查看: 1344|回复: 4
[Windows VPS] 求教,mysql无法启动,报错,请问如何解决啊
发表于 2021-1-3 16:42:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2021-01-03 16:39:33 25990 [Warning] You need to use --log-bin to make --log-slave-updates work.
2021-01-03 16:39:33 25990 [Note] Plugin 'FEDERATED' is disabled.
2021-01-03 16:39:33 25990 [Note] InnoDB: Using atomics to ref count buffer pool pages
2021-01-03 16:39:33 25990 [Note] InnoDB: The InnoDB memory heap is disabled
2021-01-03 16:39:33 25990 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-01-03 16:39:33 25990 [Note] InnoDB: Memory barrier is not used
2021-01-03 16:39:33 25990 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-01-03 16:39:33 25990 [Note] InnoDB: Using Linux native AIO
2021-01-03 16:39:33 25990 [Note] InnoDB: Using CPU crc32 instructions
2021-01-03 16:39:33 25990 [Note] InnoDB: Initializing buffer pool, size = 512.0M
2021-01-03 16:39:33 25990 [Note] InnoDB: Completed initialization of buffer pool
2021-01-03 16:39:33 25990 [Note] InnoDB: Highest supported file format is Barracuda.
2021-01-03 16:39:33 25990 [Note] InnoDB: 128 rollback segment(s) are active.
2021-01-03 16:39:33 25990 [Note] InnoDB: Waiting for purge to start
2021-01-03 16:39:33 25990 [Note] InnoDB: 5.6.50 started; log sequence number 1600684
2021-01-03 16:39:33 25990 [ERROR] --gtid-mode=ON or UPGRADE_STEP_1 or UPGRADE_STEP_2 requires --log-bin and --log-slave-updates
2021-01-03 16:39:33 25990 [ERROR] Aborting
2021-01-03 16:39:33 25990 [Note] Binlog end
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'partition'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'BLACKHOLE'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'ARCHIVE'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_METRICS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMPMEM'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_CMP'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_LOCKS'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'INNODB_TRX'
2021-01-03 16:39:33 25990 [Note] Shutting down plugin 'InnoDB'
2021-01-03 16:39:33 25990 [Note] InnoDB: FTS optimize thread exiting.
2021-01-03 16:39:33 25990 [Note] InnoDB: Starting shutdown...
2021-01-03 16:39:35 25990 [Note] InnoDB: Shutdown completed; log sequence number 1600694
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'CSV'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'MyISAM'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'MRG_MYISAM'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'MEMORY'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'sha256_password'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'mysql_old_password'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'mysql_native_password'
2021-01-03 16:39:35 25990 [Note] Shutting down plugin 'binlog'
2021-01-03 16:39:35 25990 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
发表于 2021-1-3 16:58:50 | 只看该作者
 楼主| 发表于 2021-1-3 17:00:03 | 只看该作者
请教大佬,如何解决啊?
发表于 2021-1-3 17:24:04 | 只看该作者
dqlb123 发表于 2021-1-3 17:00
请教大佬,如何解决啊?
复制他给你的提示,直接百度,不就有了。
发表于 2021-1-3 17:28:32 来自手机 | 只看该作者
禁用 gtid 或者配置 log-bin 选项
GMT+8, 2026-4-24 22:53 , Processed in 0.061827 second(s), 9 queries , Gzip On, MemCache On.
