查看: 828|回复: 7
[疑问] hosthatch 2T 芝加哥IO测试
发表于 2020-12-6 21:48:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
wget -qO- http://ilemonra.in/LemonBenchIntl | bash -s full
  1. OS Release:            Debian GNU/Linux "Buster" 10.7 (x86_64)
  2. CPU Model:             Intel(R) Xeon(R) CPU E5-2680 v2 [url=home.php?mod=space&uid=175]@[/url] 2.80GHz  2.80 GHz
  3. CPU Cache Size:        16384 KB
  4. CPU Number:            1 vCPU
  5. Virt Type:             KVM
  6. Memory Usage:          82.98 MB / 3.85 GB
  7. Swap Usage:            0 KB / 975.00 MB
  8. Boot Device:           /dev/vda1
  9. Disk Usage:            982.62 MB / 2062200.26 MB
  10. CPU Usage:             0.0% used, 0.0% iowait, 0.0% steal
  11. Load (1/5/15min):      0.15 0.03 0.01
  12. Uptime:                0 Days, 13 Hours, 6 Minutes, 15 Seconds
  13. Kernel Version:        4.19.0-13-amd64
  14. Network CC Method:     cubic + pfifo_fast
  15. -> CPU Performance Test (Standard Mode, 3-Pass @ 30sec)
  16. 1 Thread Test:                 832 Scores
  17. -> Memory Performance Test (Standard Mode, 3-Pass @ 30sec)
  18. 1 Thread - Read Test :         17198.13 MB/s
  19. 1 Thread - Write Test:         13591.24 MB/s
  20. -> Disk Speed Test (4K Block/1M Block, Direct-Write)
  21. Test Name              Write Speed                             Read Speed
  22. 10MB-4K Block          33.0 MB/s (8045 IOPS, 0.32s)            41.3 MB/s (10083 IOPS, 0.25s)
  23. 10MB-1M Block          1.4 GB/s (1358 IOPS, 0.01s)             1.7 GB/s (1611 IOPS, 0.01s)
  24. 100MB-4K Block         32.8 MB/s (8010 IOPS, 3.20s)            35.7 MB/s (8717 IOPS, 2.94s)
  25. 100MB-1M Block         1.4 GB/s (1293 IOPS, 0.08s)             156 MB/s (148 IOPS, 0.67s)
  26. 1GB-4K Block           33.5 MB/s (8177 IOPS, 31.31s)           38.5 MB/s (9393 IOPS, 27.25s)
  27. 1GB-1M Block           1.4 GB/s (1361 IOPS, 0.73s)             140 MB/s (133 IOPS, 7.51s)
bash <(wget -qO- git.io/ceshi) -j
  1.   CPU 型号              Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
  2.   CPU 核心              合计 1 核心,1 线程
  3.   CPU 状态              当前主频 2799.998 MHz
  4.   内存大小              3946 MB (56 MB 已用)
  5.   交换分区              974 MB (0 MB 已用)
  6.   硬盘大小              2048.0 GB
  7.   服务器时间            2020-12-06 21:40:09
  8.   运行时间              0 days 13 hour 36 min
  9.   系统负载              0.07, 0.16, 0.17
  10.   虚拟化技术            KVM
  11.   当前脚本版本          1.4.1.1
  12.   +-----------+-----------+----------+-----------+-----------+
  13.   | 测试项目  | 读取 IOPS | 读取速度 | 写入 IOPS |  写入速度 |
  14.   +-----------+-----------+----------+-----------+-----------+
  15.   | Seq-Q32T1 |      7019 | 877 MB/s |     18184 | 2.22 GB/s |
  16.   | Seq       |       515 | 515 MB/s |      1288 | 1.26 GB/s |
  17.   | 4K-Q32T1  |      4508 |  17 MB/s |      1958 |    7 MB/s |
  18.   | 4K        |       121 | 487 KB/s |      1856 |    7 MB/s |
  19.   +-----------+-----------+----------+-----------+-----------+
wget -qO- bench.sh | bash
  1. CPU Model             : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
  2. CPU Cores             : 1
  3. CPU Frequency         : 2799.998 MHz
  4. CPU Cache             : 16384 KB
  5. Total Disk            : 2048.0 GB (1.1 GB Used)
  6. Total Mem             : 3946 MB (184 MB Used)
  7. Total Swap            : 974 MB (0 MB Used)
  8. System uptime         : 0 days, 13 hour 45 min
  9. Load average          : 0.28, 0.09, 0.11
  10. OS                    : Debian GNU/Linux 10
  11. Arch                  : x86_64 (64 Bit)
  12. Kernel                : 4.19.0-13-amd64
  13. TCP CC                : cubic
  14. Virtualization        : KVM
  15. Organization          : AS63473 HostHatch, LLC
  16. Location              : Tampa / US
  17. Region                : Florida
  18. ----------------------------------------------------------------------
  19. I/O Speed(1st run)    : 555 MB/s
  20. I/O Speed(2nd run)    : 696 MB/s
  21. I/O Speed(3rd run)    : 777 MB/s
  22. Average I/O speed     : 676.0 MB/s
  23. ----------------------------------------------------------------------
  24. Node Name        Upload Speed      Download Speed      Latency
  25. Speedtest.net    669.51 Mbps       927.12 Mbps         39.93 ms
  26. Beijing    CU    1.02 Mbps         951.17 Mbps         320.57 ms
  27. Shanghai   CU    0.44 Mbps         3.53 Mbps           360.63 ms
  28. Guangzhou  CU    80.75 Mbps        2.89 Mbps           240.25 ms
  29. Shenzhen   CU    197.66 Mbps       9.35 Mbps           220.37 ms
  30. Hongkong   CN    280.14 Mbps       11.25 Mbps          180.28 ms
  31. Singapore  SG    217.20 Mbps       9.11 Mbps           228.17 ms
  32. Tokyo      JP    47.97 Mbps        10.11 Mbps          140.13 ms
  33. ----------------------------------------------------------------------
wget --no-check-certificate https://github.com/teddysun/across/raw/master/unixbench.sh
chmod +x unixbench.sh
./unixbench.sh
  1. Benchmark Run: Sun Dec 06 2020 21:56:49 - 22:24:49
  2. 1 CPU in system; running 1 parallel copy of tests
  3. Dhrystone 2 using register variables       33647082.9 lps   (10.0 s, 7 samples)
  4. Double-Precision Whetstone                     5104.5 MWIPS (9.4 s, 7 samples)
  5. Execl Throughput                               3610.7 lps   (30.0 s, 2 samples)
  6. File Copy 1024 bufsize 2000 maxblocks        443972.4 KBps  (30.0 s, 2 samples)
  7. File Copy 256 bufsize 500 maxblocks          127374.8 KBps  (30.0 s, 2 samples)
  8. File Copy 4096 bufsize 8000 maxblocks       1039849.6 KBps  (30.0 s, 2 samples)
  9. Pipe Throughput                              712791.7 lps   (10.0 s, 7 samples)
  10. Pipe-based Context Switching                 187388.3 lps   (10.0 s, 7 samples)
  11. Process Creation                               8917.5 lps   (30.0 s, 2 samples)
  12. Shell Scripts (1 concurrent)                   6649.6 lpm   (60.0 s, 2 samples)
  13. Shell Scripts (8 concurrent)                    845.9 lpm   (60.0 s, 2 samples)
  14. System Call Overhead                         400483.8 lps   (10.0 s, 7 samples)
  15. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  16. Dhrystone 2 using register variables         116700.0   33647082.9   2883.2
  17. Double-Precision Whetstone                       55.0       5104.5    928.1
  18. Execl Throughput                                 43.0       3610.7    839.7
  19. File Copy 1024 bufsize 2000 maxblocks          3960.0     443972.4   1121.1
  20. File Copy 256 bufsize 500 maxblocks            1655.0     127374.8    769.6
  21. File Copy 4096 bufsize 8000 maxblocks          5800.0    1039849.6   1792.8
  22. Pipe Throughput                               12440.0     712791.7    573.0
  23. Pipe-based Context Switching                   4000.0     187388.3    468.5
  24. Process Creation                                126.0       8917.5    707.7
  25. Shell Scripts (1 concurrent)                     42.4       6649.6   1568.3
  26. Shell Scripts (8 concurrent)                      6.0        845.9   1409.8
  27. System Call Overhead                          15000.0     400483.8    267.0
  28.        ========
  29. System Benchmarks Index Score                                         924.5
  30. ======= Script description and score comparison completed! =======
发表于 2020-12-6 21:49:30 来自手机 | 只看该作者
还没开的默默路过
发表于 2020-12-6 21:49:40 | 只看该作者
目前来说中规中矩 差强人意
发表于 2020-12-6 21:51:06 | 只看该作者
2680 2690 有啥差距吗
发表于 2020-12-6 21:57:08 来自手机 | 只看该作者
刚刚开了,io一样
发表于 2020-12-6 21:59:59 | 只看该作者
很不错喔
发表于 2020-12-6 22:11:34 来自手机 | 只看该作者
Stillso 发表于 2020-12-6 21:51
2680 2690 有啥差距吗
2690主频有3G。真香。
GMT+8, 2026-1-15 14:18 , Processed in 0.061244 second(s), 9 queries , Gzip On, MemCache On.
