楼主: flameacheson
[疑问] 【统计】欢迎MJJ们把vps跑分发到本帖方便查询2020.1.18
发表于 2021-1-3 22:49:21 | 只看该作者
Hotlineservers-洛杉矶锐龙3900,512M-10GSSD-1G口-10T流量-1.58刀月付
Quantumcore-澳洲KVM,1G-30GSSD-1G-1T流量-7.5刀/年
  1. ------------------------------------------------------------------------
  2. Benchmark Run: Sun Jan 03 2021 09:06:12 - 09:34:26
  3. 1 CPU in system; running 1 parallel copy of tests
  4. Dhrystone 2 using register variables       35917101.4 lps   (10.0 s, 7 samples)
  5. Double-Precision Whetstone                     4645.9 MWIPS (9.7 s, 7 samples)
  6. Execl Throughput                               3709.4 lps   (29.5 s, 2 samples)
  7. File Copy 1024 bufsize 2000 maxblocks        265156.5 KBps  (30.0 s, 2 samples)
  8. File Copy 256 bufsize 500 maxblocks           67594.6 KBps  (30.0 s, 2 samples)
  9. File Copy 4096 bufsize 8000 maxblocks        857055.7 KBps  (30.0 s, 2 samples)
  10. Pipe Throughput                              378673.5 lps   (10.0 s, 7 samples)
  11. Pipe-based Context Switching                  89372.2 lps   (10.0 s, 7 samples)
  12. Process Creation                               8882.8 lps   (30.0 s, 2 samples)
  13. Shell Scripts (1 concurrent)                   5295.5 lpm   (60.0 s, 2 samples)
  14. Shell Scripts (8 concurrent)                    721.9 lpm   (60.0 s, 2 samples)
  15. System Call Overhead                         227704.7 lps   (10.0 s, 7 samples)
  16. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  17. Dhrystone 2 using register variables         116700.0   35917101.4   3077.7
  18. Double-Precision Whetstone                       55.0       4645.9    844.7
  19. Execl Throughput                                 43.0       3709.4    862.6
  20. File Copy 1024 bufsize 2000 maxblocks          3960.0     265156.5    669.6
  21. File Copy 256 bufsize 500 maxblocks            1655.0      67594.6    408.4
  22. File Copy 4096 bufsize 8000 maxblocks          5800.0     857055.7   1477.7
  23. Pipe Throughput                               12440.0     378673.5    304.4
  24. Pipe-based Context Switching                   4000.0      89372.2    223.4
  25. Process Creation                                126.0       8882.8    705.0
  26. Shell Scripts (1 concurrent)                     42.4       5295.5   1248.9
  27. Shell Scripts (8 concurrent)                      6.0        721.9   1203.2
  28. System Call Overhead                          15000.0     227704.7    151.8
  29.        ========
  30. System Benchmarks Index Score                                         680.8
Altantic-旧金山KVM,1G-30GSSD-100M-3T流量- 免费
  2. Benchmark Run: Sun Jan 03 2021 09:06:08 - 09:34:43
  4. Dhrystone 2 using register variables       20233929.3 lps   (10.0 s, 7 samples)
  5. Double-Precision Whetstone                     2920.3 MWIPS (10.0 s, 7 samples)
  6. Execl Throughput                               1776.9 lps   (30.0 s, 2 samples)
  7. File Copy 1024 bufsize 2000 maxblocks        131258.0 KBps  (30.0 s, 2 samples)
  8. File Copy 256 bufsize 500 maxblocks           35603.0 KBps  (30.0 s, 2 samples)
  9. File Copy 4096 bufsize 8000 maxblocks        407927.1 KBps  (30.0 s, 2 samples)
  10. Pipe Throughput                              190473.5 lps   (10.0 s, 7 samples)
  11. Pipe-based Context Switching                  42036.2 lps   (10.0 s, 7 samples)
  12. Process Creation                               4107.3 lps   (30.0 s, 2 samples)
  13. Shell Scripts (1 concurrent)                   2557.0 lpm   (60.0 s, 2 samples)
  14. Shell Scripts (8 concurrent)                    345.5 lpm   (60.1 s, 2 samples)
  15. System Call Overhead                         152747.5 lps   (10.0 s, 7 samples)
  17. Dhrystone 2 using register variables         116700.0   20233929.3   1733.8
  18. Double-Precision Whetstone                       55.0       2920.3    531.0
  19. Execl Throughput                                 43.0       1776.9    413.2
  20. File Copy 1024 bufsize 2000 maxblocks          3960.0     131258.0    331.5
  21. File Copy 256 bufsize 500 maxblocks            1655.0      35603.0    215.1
  22. File Copy 4096 bufsize 8000 maxblocks          5800.0     407927.1    703.3
  23. Pipe Throughput                               12440.0     190473.5    153.1
  24. Pipe-based Context Switching                   4000.0      42036.2    105.1
  25. Process Creation                                126.0       4107.3    326.0
  26. Shell Scripts (1 concurrent)                     42.4       2557.0    603.1
  27. Shell Scripts (8 concurrent)                      6.0        345.5    575.9
  28. System Call Overhead                          15000.0     152747.5    101.8
  29.        ========
  30. System Benchmarks Index Score                                         351.4
Virmach亚特兰大8.03刀KVM,1.6G-15GHDD-3T流量
  2. Benchmark Run: Sun Jan 03 2021 09:18:06 - 09:46:36
  4. Dhrystone 2 using register variables       16677597.1 lps   (10.0 s, 7 samples)
  5. Double-Precision Whetstone                     2604.5 MWIPS (9.9 s, 7 samples)
  6. Execl Throughput                               1706.8 lps   (29.5 s, 2 samples)
  7. File Copy 1024 bufsize 2000 maxblocks        260286.9 KBps  (30.0 s, 2 samples)
  8. File Copy 256 bufsize 500 maxblocks           75559.0 KBps  (30.0 s, 2 samples)
  9. File Copy 4096 bufsize 8000 maxblocks        677248.9 KBps  (30.0 s, 2 samples)
  10. Pipe Throughput                              483100.6 lps   (10.0 s, 7 samples)
  11. Pipe-based Context Switching                  61124.7 lps   (10.0 s, 7 samples)
  12. Process Creation                               3640.9 lps   (30.0 s, 2 samples)
  13. Shell Scripts (1 concurrent)                   2748.7 lpm   (60.0 s, 2 samples)
  14. Shell Scripts (8 concurrent)                    361.5 lpm   (60.1 s, 2 samples)
  15. System Call Overhead                         329729.0 lps   (10.0 s, 7 samples)
  17. Dhrystone 2 using register variables         116700.0   16677597.1   1429.1
  18. Double-Precision Whetstone                       55.0       2604.5    473.6
  19. Execl Throughput                                 43.0       1706.8    396.9
  20. File Copy 1024 bufsize 2000 maxblocks          3960.0     260286.9    657.3
  21. File Copy 256 bufsize 500 maxblocks            1655.0      75559.0    456.6
  22. File Copy 4096 bufsize 8000 maxblocks          5800.0     677248.9   1167.7
  23. Pipe Throughput                               12440.0     483100.6    388.3
  24. Pipe-based Context Switching                   4000.0      61124.7    152.8
  25. Process Creation                                126.0       3640.9    289.0
  26. Shell Scripts (1 concurrent)                     42.4       2748.7    648.3
  27. Shell Scripts (8 concurrent)                      6.0        361.5    602.4
  28. System Call Overhead                          15000.0     329729.0    219.8
  29.        ========
  30. System Benchmarks Index Score                                         476.9
22#
发表于 2021-1-3 23:18:46 | 只看该作者
2021 RackNerd新年 - 闪售第六波 3 个核心 75 GB SSD 硬盘 5.5 GB 内存 闪售价格: $25.88 /年,续费同价
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                 724 Scores
3 Threads Test:                2105 Scores
https://paste.ubuntu.com/p/DVZdhsbJbF/
23#
发表于 2021-1-3 23:22:19 | 只看该作者
看看还不错哦。
24#
发表于 2021-1-3 23:26:02 | 只看该作者
哪位大佬做一个测评脚本,直接提交到一个数据库,就爽歪歪了
25#
发表于 2021-1-3 23:30:09 | 只看该作者
甲骨文韩国 1200分怕不是开玩笑
我手里两个加起来不到600分
我在跑分的时候甲骨文的CPU最多占用一半,很奇怪  发表于 2021-1-4 09:41
26#
发表于 2021-1-4 02:13:52 | 只看该作者
发表于 2021-1-4 02:16:20 | 只看该作者
发表于 2021-1-4 08:27:38 | 只看该作者
https://www.loc.qiche.eu.org/thread-791835-1-1.html
RN新年第三波
29#
 楼主| 发表于 2021-1-4 09:29:10 | 只看该作者
RN新年第三波
收集好啦。老弟,不对MJJ,等会儿上图
30#
 楼主| 发表于 2021-1-4 09:39:19 | 只看该作者
1 Thread Test:                 729 Scores
数据统计上去啦
GMT+8, 2026-4-27 05:32 , Processed in 0.065122 second(s), 8 queries , Gzip On, MemCache On.
