楼主: flameacheson
[疑问] 【统计】欢迎MJJ们把vps跑分发到本帖方便查询2020.1.18
 楼主| 发表于 2021-1-4 09:46:17 | 只看该作者
宣传 发表于 2021-1-3 22:14
樱花VPS 1核512MB内存
Xeon Gold 6212U
单核1636.4
老哥分数不错,天花板了
32#
发表于 2021-1-14 23:55:37 | 只看该作者
CC双十二
  1. Benchmark Run: Thu Jan 14 2021 14:55:48 - 15:23:47
  2. 2 CPUs in system; running 1 parallel copy of tests
  3. Dhrystone 2 using register variables       29532601.8 lps   (10.0 s, 7 samples)
  4. Double-Precision Whetstone                     4465.4 MWIPS (9.5 s, 7 samples)
  5. Execl Throughput                               2928.6 lps   (29.6 s, 2 samples)
  6. File Copy 1024 bufsize 2000 maxblocks        241196.0 KBps  (30.0 s, 2 samples)
  7. File Copy 256 bufsize 500 maxblocks           65705.1 KBps  (30.0 s, 2 samples)
  8. File Copy 4096 bufsize 8000 maxblocks        755401.7 KBps  (30.0 s, 2 samples)
  9. Pipe Throughput                              402849.2 lps   (10.0 s, 7 samples)
  10. Pipe-based Context Switching                  58728.1 lps   (10.0 s, 7 samples)
  11. Process Creation                               5389.1 lps   (30.0 s, 2 samples)
  12. Shell Scripts (1 concurrent)                   5954.9 lpm   (60.0 s, 2 samples)
  13. Shell Scripts (8 concurrent)                   1119.9 lpm   (60.0 s, 2 samples)
  14. System Call Overhead                         278616.5 lps   (10.0 s, 7 samples)
  15. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  16. Dhrystone 2 using register variables         116700.0   29532601.8   2530.6
  17. Double-Precision Whetstone                       55.0       4465.4    811.9
  18. Execl Throughput                                 43.0       2928.6    681.1
  19. File Copy 1024 bufsize 2000 maxblocks          3960.0     241196.0    609.1
  20. File Copy 256 bufsize 500 maxblocks            1655.0      65705.1    397.0
  21. File Copy 4096 bufsize 8000 maxblocks          5800.0     755401.7   1302.4
  22. Pipe Throughput                               12440.0     402849.2    323.8
  23. Pipe-based Context Switching                   4000.0      58728.1    146.8
  24. Process Creation                                126.0       5389.1    427.7
  25. Shell Scripts (1 concurrent)                     42.4       5954.9   1404.5
  26. Shell Scripts (8 concurrent)                      6.0       1119.9   1866.5
  27. System Call Overhead                          15000.0     278616.5    185.7
  28.        ========
  29. System Benchmarks Index Score                                         635.8
  30. ------------------------------------------------------------------------
  31. Benchmark Run: Thu Jan 14 2021 15:23:47 - 15:51:56
  32. 2 CPUs in system; running 2 parallel copies of tests
  33. Dhrystone 2 using register variables       58576158.2 lps   (10.0 s, 7 samples)
  34. Double-Precision Whetstone                     8840.7 MWIPS (9.4 s, 7 samples)
  35. Execl Throughput                               5068.6 lps   (30.0 s, 2 samples)
  36. File Copy 1024 bufsize 2000 maxblocks        419538.0 KBps  (30.0 s, 2 samples)
  37. File Copy 256 bufsize 500 maxblocks          109847.4 KBps  (30.0 s, 2 samples)
  38. File Copy 4096 bufsize 8000 maxblocks       1268833.1 KBps  (30.0 s, 2 samples)
  39. Pipe Throughput                              764119.0 lps   (10.0 s, 7 samples)
  40. Pipe-based Context Switching                 208419.3 lps   (10.0 s, 7 samples)
  41. Process Creation                              10364.3 lps   (30.0 s, 2 samples)
  42. Shell Scripts (1 concurrent)                   8570.1 lpm   (60.0 s, 2 samples)
  43. Shell Scripts (8 concurrent)                   1290.4 lpm   (60.0 s, 2 samples)
  44. System Call Overhead                         507143.5 lps   (10.0 s, 7 samples)
  45. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  46. Dhrystone 2 using register variables         116700.0   58576158.2   5019.4
  47. Double-Precision Whetstone                       55.0       8840.7   1607.4
  48. Execl Throughput                                 43.0       5068.6   1178.7
  49. File Copy 1024 bufsize 2000 maxblocks          3960.0     419538.0   1059.4
  50. File Copy 256 bufsize 500 maxblocks            1655.0     109847.4    663.7
  51. File Copy 4096 bufsize 8000 maxblocks          5800.0    1268833.1   2187.6
  52. Pipe Throughput                               12440.0     764119.0    614.2
  53. Pipe-based Context Switching                   4000.0     208419.3    521.0
  54. Process Creation                                126.0      10364.3    822.6
  55. Shell Scripts (1 concurrent)                     42.4       8570.1   2021.3
  56. Shell Scripts (8 concurrent)                      6.0       1290.4   2150.7
  57. System Call Overhead                          15000.0     507143.5    338.1
  58.        ========
  59. System Benchmarks Index Score                                        1155.4
OK 感谢老哥支持  发表于 2021-1-15 06:42
33#
发表于 2021-1-18 17:10:09 | 只看该作者
hosteons 1C512M5G 100M无限流量
https://paste.ubuntu.com/p/GQxyXt8mNZ/
loc感谢有你!  发表于 2021-1-19 20:44
GMT+8, 2026-4-27 05:31 , Processed in 0.062161 second(s), 8 queries , Gzip On, MemCache On.
