查看: 1079|回复: 4
[不限流量] 【已出】溢价10元出RN黑五闪售 11.89$
发表于 2020-12-13 21:29:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1 个AMD RYZEN核心
15 GB NVMe 硬盘
512 MB 内存
2,000 GB 月流量
1Gbps 带宽
1 个IPv4
可选机房:洛杉矶DC-02
闪售价格: $11.89 /年,续费同价
闪售数量: 30
   BYTE UNIX Benchmarks (Version 5.1.3)
   System: racknerd-d09f41: GNU/Linux
   OS: GNU/Linux -- 4.9.0-4-amd64 -- #1 SMP Debian 4.9.65-3+deb9u1 (2017-12-23)
   Machine: x86_64 (unknown)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: AMD Ryzen 9 3900X 12-Core Processor (7585.7 bogomips)
          x86-64, MMX, AMD MMX, Physical Address Ext, SYSENTER/SYSEXIT, AMD virtualization, SYSCALL/SYSRET
   20:52:10 up 14 days, 20:26,  1 user,  load average: 0.00, 0.00, 0.00; runlevel 5
Benchmark Run: Sun Dec 13 2020 20:52:10 - 21:22:09
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       47148315.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3373.9 MWIPS (22.1 s, 7 samples)
Execl Throughput                               9796.7 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks       1747587.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          491505.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       3776720.9 KBps  (30.0 s, 2 samples)
Pipe Throughput                             3334116.4 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 461598.3 lps   (10.0 s, 7 samples)
Process Creation                              26158.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  16182.5 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2119.4 lpm   (60.0 s, 2 samples)
System Call Overhead                        5004425.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   47148315.8   4040.1
Double-Precision Whetstone                       55.0       3373.9    613.4
Execl Throughput                                 43.0       9796.7   2278.3
File Copy 1024 bufsize 2000 maxblocks          3960.0    1747587.6   4413.1
File Copy 256 bufsize 500 maxblocks            1655.0     491505.0   2969.8
File Copy 4096 bufsize 8000 maxblocks          5800.0    3776720.9   6511.6
Pipe Throughput                               12440.0    3334116.4   2680.2
Pipe-based Context Switching                   4000.0     461598.3   1154.0
Process Creation                                126.0      26158.6   2076.1
Shell Scripts (1 concurrent)                     42.4      16182.5   3816.6
Shell Scripts (8 concurrent)                      6.0       2119.4   3532.4
System Call Overhead                          15000.0    5004425.1   3336.3
System Benchmarks Index Score                                        2683.1
======= Script description and score comparison completed! =======
AMD核心性能爆炸
有需要的pm或tg tkrdust
小鸡已出,感谢各位大佬绑定
发表于 2020-12-13 21:50:51 来自手机 | 只看该作者
绑定,就是内存太小了
发表于 2020-12-13 22:00:01 | 只看该作者
帮顶 手上 还有2个。。。
发表于 2020-12-13 22:03:39 | 只看该作者
翻倍了流量 ,还是后悔用7.38置换了。发现这个内存根本用不到那么高的CPU。
GMT+8, 2026-4-23 16:10 , Processed in 0.070032 second(s), 10 queries , Gzip On, MemCache On.
