查看: 1872|回复: 9
有大佬帮忙看下eth0不能自动启动的原因吗?
发表于 2021-1-23 10:34:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一个月前折腾了甲骨文小鸡,DD了萌咖大佬的debian 9系统,
前段时间看着网卡ens3不舒服,改成了eth0,然后半夜装着了一下宝塔,重启完以后发现失联了。
赶紧开控制台用VNC进去,发现原因是网卡eth0没有启动, ifup eth0就能正常启动网卡。
发现启动时候报错:
  1. failed to start rasie network interfaces
VNC进系统后添加interface 里面
  1. auto eth0
仍然无法启动网卡
systemctl status nework.interfaces查了下错误的是
  1. execstart=/sbin/ifup -a --read-environment (code=exited, status=1/failure)
读到环境里面网卡ifup的status=1,是重启没停止eth0吗?
查了下系统报错日志网卡部分大概是
  1. Jan 22 21:02:21 debian systemd[1]: Started ifup for eth0.
  2. Jan 22 21:02:21 debian systemd[1]: Starting Raise network interfaces...
  3. Jan 22 21:02:21 debian systemd[1]: Starting Create Volatile Files and Directories...
  4. Jan 22 21:02:21 debian systemd[1]: Started Create Volatile Files and Directories.
  5. Jan 22 21:02:21 debian systemd[1]: Starting Network Time Synchronization...
  6. Jan 22 21:02:21 debian systemd[1]: Starting Update UTMP about System Boot/Shutdown...
  7. Jan 22 21:02:21 debian ifup[559]: iptables-restore: line 109 failed
  8. Jan 22 21:02:21 debian sh[534]: iptables-restore: line 109 failed
  9. Jan 22 21:02:21 debian ifup[559]: run-parts: /etc/network/if-pre-up.d/iptables exited with return code 1
  10. Jan 22 21:02:21 debian ifup[559]: ifup: pre-up script failed
  11. Jan 22 21:02:21 debian systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  12. Jan 22 21:02:21 debian sh[534]: run-parts: /etc/network/if-pre-up.d/iptables exited with return code 1
  13. Jan 22 21:02:21 debian systemd[1]: Failed to start Raise network interfaces.
  14. Jan 22 21:02:21 debian sh[534]: ifup: failed to bring up eth0
  15. Jan 22 21:02:21 debian systemd[1]: networking.service: Unit entered failed state.
  16. Jan 22 21:02:21 debian systemd[1]: networking.service: Failed with result 'exit-code'.
  17. Jan 22 21:02:21 debian systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
有没有大佬帮忙看看怎么解决?
发表于 2021-1-23 10:37:44 | 只看该作者
/etc/network/if-pre-up.d/iptables 这脚本发来看看
 楼主| 发表于 2021-1-23 10:39:10 | 只看该作者
  1. #!/bin/bash
  2. /sbin/iptables-restore < /etc/iptables.up.rules
发表于 2021-1-23 10:42:08 | 只看该作者
/etc/iptables.up.rules ,把这里的ens3改成eth0
 楼主| 发表于 2021-1-23 10:42:37 | 只看该作者
大佬,是不是因为宝塔重写了iptables?
发表于 2021-1-23 10:51:02 | 只看该作者
没用过不清楚
发表于 2021-1-23 10:58:54 | 只看该作者
既然是 D9,咋还会用iptable?
 楼主| 发表于 2021-1-23 11:00:23 | 只看该作者
llyang 发表于 2021-1-23 10:58
既然是 D9,咋还会用iptable?
应该是装了宝塔的缘故,宝塔重写编译了iptable
发表于 2021-1-23 11:03:21 | 只看该作者
没用过塔
大约1年左右,不用iptable了
ufw OR firealld
挺好的
 楼主| 发表于 2021-1-23 12:28:51 | 只看该作者
把/etc/network/if-pre-up.d/iptables改成
  1. #!/bin/sh
  2. if [ "${IFACE}" == eth0 ]; then
  3.     /sbin/iptables-restore < /etc/iptables.up.rules
  4. fi
解决了,感谢大佬!!!
GMT+8, 2026-4-16 21:48 , Processed in 0.071143 second(s), 10 queries , Gzip On, MemCache On.
