查看: 1252|回复: 2
[Windows VPS] 只用简单的samba共享用什么系统好?
发表于 2021-1-17 13:57:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
设备垃圾,不能用高级的系统,现在装的 Debian 10,分配了512M的内存,感觉系统占用内存很高,有没有轻量一点的Debian系的系统,单纯用作samba共享给客厅的电视,在电视上看剧。
发表于 2021-1-17 14:02:44 | 只看该作者
发表于 2021-1-17 14:14:35 | 只看该作者
To install and use 64-bit 【【【Xubuntu】】】, you need an Intel or AMD 64-bit processor with at least 512 MB of memory. You can also try Xubuntu with a USB or DVD with the same amount of memory. Keep in mind that running the system from a USB or DVD will be slower than an installed system.
When you install Xubuntu, you need about 8 GB of free space on your hard disk.
Your 32-bit processor needs to support PAE in order to run the 32-bit version of Xubuntu 18.04.
GMT+8, 2026-4-23 06:22 , Processed in 0.065697 second(s), 10 queries , Gzip On, MemCache On.
