查看: 2031|回复: 7
在Contabo买4.99欧VPS被要求验证个人信息
发表于 2021-1-15 18:28:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大佬在Contabo下单用paypal付款后是直接开机了,还是会收到要求验证个人信息的邮件?用那种方式不会被要求提供个人信息?
邮件内容:
Dear Sir or Madam,
Thank you very much for your order at Contabo. We received your payment and are setting up your account.
We are obligated by law to perform customer data verification for each new customer. To fulfill this duty, we need additional information from you.
First of all, we would kindly ask you to provide the following information again, just to make sure there are no typing errors causing the verification issue:
First name:
Last name:
Address:
City:
ZIP code:
Country:
Telephone Number:
In addition to the above please also send us a document that proves the address. This could be:
1. A scan of your passport, driving license or national identity card.
2. A scan of your telephone, electricity, or any other utility bill as long as it contains your name and the address mentioned above.
Please note that the provisioning of your order is on hold until you provide us this data. Once we received all relevant data from you, we will complete the verification process and we will continue the setup of your order right away.
Your cooperation is highly appreciated. Thank you in advance for your input in the process!
If you have any questions or need help, please do not hesitate to contact us.
发表于 2021-1-15 18:30:53 来自手机 | 只看该作者
用paypal账号注册他们家应该不会
无论啥方式都会,德国人就这样,身份信息打点码不就行了
发表于 2021-1-15 18:33:16 来自手机 | 只看该作者
我直接大陆pp『借记卡』付款就没要我验证,大陆ip,自己真实实名信息
发表于 2021-1-15 19:28:54 | 只看该作者
我记得我买的时候,没要什么信息
发表于 2021-1-15 20:19:37 | 只看该作者
我当时买的时候要了,身份证打上点码上个水印发过去就可以了
发表于 2021-1-15 20:22:56 | 只看该作者
身份信息打打码 发过去就过了
德国人很严谨的
发表于 2021-1-15 20:27:52 | 只看该作者
在线生成个身份证发过去不就行了。
GMT+8, 2026-4-24 09:49 , Processed in 0.062006 second(s), 10 queries , Gzip On, MemCache On.
