查看: 2636|回复: 13
黑五最后没忍住上了个RN,把3周年的CC拿出来跑了下分180
发表于 2020-11-30 13:31:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3核心的鸡还是首次上,感觉用来建站应该是靠谱的,
之前本来想要用CC的3周年建站,看中2G内存。
实际体验卡得我再也不想碰CC了。
上了RN的两辆雪国列车,对比跑分如下:
CC的:
Dhrystone 2 using register variables       11903747.2 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2417.2 MWIPS (9.0 s, 7 samples)
Execl Throughput                                738.4 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks         69219.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           17222.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        196290.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              103118.6 lps   (10.1 s, 7 samples)
Pipe-based Context Switching                  25555.5 lps   (10.0 s, 7 samples)
Process Creation                               1938.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   1369.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    110.4 lpm   (60.3 s, 2 samples)
System Call Overhead                          75485.6 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   11903747.2   1020.0
Double-Precision Whetstone                       55.0       2417.2    439.5
Execl Throughput                                 43.0        738.4    171.7
File Copy 1024 bufsize 2000 maxblocks          3960.0      69219.6    174.8
File Copy 256 bufsize 500 maxblocks            1655.0      17222.1    104.1
File Copy 4096 bufsize 8000 maxblocks          5800.0     196290.4    338.4
Pipe Throughput                               12440.0     103118.6     82.9
Pipe-based Context Switching                   4000.0      25555.5     63.9
Process Creation                                126.0       1938.1    153.8
Shell Scripts (1 concurrent)                     42.4       1369.2    322.9
Shell Scripts (8 concurrent)                      6.0        110.4    184.0
System Call Overhead                          15000.0      75485.6     50.3
System Benchmarks Index Score                                         180.0
RN黑5终极3C4T:
3 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       30791111.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4668.6 MWIPS (9.4 s, 7 samples)
Execl Throughput                               2677.4 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        390967.1 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          105648.6 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        991828.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                              597751.1 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  67249.5 lps   (10.0 s, 7 samples)
Process Creation                               4315.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6053.1 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1672.0 lpm   (60.0 s, 2 samples)
System Call Overhead                         365117.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   30791111.9   2638.5
Double-Precision Whetstone                       55.0       4668.6    848.8
Execl Throughput                                 43.0       2677.4    622.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     390967.1    987.3
File Copy 256 bufsize 500 maxblocks            1655.0     105648.6    638.4
File Copy 4096 bufsize 8000 maxblocks          5800.0     991828.0   1710.0
Pipe Throughput                               12440.0     597751.1    480.5
Pipe-based Context Switching                   4000.0      67249.5    168.1
Process Creation                                126.0       4315.6    342.5
Shell Scripts (1 concurrent)                     42.4       6053.1   1427.6
Shell Scripts (8 concurrent)                      6.0       1672.0   2786.7
System Call Overhead                          15000.0     365117.7    243.4
System Benchmarks Index Score                                         765.2
Benchmark Run: Mon Nov 30 2020 13:01:45 - 13:29:48
3 CPUs in system; running 3 parallel copies of tests
Dhrystone 2 using register variables       91760829.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    13963.5 MWIPS (9.4 s, 7 samples)
Execl Throughput                               7282.8 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        781099.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          212199.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       2167514.0 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1791234.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 361174.8 lps   (10.0 s, 7 samples)
Process Creation                              10800.2 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  13308.8 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1965.1 lpm   (60.0 s, 2 samples)
System Call Overhead                        1034906.5 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   91760829.8   7863.0
Double-Precision Whetstone                       55.0      13963.5   2538.8
Execl Throughput                                 43.0       7282.8   1693.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     781099.9   1972.5
File Copy 256 bufsize 500 maxblocks            1655.0     212199.1   1282.2
File Copy 4096 bufsize 8000 maxblocks          5800.0    2167514.0   3737.1
Pipe Throughput                               12440.0    1791234.7   1439.9
Pipe-based Context Switching                   4000.0     361174.8    902.9
Process Creation                                126.0      10800.2    857.2
Shell Scripts (1 concurrent)                     42.4      13308.8   3138.9
Shell Scripts (8 concurrent)                      6.0       1965.1   3275.2
System Call Overhead                          15000.0    1034906.5    689.9
System Benchmarks Index Score                                        1921.0
RN的AMD跑分 core:
Dhrystone 2 using register variables       51961866.6 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     9417.1 MWIPS (9.9 s, 7 samples)
Execl Throughput                               7772.0 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks       1716870.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          479559.4 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       4032708.8 KBps  (30.0 s, 2 samples)
Pipe Throughput                             3090402.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 439232.0 lps   (10.0 s, 7 samples)
Process Creation                              28322.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  14927.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1890.5 lpm   (60.0 s, 2 samples)
System Call Overhead                        3890172.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   51961866.6   4452.6
Double-Precision Whetstone                       55.0       9417.1   1712.2
Execl Throughput                                 43.0       7772.0   1807.4
File Copy 1024 bufsize 2000 maxblocks          3960.0    1716870.9   4335.5
File Copy 256 bufsize 500 maxblocks            1655.0     479559.4   2897.6
File Copy 4096 bufsize 8000 maxblocks          5800.0    4032708.8   6952.9
Pipe Throughput                               12440.0    3090402.7   2484.2
Pipe-based Context Switching                   4000.0     439232.0   1098.1
Process Creation                                126.0      28322.1   2247.8
Shell Scripts (1 concurrent)                     42.4      14927.2   3520.6
Shell Scripts (8 concurrent)                      6.0       1890.5   3150.9
System Call Overhead                          15000.0    3890172.7   2593.4
System Benchmarks Index Score                                        2779.2
======= Script description and score comparison completed! =======
总结:AMD YES
发表于 2020-11-30 14:19:11 来自手机 | 只看该作者
AFFman表示跑分就算2分我也能吹出花来
发表于 2020-11-30 13:32:22 | 只看该作者
发表于 2020-11-30 13:34:30 | 只看该作者
看了下最近MJJ发的节点
好像RN的速度相对快一些。不过IP确实都被google拉黑了 要验证
Fei 该用户已被删除
发表于 2020-11-30 13:37:30 | 只看该作者
发表于 2020-11-30 13:53:25 | 只看该作者
Fei 发表于 2020-11-30 13:37
cc周年不如丢了买Hosthatch。
3周年这个现在退的话,是到余额?
发表于 2020-11-30 13:55:20 | 只看该作者
在用cc per黑五版本  1.9刀  感觉还ok
发表于 2020-11-30 13:59:53 | 只看该作者
AMD是单核还是双核的?
单核  发表于 2020-11-30 14:20
发表于 2020-11-30 14:02:58 | 只看该作者
cc感觉不行了
发表于 2020-11-30 14:10:09 | 只看该作者
脚本分享一下?
发表于 2020-11-30 14:14:33 | 只看该作者
为什么还有人执着上CC家的车
这家烂是出了名的
GMT+8, 2026-4-30 09:40 , Processed in 0.073445 second(s), 16 queries , Gzip On, MemCache On.
