuf 发表于 2021-3-20 20:44
翻车了 草坏咯。等过几天瞧瞧性能咋样。
已补充宝塔跑分,论坛里最低分了吧,CPU别人8000多分,我的只有4000分
发表于 2021-3-20 21:28:34 来自手机 | 只看该作者
都2021了还有mjj买pr不会吧不会吧
发表于 2021-3-20 20:33:24 | 只看该作者
喜闻乐见,让你管不住手~
发表于 2021-3-20 17:28:29 | 只看该作者
谢谢分享。有没有跑 UnixBench 呢?
 楼主| 发表于 2021-3-20 17:39:32 | 只看该作者
有跑,单核400多,多核1000分出头,貌似是翻车了?
发表于 2021-3-20 17:39:58 | 只看该作者
翻车了!!!
发表于 2021-3-20 17:41:19 | 只看该作者
这速度没法入手啊
发表于 2021-3-20 17:41:59 | 只看该作者
大佬,求脚本
估计大家都在测试
发表于 2021-3-20 17:44:52 | 只看该作者
PR,始终如一
 楼主| 发表于 2021-3-20 20:28:06 | 只看该作者
已补充UnixBench跑分,请看!!!
发表于 2021-3-20 20:30:30 | 只看该作者
GMT+8, 2026-1-15 08:52 , Processed in 0.072907 second(s), 12 queries , Gzip On, MemCache On.
