查看: 1478|回复: 1
PR20.21 UNIX Benchmarks 跑分
发表于 2021-3-20 00:59:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为毛我的 UNIX Bench 跑分低很多
0.0
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3.    System: C20210319231755: GNU/Linux
  4.    OS: GNU/Linux -- 3.10.0-1127.el7.x86_64 -- #1 SMP Tue Mar 31 23:36:51 UTC 202        0
  5.    Machine: x86_64 (x86_64)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU E5-2650 v2 [url=home.php?mod=space&uid=175]@[/url] 2.60GHz (5200.0 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT,        SYSCALL/SYSRET, Intel virtualization
  9.    CPU 1: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT,        SYSCALL/SYSRET, Intel virtualization
  11.    CPU 2: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT,        SYSCALL/SYSRET, Intel virtualization
  13.    CPU 3: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz (5200.0 bogomips)
  14.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT,        SYSCALL/SYSRET, Intel virtualization
  15.    23:59:54 up 3 min,  1 user,  load average: 0.57, 0.21, 0.08; runlevel 2021-03        -19
  16. ------------------------------------------------------------------------
  17. Benchmark Run: Fri Mar 19 2021 23:59:54 - 00:28:17
  18. 4 CPUs in system; running 1 parallel copy of tests
  19. Dhrystone 2 using register variables       33609041.4 lps   (10.0 s, 7 samples)
  20. Double-Precision Whetstone                     4192.4 MWIPS (9.9 s, 7 samples)
  21. Execl Throughput                               1558.4 lps   (29.6 s, 2 samples)
  22. File Copy 1024 bufsize 2000 maxblocks        367930.7 KBps  (30.0 s, 2 samples)
  23. File Copy 256 bufsize 500 maxblocks          103415.5 KBps  (30.0 s, 2 samples)
  24. File Copy 4096 bufsize 8000 maxblocks       1010614.2 KBps  (30.0 s, 2 samples)
  25. Pipe Throughput                              534741.1 lps   (10.0 s, 7 samples)
  26. Pipe-based Context Switching                  51636.4 lps   (10.0 s, 7 samples)
  27. Process Creation                               5419.7 lps   (30.0 s, 2 samples)
  28. Shell Scripts (1 concurrent)                   3611.6 lpm   (60.0 s, 2 samples)
  29. Shell Scripts (8 concurrent)                   1130.5 lpm   (60.0 s, 2 samples)
  30. System Call Overhead                         497107.5 lps   (10.0 s, 7 samples)
  31. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  32. Dhrystone 2 using register variables         116700.0   33609041.4   2880.0
  33. Double-Precision Whetstone                       55.0       4192.4    762.3
  34. Execl Throughput                                 43.0       1558.4    362.4
  35. File Copy 1024 bufsize 2000 maxblocks          3960.0     367930.7    929.1
  36. File Copy 256 bufsize 500 maxblocks            1655.0     103415.5    624.9
  37. File Copy 4096 bufsize 8000 maxblocks          5800.0    1010614.2   1742.4
  38. Pipe Throughput                               12440.0     534741.1    429.9
  39. Pipe-based Context Switching                   4000.0      51636.4    129.1
  40. Process Creation                                126.0       5419.7    430.1
  41. Shell Scripts (1 concurrent)                     42.4       3611.6    851.8
  42. Shell Scripts (8 concurrent)                      6.0       1130.5   1884.1
  43. System Call Overhead                          15000.0     497107.5    331.4
  44.        ========
  45. System Benchmarks Index Score                                         682.5
  46. ------------------------------------------------------------------------
  47. Benchmark Run: Sat Mar 20 2021 00:28:17 - 00:56:35
  48. 4 CPUs in system; running 4 parallel copies of tests
  49. Dhrystone 2 using register variables       89824562.3 lps   (10.0 s, 7 samples)
  50. Double-Precision Whetstone                    14796.2 MWIPS (9.8 s, 7 samples)
  51. Execl Throughput                               6693.0 lps   (30.0 s, 2 samples)
  52. File Copy 1024 bufsize 2000 maxblocks        630812.9 KBps  (30.0 s, 2 samples)
  53. File Copy 256 bufsize 500 maxblocks          150385.7 KBps  (30.0 s, 2 samples)
  54. File Copy 4096 bufsize 8000 maxblocks       1692152.3 KBps  (30.0 s, 2 samples)
  55. Pipe Throughput                             1832782.7 lps   (10.0 s, 7 samples)
  56. Pipe-based Context Switching                 308151.6 lps   (10.0 s, 7 samples)
  57. Process Creation                              20628.4 lps   (30.0 s, 2 samples)
  58. Shell Scripts (1 concurrent)                  11265.8 lpm   (60.0 s, 2 samples)
  59. Shell Scripts (8 concurrent)                   1761.0 lpm   (60.0 s, 2 samples)
  60. System Call Overhead                        1453054.2 lps   (10.0 s, 7 samples)
  61. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  62. Dhrystone 2 using register variables         116700.0   89824562.3   7697.0
  63. Double-Precision Whetstone                       55.0      14796.2   2690.2
  64. Execl Throughput                                 43.0       6693.0   1556.5
  65. File Copy 1024 bufsize 2000 maxblocks          3960.0     630812.9   1593.0
  66. File Copy 256 bufsize 500 maxblocks            1655.0     150385.7    908.7
  67. File Copy 4096 bufsize 8000 maxblocks          5800.0    1692152.3   2917.5
  68. Pipe Throughput                               12440.0    1832782.7   1473.3
  69. Pipe-based Context Switching                   4000.0     308151.6    770.4
  70. Process Creation                                126.0      20628.4   1637.2
  71. Shell Scripts (1 concurrent)                     42.4      11265.8   2657.0
  72. Shell Scripts (8 concurrent)                      6.0       1761.0   2935.0
  73. System Call Overhead                          15000.0    1453054.2    968.7
  74.        ========
  75. System Benchmarks Index Score                                        1876.9
  76. //
  77. [root@~]# dd if=/dev/zero of=/dev/null bs=1M count=1024
  78. 1024+0 records in
  79. 1024+0 records out
  80. 1073741824 bytes (1.1 GB) copied, 0.084409 s, 12.7 GB/s
  81. [root@~]# dd if=/dev/zero of=/dev/null bs=1M count=1024
  82. 1024+0 records in
  83. 1024+0 records out
  84. 1073741824 bytes (1.1 GB) copied, 0.0642098 s, 16.7 GB/s
  85. [root@~]# dd if=/dev/zero of=file bs=1M count=1024
  86. 1024+0 records in
  87. 1024+0 records out
  88. 1073741824 bytes (1.1 GB) copied, 2.90476 s, 370 MB/s
  89. [root@~]#
  90. [root@~]#
  91. [root@~]# dd if=/dev/zero of=file bs=1M count=1024
  92. 1024+0 records in
  93. 1024+0 records out
  94. 1073741824 bytes (1.1 GB) copied, 3.62339 s, 296 MB/s
发表于 2021-3-20 01:01:39 | 只看该作者
那是你没见过低的。6c6g 第一批机主飘过。
GMT+8, 2026-4-25 02:28 , Processed in 0.063168 second(s), 9 queries , Gzip On, MemCache On.
