CeraNetworks网络延迟测速工具IP归属甄别
查看: 10109|回复: 10
KT到底怎么弄的 搞成这样
发表于 2009-12-17 22:47:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
C:\Documents and Settings\Administrator>ping 98.126.17.114 -t
Pinging 98.126.17.114 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 98.126.17.114: bytes=32 time=273ms TTL=108
Request timed out.
Reply from 98.126.17.114: bytes=32 time=282ms TTL=108
Reply from 98.126.17.114: bytes=32 time=287ms TTL=108
Request timed out.
Request timed out.
Reply from 98.126.17.114: bytes=32 time=218ms TTL=108
Request timed out.
Ping statistics for 98.126.17.114:
    Packets: Sent = 14, Received = 4, Lost = 10 (71% loss),
    Minimum = 218ms, Maximum = 287ms, Average = 265ms
这还玩个鸟呀 昨天被百度K  今天KT又这样   真是纠结
发表于 2009-12-17 23:05:26 | 只看该作者
的确操蛋,可能线路不一样情况不一样,我两个VPS一个正常200内延时,一个延时300多还掉包
不知道能不能换线路
发表于 2009-12-18 02:19:55 | 只看该作者
回复 1# 的帖子
KT貌似升级了一个核心路由,现在应该基本正常了。
发表于 2009-12-18 02:20:30 | 只看该作者
Reply from 98.126.17.114: bytes=32 time=190ms TTL=115
Reply from 98.126.17.114: bytes=32 time=188ms TTL=115
Reply from 98.126.17.114: bytes=32 time=195ms TTL=115
    Minimum = 188ms, Maximum = 195ms, Average = 190ms
发表于 2009-12-19 00:09:13 | 只看该作者
速度还真不错啊
发表于 2009-12-19 11:24:13 | 只看该作者
回复 5# 的帖子
现在是正常了。
发表于 2009-12-20 14:13:04 | 只看该作者
是他们的网络出问题了。
发表于 2009-12-20 21:34:22 | 只看该作者
回复 7# 的帖子
是的,机房网络问题。
发表于 2009-12-28 09:30:42 | 只看该作者
kt现在相当不稳定
KT现的在ping也相当的不稳定!
Reply from 98.126.7.74: bytes=32 time=360ms TTL=52
Reply from 98.126.7.74: bytes=32 time=208ms TTL=52
Reply from 98.126.7.74: bytes=32 time=200ms TTL=52
Reply from 98.126.7.74: bytes=32 time=199ms TTL=52
Reply from 98.126.7.74: bytes=32 time=201ms TTL=52
Reply from 98.126.7.74: bytes=32 time=258ms TTL=52
Reply from 98.126.7.74: bytes=32 time=198ms TTL=52
Reply from 98.126.7.74: bytes=32 time=204ms TTL=52
Reply from 98.126.7.74: bytes=32 time=196ms TTL=52
Reply from 98.126.7.74: bytes=32 time=197ms TTL=52
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
我已经快受不了了!
发表于 2009-12-28 10:36:16 | 只看该作者
我已经发邮件去问了,回信说:
It looks like most/all of the problems are at the server itself. You should check your firewall/remote and routing settings to make sure that its accepting all packets.
无语了...我的防火墙就没有开过,路由器配置我完全不懂,机器拿来后就没有动过。之前这台机器一直都工作得很好,就这几天出问题。没办法,我把ssh的用户名和密码给他们,请他们帮忙查一下了。
GMT+8, 2026-4-18 11:32 , Processed in 0.078135 second(s), 12 queries , Gzip On, MemCache On.
