CeraNetworks网络延迟测速工具IP归属甄别
查看: 7598|回复: 0
关于SoftLayer部分服务器登陆出现DiskCheckup 错误的问题
发表于 2009-2-13 14:30:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3389远程登陆服务器后会提示下面的错误:
这个问题我咨询了softlayer的技术部门,他们给我做了回复如下:
The particular drive controller used in this system does not support reading the SMART information from the drive controller. You can disable this message from appearing by going into the Start/Programs/Startup and removing the DiskCheckup utility from launching on startup. This does not indicate a problem, but rather this extra program we installed on the server can't read the drive information due to lack of support for the drive controller.
意思是这个是因为硬盘控制器不支持DiskCheckup软件读取其SMART信息的原因导致的,可以通过去开始菜单里面把DiskCheckup软件卸载了就不会提示了。这不能说明什么问题,只是说我们安装的服务器额外程序不能读取到驱动器信息因为缺少驱动控制器的支持。
GMT+8, 2026-2-13 03:29 , Processed in 0.062198 second(s), 10 queries , Gzip On, MemCache On.
