查看: 1032|回复: 2
测了下la3.6和la5.0,做个记录
发表于 2020-12-23 09:14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3.6是秒开的,5.0这两天刚开
3.6的:
-> System Information
OS Release:                Debian GNU/Linux "Jessie" 8.0 (x86_64)
CPU Model:                Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz  2.50 GHz
CPU Cache Size:        4096 KB
CPU Number:                2 vCPU
Virt Type:                KVM
Memory Usage:                77.95 MB / 226.48 MB
Swap Usage:                0 KB / 256.00 MB
Disk Usage:                1.38 GB / 4.87 GB
Boot Device:                /dev/vda1
Load (1/5/15min):        0.36 0.13 0.05
CPU Usage:                0.3% used, 0.1% iowait, 2.4% steal
Kernel Version:        5.10.0
Network CC Method:        bbr + fq_pie
-> Network Information
IPV4 - IP Address:
IPV4 - ASN Info:        36352 (AS-COLOCROSSING - ColoCrossing, US)
IPV4 - Region:                United States California Los Angeles
-> Media Unlock Test
HBO Now:                                Yes
Bahamut Anime:                                No
Abema.TV:                                No
Princess Connect Reive Japan:        Yes
BBC:                                        No
Bilibili China Mainland Only:                No
Bilibili Hongkong/Macau/Taiwan:        No
Bilibili Taiwan Only:                        No
-> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread Test:                        547 Scores
2 Threads Test:                1050 Scores
-> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
1 Thread - Read Test :                11954.24 MB/s
1 Thread - Write Test:                7867.88 MB/s
-> Disk Speed Test (4K Block/1M Block, Direct Mode)
Test Name                Write Speed                                Read Speed
100MB-4K Block                18.0 MB/s (4392 IOPS, 5.83 s)                19.2 MB/s (4685 IOPS, 5.46 s)
1GB-1M Block                1.1 GB/s (1087 IOPS, 0.92 s)                1.5 GB/s (1424 IOPS, 0.70 s)
-> Speedtest.net Network Speed Test
Node Name                        Upload Speed        Download Speed        Ping Latency        Server Name
Speedtest Default                55.26 MB/s        142.94 MB/s        20.98 ms        Inyo Networks Inc (United States Los Angeles, CA)
China, Beijing CU                  2.80 MB/s        47.48 MB/s        208.16 ms        Beijing Unicom (China Beijing)
China, Shanghai CT                 8.18 MB/s        127.81 MB/s        132.64 ms        China Telecom (China Shanghai)
China, Hangzhou CM                 5.33 MB/s        21.89 MB/s        277.86 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
5.0
OS Release:                Debian GNU/Linux "Buster" 10.1 (x86_64)
CPU Model:                QEMU Virtual CPU version (cpu64-rhel6)  2.50 GHz
CPU Number:                2 vCPU
Virt Type:                KVM
Memory Usage:                144.68 MB / 1.95 GB
Disk Usage:                1.21 GB / 10.04 GB
Load (1/5/15min):        0.20 0.05 0.02
CPU Usage:                17.7% used, 0.0% iowait, 2.9% steal
Kernel Version:        4.19.0-6-amd64
IPV4 - IP Address:
HBO Now:                                Yes
Bahamut Anime:                                No
Abema.TV:                                No
BBC:                                        No
1 Thread Test:                        651 Scores
2 Threads Test:                1282 Scores
1 Thread - Read Test :                11178.81 MB/s
1 Thread - Write Test:                8979.09 MB/s
100MB-4K Block                13.9 MB/s (3387 IOPS, 7.56 s)                16.5 MB/s (4017 IOPS, 6.37 s)
1GB-1M Block                525 MB/s (500 IOPS, 2.00 s)                697 MB/s (664 IOPS, 1.51 s)
Speedtest Default                166.22 MB/s        51.27 MB/s        43.56 ms        Sprint (United States Enid, OK)
China, Beijing CU                  Fail: Latency test failed for both TCP, and no HTTP URL available.
China, Shanghai CT                 24.38 MB/s        53.99 MB/s        154.88 ms        China Telecom (China Shanghai)
China, Hangzhou CM                 6.35 MB/s              45.56 MB/s               276.19 ms        China Mobile Group Zhejiang Co.,Ltd (China Hangzhou)
发表于 2020-12-23 09:16:19 | 只看该作者
你好,欢迎来到la村
 楼主| 发表于 2020-12-23 09:17:00 | 只看该作者
还有个888mini没开,到时候在测下
GMT+8, 2026-4-23 05:58 , Processed in 0.070377 second(s), 10 queries , Gzip On, MemCache On.
